Significance of the Lagrangian
In summary, I don't think the Lagrangian is as simple as it is made out to be. There may be more to it than meets the eye.
  • #36
Francesco,
Thanks a lot for your explanation. I'll have to go over it. I started school last monday and I'll be also teching two labs. So I'll be kind of busy. I am taking mechanics (we'll use Marion & Thornton and Goldstein) and Matehmatical methods (Arfken and also Boas).
I found in Goldstein (second edition) a short explanation on the Legendre transformation (pg.339). Lanczos talks a lot about it. With respect to my comment, I didn't mean that I was looking for an alternative explanation to the Legendre transformation. I just meant that I want to go one step at a time, and I am lookin for more insights into the Lagrangian before I explore the transition to Hamiltonian mechanics.
I guess your post may be giving me that insight I was looking for, but I'll have to go over it several times and think about it.
My mechanics professor told us yesterday that we are going to be solving a lot of problems, that that's why we are physicists. I dissagree with that and I am a little dissapointed. I am into physics because I want to gain a better understanding of how the universe works and not just to solve problems.
Well, that was really off the subject of this thread but I was feeling a little frustrated and felt like telling someone about it.
I am affraid that now that I'll be studying mechanics, I'll be so busy working out problems that i won't have enough time to explore and gain a deep understanding of the fundamental concepts.
I hope once I get organized with my lab teaching I'll have more time to do some study on my own.
Thanks again Francesco,
-Alex-
  • #37
alexepascual said:
Turin:
Your observation is very interesting. I didn't think about inflection points. Woundn't this support my point that Hamilton's principle does not represent an attempt by Nature to obtain an economy in a certain quantity?.
Since any function which yields the proper equations of motion can be and is called a Lagrangian, one has a lot of choice when writing down a Lagrangian for a specific system.
I have a suspicion that when actually writing the Lagrangian in the form L = T-V, the principle of least action actually is a minimization principle. But I don't have a proof of this, and my intuition might well be wrong. I would be interested in seeing a counterexample, if anyone has one to offer, though.
Using Newtonian mechanics, for instance, with T=.5 m v^2, I think it's fairly obvious (?) that the intergal of L*dt will be increased by making the velocity arbitrarily high.
  • #38
Pervect,
It's been a while since your post. I have been really busy with school (including classical mechanics). It looks like since I started school I stopped learning, as we just do a lot of algebra an there are no discussions on what it all means.
With respect to your idea about T-V being minimized, I think I have read some place that possible paths may be obtained by maximizing the lagrangian, but that that would be kind of an "unstable" path.
I visualize a ball running downhill on a ridge of a mountain. Most of the time, the ball will fall over the side of the ridge. But build the mountain (Disneyland type) and design the ridge with a very particular shape, it might be possible for the ball to stay on the ridge. (in order for this to work the ridge woud habe to be rounded). I realize we have a probelm with constraints here, but I think it roughly illustrates a case. I have not worked the problem out to see if the integral of the Lagrangian really is maximum for the path that goes along the ridge though. If it isn't then my example won't be valid.
I was just trying to think about it and I see that something that complicates the picture is that In Hamilton's principle we are going from one point to another fixed point. In this case, when the ball falls on the side of the ridge, it ends up somewhere else. But I guess you could have gutters on both sides of the ridge running prallel to the ridge and having these gutters merge with the top of the ridge at the end of the path. If the ball fell on one of the gutters from the start, it is clear that that path on the bottom of the gutter would have the lowest hamiltonian action. So it is possible that if the ball follows the ridge it will have maximum action.
  • #39
alexepascual said:
I have the gut feeling that there is more to it than meets the eye.
the significance of the Lagrangian is its inherent natural form for a local gauge invariance. The Hamiltonian is not locally gauge invariance leading to problems with infinities which require renormalizations.
  • #40
Thanks Antonio,
I'll keep that in mind. I know that gauge invariance is a very important topic, but my exposure to it in undergraduate studies has been very brief. I think I only saw it in E&M and I don't remember much about it except that the vector potential had something to do with it.
I am looking forward to studying gauge invariance in connection with classical mechanics.
Thanks again for your input.
-Alex-
  • #41
To me it appears to be quite similar to the law of conservation of energy.
You take the differences of T and V all over the path and then sum all the values up. For the actual path, they have to be zero since energy didn't come from anywhere and didn't go anywhere.
spacetime
www.geocities.com/physics_all/index.html
  • #42
Spacetime,
Your explanation sounded appealing because in the Lagrangian approach, conservation of energy is actually assumed. But it fails when you realize that the integral of L=T-V does not necessarily vanish but assumes a stationary value with respect to nearby paths. Let's say we have a particle going from point A to point B in straight line and the potential is zero. Then the Lagrangian would contain only the kinetic energy and the integral would clearly not be zero.
What do you think?
  • #43
Yeah alexepascual
you are right. I am trying to figure it out. But I think it has something to do with energy conservation. Let me see if I can find an answer.
spacetime
  • #44
While you are at it, let me give you some additional information.
I have seen two derivations of Lagrange equations of motion. One starts from Hamilton's principle, which already uses the concept of the Lagrangian function, and the starts from D'Alembert's principle and in that case the Lagrangian comes out of the equations after some manipulation. The first procedure, (from Hamilton's principle) does not add any intuitive understanding as it presuposes something which we would like to understand better (The Lagrangian function and Hamilton's principle). So this approach in a way says: If we accept Hamilton's principle as true, then all these other things (such as the Lagrange equations of motion and Newton's laws) can be derived.
The other approach (from D'Alemebert's principle) uses the idea of forces of inertia which is intuitive enough. The problem I found is that the derivation gets to a point where it uses an integration by parts. At that point the argument becomes hidden in the algebra (or calculus) and fails to be easily followed on an intuitive basis. That is, you can follow on paper and verify that all the algebraic manipulations are correct, but I at least loose track of what each thing means in physical terms so that in the end I do get the Lagrangian function and Hamilton's principle, but can't explain intuitively how I got there.
  • Classical Physics
  • Classical Physics
  • Classical Physics
