Pitch of net slip and plunge and trend of net slip of a fault using stereonets
In summary, the problem involves determining the net slip, plunge, trend, and attitude of the net slip for 2 cut veins that have been displaced along a fault plane. To find the plunge and trend, you can use the orientations of the cut veins and fault plane on a stereonet. The attitude of the net slip can also be found using a stereonet. If you need more help, consider reaching out to your instructor or classmates.
subopolois
86
ive been given a problem in my school work. it involves 2 veins that have been cut by a fault and displaced along the fault plane. the question gives the orientation of the cut veins on either side of the wall and the orientation of the fault. it asks for the following: net slip, plunge and trend of the net slip and the attitude of the net slip.
i know how to plot planes, lineations, poles etc on stereonets and i have already found the net slip, i just need some help with the plunge and trend and attitude of the net slip
Hi there! It sounds like you're working on a geology or structural geology problem. I'm not an expert in this field, but I can offer some general advice.
First, let's define some terms. The "net slip" is the total amount of displacement along the fault plane. Plunge refers to the angle that the net slip makes with the horizontal plane, and trend refers to the direction of the net slip in relation to a compass direction. The attitude of the net slip refers to the orientation of the net slip in relation to a reference plane, typically the horizontal plane.
To find the plunge and trend of the net slip, you will need to use the orientations of the cut veins and the fault plane. The plunge can be calculated by finding the difference in dip between the two cut veins. The trend can be found by determining the direction of the fault plane and then using the orientation of the cut veins to determine the direction of the net slip. You can use a stereonet to plot these orientations and calculate the plunge and trend.
To find the attitude of the net slip, you will need to use the orientations of the cut veins and the fault plane to determine the orientation of the net slip in relation to the horizontal plane. This can also be done using a stereonet.
I hope this helps! If you need more specific guidance, I suggest reaching out to your instructor or a classmate for help. Good luck with your school work!
What is the meaning of "pitch of net slip"?
The pitch of net slip refers to the angle between the horizontal plane and the direction of slip of a fault. It is measured on a stereonet, which is a graphical representation of a fault's orientation in three-dimensional space.
What is the difference between plunge and trend of net slip?
Plunge refers to the angle between the horizontal plane and the direction of slip projected onto a vertical plane, while trend refers to the horizontal direction of the projected slip. In other words, plunge is the angle of inclination and trend is the direction of the slip.
How is the pitch of net slip calculated on a stereonet?
The pitch of net slip is calculated by measuring the angle between the horizontal plane and the projected slip line on the stereonet. This can be done using a protractor or specialized tools such as a Wulff net.
Why is it important to determine the pitch, plunge, and trend of net slip of a fault?
Understanding the orientation of a fault and its slip can provide insight into the mechanics of an earthquake and help in predicting future seismic activity. It can also aid in the design and construction of structures to withstand potential fault movement.
What other information can be obtained from a stereonet analysis?
Stereonet analysis can also provide information on the orientation and movement of other geological structures, such as folds and joints. It can also be used to determine the direction and rate of tectonic plate movement.
54K
  • General Discussion
  • Astronomy and Astrophysics
  • Computing and Technology
