When do they emit α, β+ or β- particle to become more stable?
In summary, α-particles are emitted when a heavy nuclide has too many neutrons and protons, causing it to become more stable by emitting 2 neutrons and 2 protons. This is known as alpha decay and is represented on a graph called the 'line of stable nuclides'. Nuclides that are plotted away from this line have a higher probability of being unstable and radioactive. The number of neutrons and protons in a nuclide is important in determining its stability, with heavier nuclides requiring more neutrons to maintain stability. While it may not be a perfect explanation, this information can be helpful in understanding the behavior of nuclides.
bsmm11
From what I've seen in the textbook, β- is emitted when there is an excess neutrons and β+ is emitted when there is a short of neutrons. Then when does an α-particle emitted?
An important graph to use in this explanation is Number of neutrons against number of protons for the nuclides. Are you familiar with it?
For light nuclei the number of neutrons is more or less equal to the number of protons and therefore forlight nuclei the line is more ore less at 45 degrees. The line that fits the points is known as the 'line of stable nuclides', nuclides on this 45degree line are stable.
Nuclides plotted away from this line have increased probability of being unstable and therefore radioactive. The 3 isotopes of Carbon... C12, C14 and C10 are perfect examples to illustrate stability (C12) beta- decay (C14) due to too many neutrons and beta+ decay (C10) due to too many protons... you have recognised this.
Higher up the curve more neutrons need to be in the nucleus as the number of protons increases and this means that the curve tends to become steeper.
It is now not so easy to determine how nuclides away from the line will behave but in general a heavy nuclide , by emitting 2 neutrons and 2 protons (an alpha particle) will become more stable ( the resulting nuclide will be 'closer to the line'
Not a perfect explanation but, depending on your knowledge, I hope this helps.
1. When do atoms emit α particles?
Atoms emit α particles when they undergo alpha decay, which occurs when the nucleus of an atom has too many protons and neutrons, making it unstable. The alpha particle, also known as a helium nucleus, is released to reduce the number of protons and neutrons in the nucleus, making it more stable.
2. What causes atoms to emit β+ particles?
Atoms emit β+ particles, also known as positrons, when they undergo beta plus decay. This occurs when a proton in the nucleus transforms into a neutron, releasing a positron and a neutrino. This process helps to stabilize the nucleus by reducing the number of protons.
3. Why do atoms emit β- particles?
Atoms emit β- particles, also known as electrons, when they undergo beta minus decay. This happens when a neutron in the nucleus transforms into a proton, releasing an electron and an antineutrino. This process helps to stabilize the nucleus by reducing the number of neutrons.
4. How do atoms decide which type of particle to emit?
The type of particle emitted by an atom is determined by the ratio of protons to neutrons in the nucleus. If the nucleus has too many protons, it will emit α or β+ particles to reduce the number of protons. If it has too many neutrons, it will emit β- particles to reduce the number of neutrons. This helps to balance the ratio and make the nucleus more stable.
5. Can atoms emit more than one type of particle?
Yes, atoms can emit more than one type of particle in a process called multiple decay. This often occurs when the nucleus is very unstable and needs to release multiple particles to become more stable. For example, an atom may emit an α particle and a β- particle simultaneously to achieve a more balanced ratio of protons to neutrons.
  • Nuclear Engineering
