Chiral symmetry, quark condensate and self-energy
In summary, when studying chiral symmetry breaking, only the light quarks are considered as they need to be approximately massless for the symmetry to hold. The masses of these quarks are usually set to zero, and the resulting Goldstone bosons are corrected for their non-zero mass. If the study is done with massive quarks, an explicit chiral symmetry breaking mass term is introduced. The quark condensate is the non-zero VEV of q-bar q, representing a lower energy state with bound quark-gluon states. The concept of "approximate symmetry" and "pseudo-Goldstone bosons" is a useful approximation, but not strictly rigorous. There is no chiral symmetry for heavy quarks due to
grilo
Why in QCD chiral symmetry breaking study only the light quarks are taken into account? And why are their masses usually set to zero, Goldstone bosons are found, and then their masses are corrected by letting the quarks have non-zero mass? What happens if one study this symmetry breaking with massive quarks instead?
And what exactly are quark condensates? I mean, I know they break the chiral symmetry because of their VEV, but what is their meaning?
What is the relation between a particle's self-energy and its mass? (if any)
Thanks in advance.
I just posted a kinda similar question.
Only the light quarks are taken into account because you need them to be approximately massless for there to be chiral symmetry. Also, when you do chiral perturbation theory, you do an expansion in terms of the meson mass - if this is too big, as it would be for the heavier quarks, then your expansion breaks down.
The pions are actually pseudo-goldstone bosons, meaning the broken chiral symmetry isn't exact to begin with so the goldstone modes arent massless. Basically this is allowed because their mass is small enough that they can be thought of as "almost" being goldstone bosons in the sense above - the effects due to the meson mass are small.
When you study the massless theory and find that the pions are the goldstone bosons of the broken chiral symmetry, and then put in realistic up and down masses, you are doing exactly what you said ie studying chiral symmetry with massive quarks. In chiral perturbation theory you do the same thing, that is you introduce a small explicit chiral symmetry breaking mass term.
The quark condensate as you say is the non-zero VEV of q-bar q. It means that it is possible to form a state with lower energy than the empty vacuum by having a sea of bound states of quarks floating about. The empty vacuum then is unstable and will quickly "decay" into a state filled with a bunch of quarks and gluons. This will be the true ground state of the theory, ie the state of lowest energy.
Is this idea of "approximate symmetry" and "pseudo-Goldstone bosons" rigorous? Better put: How rigorous are those ideas?
Also, is there no chiral symmetry with massive quarks? (I'm kinda not used to the idea of a chiral symmetry)
Well, we know of course that chiral symmetry is not exact even for the u and d because of their non-zero masses. But we also have quantiative measures of how wrong we are when we treat an already explicitly broken symmetry as one that gets spontaneously broken. Basically, if the explicity symmetry breaking parameters, ie the quark masses, are small compared to the symmetry breaking scale, then everything is rosy. The errors we introduce are small and we can still get a lot of useful information treating the theory in this way.
If you want more information, this paper is pretty good:
http://arxiv.org/abs/nucl-th/9512029
There is not even an approximate chiral symmetry of the heavy quarks in the sense above that their mass is too large compared to the symmetry breaking scale for this approximation to be useful.
What is chiral symmetry?
Chiral symmetry is a fundamental symmetry in particle physics that describes the behavior of particles with spin. It refers to the idea that the left and right-handed components of a particle should behave the same way, regardless of their spin direction.
What is a quark condensate?
A quark condensate is a phenomenon that occurs in quantum chromodynamics (QCD), the theory that describes the behavior of quarks and gluons. It refers to the formation of a vacuum state where quarks are bound together in pairs, resulting in a non-zero expectation value for the quark field.
What is self-energy in particle physics?
In particle physics, self-energy refers to the energy associated with a particle's interaction with itself. It is an important concept in quantum field theory as it accounts for the mass and stability of particles.
How do chiral symmetry and quark condensates relate to each other?
Chiral symmetry breaking, the phenomenon in which chiral symmetry is spontaneously broken, is thought to be responsible for the existence of quark condensates in QCD. The formation of quark condensates can also lead to chiral symmetry breaking, resulting in the masses of particles such as pions and kaons.
Why are chiral symmetry, quark condensates, and self-energy important in particle physics?
These concepts are important in understanding the behavior and properties of particles at the fundamental level. They play a crucial role in our current understanding of the Standard Model of particle physics and are essential in predicting and explaining various phenomena observed in particle accelerators and experiments.
