Understanding the Boiling Point: Thermodynamic Proof
In summary, at the boiling point of a liquid, adding heat can either increase its temperature or cause a phase change into vapor. Experimentally, liquids remain at the boiling point until the phase change is complete. This is due to the fact that the free energy of the liquid is lower below the boiling point, while the free energy of the vapor is lower above the boiling point. To achieve the lowest free energy, the substance must convert part of the liquid to vapor. This can be proven from the laws of thermodynamics by considering the different rates at which free energy changes with temperature for different phases. However, to derive the actual dependence of free energy on temperature, statistical mechanics is needed as thermodynamics alone is insufficient.
Termotanque
34
If we add a small amount of heat δq to a liquid at its boiling point Tb, it could either increase its temperature a small amount dT = δq/Cv, or suffer a phase change into vapor.
Experimentally, we see that liquids remain at Tb until the phase change is complete, and only then continue increasing their temperature. Why is this?
I want to prove this macroscopically, that is, from thermodynamics, but I don't know where to start. Any leads?
Science news on Phys.org
The way you do this is by looking at free energy. Bellow the Tb, the free energy of a liquid is lower. Above, free energy of gas is lower. At Tb, the free energy of the two phases is the same. So to get an absolute lowest free energy, the substance must convert part of liquid to vapor in response to added energy, until there is no more liquid left.
Can what you just said be proved from the laws of thermodynamics, without looking up ΔG values on tables?
Like I said, if you take for granted that different phases have different rate at which free energy changes with temperature, that's all you need to prove that phase transition happens at a specific temperature for pure substance.
If you want to derive the actual dependence of free energy on temperature, then you need statistical mechanics. As far as I know, thermodynamics by itself is insufficient.
I would like to start by stating that boiling point is a fundamental property of a substance and is determined by its thermodynamic properties. It is the temperature at which the vapor pressure of a liquid equals the atmospheric pressure surrounding it.
Now, let's consider the scenario where we add a small amount of heat δq to a liquid at its boiling point Tb. This heat energy is used to overcome the intermolecular forces holding the liquid molecules together and facilitate the phase change from liquid to vapor. This process is known as vaporization and it requires a significant amount of energy.
According to the first law of thermodynamics, the heat added to the system (liquid) is equal to the change in internal energy (ΔU) and the work done (W) by the system. Mathematically, it can be expressed as δq = ΔU + W.
In this case, as the liquid is at its boiling point, there is no change in temperature (dT = 0) and therefore, there is no change in internal energy (ΔU = 0). This means that all the heat energy added to the system is used to do work (W) in the form of overcoming intermolecular forces and facilitating the phase change from liquid to vapor.
Hence, experimentally, we see that liquids remain at their boiling point until the phase change is complete because all the added heat energy is being used for the phase change process and not for increasing the temperature. Once the phase change is complete, any additional heat energy added will result in an increase in temperature, as expressed by the equation dT = δq/Cv, where Cv is the heat capacity at constant volume.
In conclusion, the understanding of boiling point and its behavior can be explained by thermodynamics, specifically the first law of thermodynamics. By considering the change in internal energy and work done, we can see why liquids remain at their boiling point until the phase change is complete. Further research and experimentation can help us gain a deeper understanding of this phenomenon.
1. What is the boiling point and why is it important?
The boiling point is the temperature at which a substance changes from a liquid to a gas. It is important because it allows us to understand how different substances behave under certain conditions, and it is also a key factor in various industrial processes and everyday activities such as cooking and cleaning.
2. How is the boiling point determined?
The boiling point is determined by the intermolecular forces between the particles of a substance. These forces can be affected by factors such as pressure, altitude, and the presence of other substances. As these factors change, the boiling point of a substance can also change.
3. What is thermodynamics and how does it relate to boiling point?
Thermodynamics is the study of energy and its transformations. In the context of boiling point, thermodynamics helps us understand the relationship between temperature, pressure, and energy in a system. It provides a scientific explanation for the changes that occur during boiling and how they are affected by different factors.
4. Can the boiling point of a substance be predicted?
Yes, the boiling point of a substance can be predicted using thermodynamic principles and mathematical equations. However, it may not always be accurate as it can be affected by external factors such as impurities or changes in atmospheric pressure.
5. How does understanding boiling point benefit us?
Understanding boiling point allows us to make informed decisions in various fields such as chemistry, biology, and engineering. It also helps in the development of new products and technologies, as well as in the improvement of existing processes. Additionally, it allows us to better control and manipulate substances for various purposes.
  • Thermodynamics
