Register to reply
Can someone prove this basic identity?
by Synopoly
Tags: basic, identity, prove
Share this thread:
Synopoly
#1
Feb16-14, 01:11 AM
P: 1
x^(1/n) = the nth root of x
(I'd use mathematical notation but I don't really know how I'm new sorry)
Phys.Org News Partner Mathematics news on Phys.org
Heat distributions help researchers to understand curved space
Professor quantifies how 'one thing leads to another'
Team announces construction of a formal computer-verified proof of the Kepler conjecture
Mentallic
#2
Feb16-14, 06:19 AM
HW Helper
P: 3,543
Try raising both sides to the power of n.
lurflurf
#3
Feb16-14, 03:36 PM
HW Helper
P: 2,264
$$x^{\frac{1}{n}}=\sqrt[n]{x}$$
is usually true by definition as those are two notations for the same function.
Mark44
#4
Feb16-14, 06:32 PM
Mentor
P: 21,321
Quote Quote by lurflurf View Post
I agree.
rama
#5
Mar13-14, 06:01 AM
P: 9
same as what mentallic said,the n(and root n) gets cancelled and you are left with the original number
lhs=rhs
jing2178
#6
Mar16-14, 12:19 PM
P: 41
Not so sure that you can just say they are two notations for the same function.
You can define $$\sqrt(x)$$ as that number when multiplied by itself is $$x$$, ie square root is inverse of squaring.
However when dealing with powers you cannot just say well $$x^{\frac{1}{2}}$$ is a new notation for square root, it is the extension of the notation of powers from positive integers to rationals and its interpretation has yet to be determined.
Using the usual rules for powers then
$$x^{\frac{1}{2}}x^{\frac{1}{2}}=x^{{\frac{1}{2}}+{\frac{1}{2}}} =x^1=x$$
it follows that
$$x^{\frac{1}{2}}=\sqrt(x)$$
In the same way you cannot say $$\frac{8}{12}$$ is just another notation for $$\frac{2}{3}$$ without demonstrating their equality
micromass
#7
Mar16-14, 12:49 PM
Mentor
micromass's Avatar
P: 18,334
Quote Quote by jing2178 View Post
it follows that
Every notation must have a definition. How do you define ##x^{1/n}## and ##\sqrt[n]{x}##? Usually, these are defined to coincide.
DrewD
#8
Mar16-14, 01:54 PM
P: 446
I personally would think of the rules for exponent to be defined so that ##\{a^x|x\in\mathbb{R}\}## with ##a## being some constant that is greater than zero and not 1, is a group under multiplication. From this, like jing2178 shows, it is easy to prove that ##x^{1/n}## is a number such that, when raised to the ##n^{th}## power, one gets ##x##. From there it is clear that the notation ##\sqrt[n]{x}## and ##x^{1/n}## mean the same thing (ignoring discussions of principle roots).
It is equally valid to set the definition that those are the same notation and then show that the exponent rules work out to keep the group structure. To me the other way makes me feel happier inside
micromass
#9
Mar16-14, 02:41 PM
Mentor
micromass's Avatar
P: 18,334
Quote Quote by DrewD View Post
That's actually a neat definition
qspeechc
#10
Mar16-14, 03:00 PM
P: 792
$$(x^{1/n})^n = x$$ from which the result follows. E.g. $$\sqrt{4}=2$$ because 2x2=4. $$\sqrt[3]{8}=2$$ because 2x2x2=8.
So if $$(x^{1/n})^n$$ means $$x^{1/n}$$ multiplied by itself n times, and the result gives x, then it must mean $$x^{\frac{1}{n}}=\sqrt[n]{x}$$
Register to reply
Related Discussions
Prove this identity Precalculus Mathematics Homework 4
Prove Identity Precalculus Mathematics Homework 6
Could someone please prove this identity Precalculus Mathematics Homework 2
How to prove this identity? Introductory Physics Homework 1
Trying to prove an identity Calculus 2
