Q: Inertial Frames & Detecting Motion
In summary, in a true inertial frame inside a train compartment, it is impossible to determine if you are moving or not, according to Newton's Laws of Motion. However, the existence of Higgs and neutrino detectors may make it impossible to have a pure inertial frame of reference. This may have ramifications for special relativity and Newton's Laws, but the train car analogy assumes that even hypothetical space-time foam cannot be detected from inside the train. Additionally, the principle of relativity states that the laws of physics work the same in all frames, so particles will behave the same regardless of the train's state of motion.
mjacobsca
98
In a true inertial frame inside a train compartment, it is impossible to do an experiment that can tell you if you are moving or not. This is a key consequence of Newton's Laws Of Motion. However, if someone had a neutrino detector, or a Higgs detector (assuming they exist), wouldn't it be impossible to have a pure inertial frame of reference, ever, since we could always determine motion? Would this have any ramifications for special relativity or Newton's Laws Of Motion? Or, as I expect, does the train car analogy assume that nothing, not even a hypothetical bit of space-time foamy quantization, could be detected from inside the train car?
Higgs particles and neutrinos do not all have a common rest frame (nor is the space-time foam expected to), if these particles were created during the course of the experiment by the lab apparatus then they should behave the same (on average) regardless of the train's state of motion. If you're talking about cosmological neutrinos, the principle of relativity just says the laws of physics work the same way in all frames, so if you start with the same initial conditions of particles in a train, they will behave (on average) the same way subsequently regardless of the state of motion. Cosmological neutrinos coming from the outside might look different depending on the train's speed relative to the CMBR, but this doesn't change the fact about the laws of physics being the same.
1. What are inertial frames?
Inertial frames refer to frames of reference in which Newton's laws of motion hold true, meaning that an object will either remain at rest or maintain a constant velocity unless acted upon by an external force.
2. How do inertial frames relate to detecting motion?
Inertial frames are important for detecting motion because they provide a fixed reference point from which to measure the movement of an object. If an object is in an inertial frame, any changes in its position or velocity can be accurately measured and attributed to external forces.
3. Can any frame of reference be considered an inertial frame?
No, not all frames of reference can be considered inertial frames. In order to be considered an inertial frame, the frame must not be accelerating or rotating. This means that the frame must be in a state of constant motion or at rest.
4. How can we detect motion in an inertial frame?
Motion in an inertial frame can be detected using various methods such as measuring the displacement, velocity, and acceleration of an object. Other techniques such as using lasers or tracking systems can also be used to detect motion in an inertial frame.
5. What are some real-world applications of inertial frames and detecting motion?
Inertial frames and detecting motion have numerous applications in fields such as aerospace, navigation, and robotics. For example, inertial frames are used in aircraft and spacecraft to determine their position and orientation, while motion detection is crucial in the development of autonomous vehicles and robotic systems.
