What Is the Equilibrium Angle of a Current Loop in a Magnetic Field?
In summary: Your Name]In summary, a square loop of wire carrying a current is placed in a horizontal magnetic field, causing the loop to rotate. The problem asks for the angle at which the loop will reach equilibrium. The torque from the spring and the magnetic field must be equal and opposite for the loop to reach equilibrium. To solve for the angle, you must correctly identify the distance from the axis of rotation to the point where the spring is attached, and use Hooke's law to find the stretch of the spring.
futurepocket
A square loop of wire with side 0.60 m carries a current of 9.0 A as shown in the figure (http://img847.imageshack.us/i/springquestion.jpg/). When there is no applied magnetic field, the plane of the loop is horizontal and the nonconducting, nonmagnetic spring (k = 550 N/m) is unstretched. A horizontal magnetic field of magnitude 1.3 T is now applied. At what angle theta is the wire loop's new equilibrium position? Assume the spring remains vertical because theta is small. (HINT: Set the sum of the torques from the spring and the magnetic field equal to 0)
tau = NIABsin(theta)
tau = rFsin(theta)
Well, the hint says it all, except I can't seem to figure out the torque from the spring. I assume that since F = -kx, we put that in for the force for the torque, the 'r' is the distance from the axis of rotation to the spring (which I am assuming is 0.6 / 2 since it says its a square but the image doesn't look like a square). Unfortunately, I don't get the right answer when I do that because the sin(theta) can just cancel out on both sides.
Therefore, I considered that we assume the spring stays vertical, so sin(theta) for the torque from the spring doesn't exist.
So we get:
-rkx + NIABsin(theta) = 0
but we don't know 'x', the stretch of the spring. So I used Newton's laws, and summed up the forces and figured out that the force due to spring must be equal to the magnetic force on the spring... so I did that, and still didn't get the right answer. I am totally lost, any help?
Thank you for your post. It seems like you are on the right track with your attempt at a solution. Here are a few suggestions that may help you to arrive at the correct answer:
1. Remember that torque is a vector quantity and it has both magnitude and direction. When you write the equation for torque, make sure you include the direction of the torque. In this case, the torque from the spring will have a negative sign since it is acting in the opposite direction of the magnetic torque.
2. The distance 'r' in the torque equation is the distance from the axis of rotation to the point where the force is applied. In this case, it is not the distance from the axis to the spring, but rather the distance from the axis to the point where the spring is attached to the loop. You can use the Pythagorean theorem to calculate this distance.
3. To find the stretch of the spring, you can use Hooke's law, F = -kx, where 'F' is the force from the spring, 'k' is the spring constant, and 'x' is the stretch of the spring. You already know the value of 'k' and you can calculate the force from the spring using the equation you mentioned in your post (since you know the value of the magnetic force). This will give you the value of 'x', which you can then use to calculate the angle theta.
I hope this helps. Good luck with your problem!
What is torque in a current loop?
Torque in a current loop is the rotational force that is exerted on a loop of wire when a current is passed through it.
How is torque in a current loop calculated?
The torque in a current loop is calculated by multiplying the magnetic moment of the loop by the magnetic field strength.
What factors affect the torque in a current loop?
The torque in a current loop is affected by the strength of the magnetic field, the size and shape of the loop, and the current passing through the loop.
What is the direction of the torque in a current loop?
The direction of the torque in a current loop is perpendicular to both the direction of the magnetic field and the direction of the current flowing through the loop.
What are some practical applications of torque in a current loop?
Some practical applications of torque in a current loop include electric motors, generators, and electromagnets. It is also used in devices such as galvanometers and compasses.
