Can the Potential Energy of a Rocket Be Calculated Using a Simple Formula?
In summary: Therefore, the potential energy of the rocket cannot be calculated by that formula. The gain in GPE of the rocket is calculated by -GMm/r because it takes into account the work done by the conservative force of gravity as the rocket moves from one point to another. Thrust, on the other hand, does not have a fixed direction and its work depends on the path taken. Therefore, it does not make sense to include it in the calculation of potential energy.
Miraj Kayastha
80
When a rocket is launched into space, its GPE increases and its KE decreases.
If we equate the change in both energies we can find out the velocity of the rocket at a certain height.
Δ GPE = Δ KE
Does the equation already take the opposing gravitational force of Earth into account?
Δ GPE = Δ KE
Yes. The GPE is represents the work done against the gravitational force of the earth. If it weren't for that force, the potential energy wouldn't increase and the kinetic energy wouldn't decrease.
Isnt GPE the work done in bringing a mass from infinity to a point inside a particular gravitational field?
No, it's defined as the work done in bringing a mass from one point to another in a particular gravitational field, plus the PE at the initial point. The value of the PE that we assign to that initial point is completely arbitrary.
You are thinking of the very useful and widely used convention in which we choose to assign zero to the potential energy at infinity. Then the PE at any other point is, as you say, the (negative of) the work done on bringing a mass in from infinity. However, we could just as reasonably choose to assign zero potential to a point at the surface of the earth, and this choice makes the calculations easier if you're working with a rocket launched from the surface of the earth.
Does changing the position of zero position change the formula of GPE?
Yes. If we define GPE = 0 at r = ∞, then
$$GPE = -\frac{GMm}{r}$$
where M is the mass of the earth, m is the mass of the object in question, and r is the distance from the center of the earth. (This applies only above the surface of the earth)
If we define GPE = 0 at r = R, where R is the radius of the earth, then
$$GPE = GMm \left( \frac{1}{R} - \frac{1}{r} \right)$$
You should be able to check for yourself that both formulas give the same result for ΔGPE between two different values of r.
In this case of rocket launch what force is doing work?
Gravity is doing work on the rocket, and the thrust of the rocket motor is doing work on the rocket.
So can the potential energy of the rocket can be calculated by the formula
(Thrust - Gravitational force) * distance
In my book the gain in GPE of the rocket is calculated by -GMm/r which basically came from integrating Gravitational force* distance
Is there any difference?
I am really confused in the case of rocket launching
Potential energy applies when the work it takes to reach a certain position against a particular force does not depend on the path you take to get there. Gravity has this property. Gravitational force is a "conservative field". So it makes sense to talk about the potential energy of gravity. Thrust does not have this property. So it does not make sense to talk about the potential energy of thrust.
No, because the rocket thrust is not a conservative force. You can define potential energy only for conservative forces such as gravity.
What is gravitational potential energy?
Gravitational potential energy is the energy an object possesses due to its position in a gravitational field. It is the energy that an object has by virtue of its height above the ground or any other reference point.
How is gravitational potential energy calculated?
The formula for calculating gravitational potential energy is GPE = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height of the object above the ground or reference point.
What factors affect an object's gravitational potential energy?
The two main factors that affect an object's gravitational potential energy are its mass and its height. As the mass or height of an object increases, so does its gravitational potential energy.
Can gravitational potential energy be converted into other forms of energy?
Yes, gravitational potential energy can be converted into other forms of energy, such as kinetic energy. When an object falls from a height, its gravitational potential energy is converted into kinetic energy as it gains speed.
How is gravitational potential energy related to potential energy?
Gravitational potential energy is a type of potential energy, which is the energy an object has due to its position or state. Other types of potential energy include elastic potential energy and chemical potential energy.
  • Mechanics
  • Mechanics
