Can Warm Water Help Treat Sunburns?
  • Medical
  • Thread starter oexnorth
  • Tags
    Hot Water
In summary: Someone deleted the posts you mentioned, but I have copies saved if anyone wants to see what I'm talking about.Thanks, hypatia. When I first heard that running warm or hot water over your skin to open the pores to let more heat out, I had serious doubts. Hot water might open the pores but it still adds a lot of heat to the system, so any benefits are immediately countered. Most of what I've read and the help that I've gotten from the people on this forum have put that myth to rest. Thanks again.If the area has fluid filled blister, seek medical aid. Never apply heat to a burn. Use cool water, and lotions developed for treating burns. Never use
oexnorth
I have heard that warm water helps to open the pores of your skin, and therefore, can release more heat which will aid in the treatment of a sunburn. I was immediately skeptical, but after a few searches I found answers both for and against it. What are the actual physics behind this, and, if a definitive answer can be given, what is it? Thank you.
Biology news on Phys.org
Personally, I'm pretty sure its completely ridiculous! :P
A sun 'burn' isn't from your skin getting too hot, its from radiation (mostly ultraviolet) damage. People often get sunburns while skiing, due to the reflectivity of the snow; or on cloudy days (cool, but still irradiated).
Hot water, and opening poors will have ZERO effect.
I appreciate your reply and I thank you. Can you direct towards something that I can see for myself why warm/hot water doesn't work?
It isn't our job to prove to you it doesn't work. The claim is ridiculous and does not address the root cause of a sunburn- UV damage. Unless you can post a credible site which proves it does help, this thread was done before it started.
http://en.wikipedia.org/wiki/Sun_burn is plenty.
A sunburn is still considered a burn {generally classified as a superficial or first-degree burn}, and should be treated as such.
If the area has fluid filled blister, seek medical aid. Never apply heat to a burn. Use cool water, and lotions developed for treating burns. Never use salves or ointments that would trap the heat in.
http://www.mayoclinic.com/health/sunburn-treatment/AN01423
Does the Physics Forums edit posts? A couple of comments were deleted from this one, including my own. I don't like negative back-and-forths, but I also respect freedom of speech. Can someone tell me what happened to those posts? I have backups if anybody wants to see what I mean.
Check your inbox with private messages.
What causes sunburns?
Sunburns are caused by overexposure to ultraviolet (UV) radiation from the sun. When the skin is exposed to too much UV radiation, it causes damage to the skin cells, leading to inflammation and redness.
Does hot water help with sunburns?
No, hot water can actually make sunburns worse. Hot water can further irritate and damage already sensitive and burned skin. It is recommended to use cool or lukewarm water to soothe sunburned skin.
How does hot water affect sun-damaged skin?
Hot water can strip the skin of its natural oils and moisture, making it more vulnerable to further damage and irritation. It can also worsen the appearance of sun-damaged skin, such as causing it to peel or become more red and inflamed.
Can hot water help with peeling skin from sunburns?
No, hot water can actually worsen peeling skin from sunburns. Hot water can strip the skin of its natural oils, making it drier and more prone to peeling. It is recommended to use moisturizers and gentle exfoliants to help with peeling skin.
How can hot water be used to prevent sunburns?
Hot water should not be used as a preventative measure for sunburns. The best way to prevent sunburns is to limit sun exposure, wear protective clothing and sunscreen, and seek shade when possible. It is important to remember that hot water does not offer any protection against UV radiation.
  • Biology and Medical
  • General Engineering
  • Earth Sciences
22K
  • Mechanical Engineering
