Hydrogen orbits, magnetic field, orbit-spin interaction
In summary, there is no universally acknowledged value for the magnetic moment of H-1, with various values ranging from 0.3 to 0.6 Tesla. Additionally, the axis of electron spin and orbital angular momentum cannot be precisely defined in quantum mechanics, and the electron's spin is equally likely to be in any direction in the ground state. Spin-orbit coupling can also affect the electron's spin orientation. The magnetic field created by the electron's intrinsic spin is not typically measured, but can be calculated using quantum electrodynamics in more complex systems.
simpatico
47
In different (scientific) sites I find different values for MF of H-1 ranging from 0.3 to 0.6 Tesla. Isn't there a generally acknowledged value?
what about H-2 and H-3 ?
using the general formula I get 1/ 8 tesla, that formula it not valid?
can the axis of electron spin be oriented in any direction,(without external influence)an be
or it can be only anti-parallel to orbit axis?
(again: in many (scientific) applets the show axis at a tilt)
To start off with, let's assume the nucleus makes no contribution to spin. In reality, it will, but let's hope it is effects are shielded by the electron or its effects are comparatively small.
So now we just have the one electron. Generally, it can have many possible values for its orbital angular momentum. But usually it will fall into the lowest energy state. This state has zero orbital angular momentum.
So now, we just have the intrinsic spin of the electron, which is hbar/2. This gives the electron an electronic spin magnetic moment of about (plus or minus) 1.4*(10^-5) eV/T.
So when there is an external magnetic field of one Tesla applied to the atom, an energy difference of twice the number mentioned will separate the two states.
They usually talk about the magnetic moment of the electron because it is the energy difference which is usually measured (not the magnetic field itself). If you wanted to know about the magnetic field created by the atom, I don't know the answer, that's not something I've come across in basic quantum mechanics. If I had to guess, I'd say there isn't a nice, classical picture of magnetic field lines flowing through space. I suppose QED is the proper description for a magnetic field in quantum mechanics.
Even the idea of the electron's spin axis is a bit tricky. It can never be perfectly defined in a single direction, but you can define the component of spin in a given direction. (which is what happens when we apply an external magnetic field). So then you can imagine the axis of the electron's spin to lie somewhere on a cone of possible axis.
For a hydrogen atom in its ground state, when no external magnetic field is applied, the electron's spin will be equally as likely to be in any direction.
But when the electron is orbiting around the nucleus, there is another effect I have not yet mentioned. It is spin-orbit coupling, which can be roughly explained as an effective magnetic field at the electron, which means the different spin states will have different associated energy levels.
BruceW said:
1)If you wanted to know about the magnetic field created by the atom, I don't know the answer.
2)So then you can imagine the axis of the electron's spin to lie somewhere on a cone of possible axis.
3) the electron's spin will be equally as likely to be in any direction.
1)If I got it right, you don't know it but it is known
Can't we calc it by the rule of MF in a loop?
Once I found the value for H-1 can I automatically deduce the other values (H-2,H-3...)
2, 3)That is my problem:
inside the orbit we a strong magnetic field of say 0.4 T. No external influence !
shouldn't the e-axis be always antiparallel to MFaxis, that is, rotating like a wheel on a road? (of course it may wobble a bit.)
3)it shouldn't be any direction, because it takes energy ,to deflect an e- from the antiparallel direction
1) What is usually important is the magnetic moment of the electron. This tells us the energy difference of different electron states. The magnetic moment due to intrinsic spin cannot be calculated by classical rules (although the rules are similar in some ways). If the atom is not hydrogen, approximation can be used to find the energy levels.
If you want to know the magnetic field created by the electron's intrinsic spin, this implies you want to find out what effect this has on other particles. But such experiments are a lot more tricky (I think) which is why its not taught as one of the basics of quantum physics. As I said before, I guess quantum electrodynamics has the answer. But keep in mind that the quantum version of electrodynamics is very different from the classical version.
2,3) The axis of orbital angular momentum is also not defined precisely. Quantum mechanics does not allow it. Even if we do have a precisely defined axis (i.e. in the case of an external magnetic field), the electron's spin cannot take an exact direction because this state is not allowed by quantum mechanics.
3)In the ground state, the electron has no orbital angular momentum. its not moving, so there is no spin-orbit interaction.
I would respond by saying that the magnetic field of hydrogen atoms is influenced by a variety of factors, including the strength of the external magnetic field, the orbital and spin angular momentum of the electron, and any interactions between the orbit and spin. This can lead to variations in the measured magnetic field for hydrogen atoms. It is important to note that there is not one universally accepted value for the magnetic field of hydrogen, as it can vary depending on the specific conditions and measurements being taken. The magnetic field of hydrogen-2 and hydrogen-3 may also differ from hydrogen-1 due to their different nuclear structures. As for the orientation of the electron spin, it can be influenced by external factors but also has a tendency to align anti-parallel to the orbital axis. However, in certain situations, the axis of electron spin may be tilted or oriented in a different direction. The general formula you used may not be applicable in all cases and it is important to consider the specific conditions and factors at play when determining the magnetic field and spin orientation of hydrogen atoms.
1. What are hydrogen orbits?
Hydrogen orbits refer to the paths that an electron takes around the nucleus of a hydrogen atom. These orbits are governed by the laws of quantum mechanics.
2. How does the magnetic field affect hydrogen orbits?
The magnetic field can cause the electron in a hydrogen atom to spin and move in a different direction, altering its orbit. This is known as the Zeeman effect.
3. What is orbit-spin interaction in hydrogen?
Orbit-spin interaction in hydrogen refers to the interaction between the orbital motion and the spin of the electron. This interaction is responsible for the fine structure of the energy levels in a hydrogen atom.
4. How does the spin of the electron in hydrogen affect its orbit?
The spin of the electron in hydrogen does not directly affect its orbit, but it does contribute to the overall energy levels of the atom through the orbit-spin interaction.
5. How is hydrogen used to study magnetic fields?
Hydrogen is often used as a probe to study magnetic fields as its energy levels are sensitive to changes in magnetic fields. By analyzing the changes in the energy levels, scientists can determine the strength and direction of a magnetic field.
  • Electromagnetism
