New Reply
line level and attenuation
Share Thread Thread Tools
Dec31-12, 04:19 AM   #1
hello all
first post here and i'm interested in some info you people may hold
in layman's terms i'm trying to understand how a fixed line level can attenuate.
according to wikis line level page the 'the signal out or line out remains at a constant level, regardless of the current setting of the volume control', i understand the statement but not the engineering behind it i.e how you attenuate a signal that is fixed
hope you can shed some light here
regards
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
Dec31-12, 07:27 AM   #2
You don't, they aren't talking about the same signals.
Typically a hifi system will have several outputs. For example there might be speaker outputs, line outputs, headphone outputs etc Each output is intended to be connected to a different type of device. Some systems will even have digital outputs, perhaps capable of streaming the signal to a network.
Normally if the system has a volume control it only affects the speaker outputs but sometimes they are designed to affect other outputs as well. Normally the line output is not affected by the volume controls.
Here is a block diagram..
Although not shown on the diagram the line output would be connected after the preamp but before the tone and volume control block. A Line Input might also be provided and this would also be connected at this point.
Dec31-12, 07:38 AM   #3
PS. I've looked for a better block diagram online but to my surprise I've not been able to find one showing a traditional hifi amplifier.
New Reply
Thread Tools
Similar Threads for: line level and attenuation
Thread Forum Replies
Line Level Frequency Splitting Electrical Engineering 2
point source (radioactive)..that emits 100 gamma per second High Energy, Nuclear, Particle Physics 5
Transmission line attenuation Electrical Engineering 11
unit of sound/noise is decibels General Physics 1
materials and attenuation Atomic, Solid State, Comp. Physics 0
