Matter and energy short question
In summary: For energy, it's not even 'primarily', it just 'is'.In summary, energy and mass are closely related concepts that are linked by the famous equation E=mc^2. In non-relativistic theory, an object at rest has no energy, while in relativistic theory, it has some rest energy. The correlation between time, space, energy, and mass is a complex topic, with energy being primarily linked to space dimension and mass primarily linked to time dimension. However, for energy, it is not even primarily linked, it just "is".
Whitefire
39
Is it correct to define matter as a force moving primarily in time dimension, and energy as the same force moving primarily in space dimension of spacetime?
Nope. Matter isn't a particularly useful concept and force and mass are separate concepts.
Dauto is true.Moreover,matter can also move in the space dimension.
Energy: The ability for one system to perform work on another.
Force (From Wiki): In physics, a force is any influence that causes an object to undergo a certain change, either concerning its movement, direction, or geometrical construction. In other words, a force can cause an object with mass to change its velocity (which includes to begin moving from a state of rest), i.e., to accelerate, or a flexible object to deform, or both.
There is no rigorous definition of matter.
Matter can be defined as things which has mass and volume.
I used the word 'force' to avoid saying that 'energy is energy', which is not really saying anything, and to avoid saying 'matter is energy' and 'energy is matter', which still means describing IT with two different words.
I asked the question because I am trying to define the difference between energy and matter. Well, I know that the difference is c^2, but it is just a number, I want to understand what this number really does with... IT.
You might try this thread: www.physicsforums.com/showthread.php?t=720053
You're confusing mass with matter. The m in the equation E=mc2 stands for mass, not matter.
The M in E=MC2 stands for mass, not matter. Be aware that a great many people say that mass is a form of energy. Whether this is true or not I don't know. The fact remains that the two are intimately linked together. If you remove energy from a system, it will also lose mass.
For example, let's say we lose 10 joules of energy in the form of light from a system (The form of the energy is irrelevant for our discussion). Putting 10 joules in the equation for E and solving for M gives us about 1x10-16 kg's lost from the system. So not much mass in this particular example.
Now, instead of measuring the energy removed from a system, we can also measure the mass before and after. Let's say our object radiates energy away and the mass afterwards is 1 kg less than before. Putting 1 in for M and solving for E yields about 9x1016 joules of energy lost as radiation. That is a LOT of energy, on par with a nuclear explosion.
Note that there is an extreme difference between the amount of energy and mass. This is simply a result of the units we choose to represent energy and mass.
sorry, my bad, I am not a native English speaker and I never learned physics in English :D
@ Nugatory: thanks, this seems to be exactly what I wanted - a discussion about the nature of energy and mass - even if they only appear to be different, it is still worth understanding why.
In non-relativistic theory, energy momentum and mass are related to each other by the formula
[tex]E=\frac{p^2}{2m},[/tex]
so if you set the momentum to zero (p=0) you get E=0. That means that an object at rest has no energy.
In relativistic theory, energy momentum and mass are related to each other by the formula
[tex]E^2=(cp)^2+(mc^2)^2,[/tex]
so if you set the momentum to zero (p=0) you get E=mc^2. That means that an object at rest has some rest energy.
An object at rest not only has some rest energy, I daresay (E=mc^2) that it has a LOT of energy. You say that it is 'rest' energy and 'rest' object, but isn't there one process that happens even to the object with zero momentum? Time passage? We usually say 'time passes for it' as if it were something distant and not related, but we don't really understand why time passes, do we.
So this happens for objects.
Now on the other hand, if you imagine a basic form of energy - light... It moves through space, but does it really move through time? Aren't there assumptions that at the speed of light, time freezes? At least relatively, but from the same point of view that we considered the object a moment earlier. We don't really even say that 'time passes' for a wave of light in vacuum.
So basically this is the correlation between time, space, energy and mass (ok, not matter) that I wanted to talk about; that's why I said "primarily in time dimension" and "primarily in space dimension". Primarily, because of course objects usually have some momentum and even light can be slowed, perhaps stopped. I have no idea how this fits with the rest. Maybe what is mass and what energy is also only relative. Now that would be something.
light and energy are not synonyms. Light is a physical object. Having energy is one of its properties but it also has other properties such as momentum and angular momentum. There are many other forms of energy and different physical objects may have different forms of energy. The popular view of light as being "pure energy" doesn't really make any sense.
Matter can move in the space dimension as well, so no
Also, the claim that light does not experience the passage of time because it travels at c is a faulty use of the lorentz transformation. It only applies to objects whose frame can be transformed to a rest frame, where the object is at rest. But light can never be at rest and as such you cannot apply the lorentz transformation to it, so the whole idea just doesn't make sense. Also, consider that if light, an EM wave, has no passage of time, then why do the fields oscillate?
1. What is matter?
Matter is anything that has mass and takes up space. It can exist in three states: solid, liquid, and gas.
2. What is energy?
Energy is the ability to do work or cause change. It comes in many forms such as heat, light, and electricity.
3. What is the relationship between matter and energy?
Matter and energy are closely related and can be converted into one another. This is described by Albert Einstein's famous equation, E=mc^2, which states that energy (E) is equal to mass (m) multiplied by the speed of light squared (c^2).
4. How is matter and energy conserved?
The law of conservation of matter states that matter cannot be created or destroyed, it can only change forms. The law of conservation of energy states that energy cannot be created or destroyed, it can only be transferred or converted into different forms.
5. How do matter and energy interact in everyday life?
Matter and energy are constantly interacting in our daily lives. For example, when we turn on a light switch, chemical energy in the form of electricity is converted into light energy. When we eat food, our bodies convert the chemical energy in the food into mechanical energy for movement and heat energy to keep us warm.
  • Other Physics Topics
