If the solenoid covers the whole length of a shake flashlight, will it light up?
In summary: EMF induced by the magnet moving freely in space. In other words, the EMF induced by the solenoid moving through the magnet is always going to be less than the EMF induced by the magnet moving freely in space.
Spock2230
In a Faraday flashlight, a magnet is shaken to and fro in a solenoid to induce an EMF and thus current. Something like this:
http://express.howstuffworks.com/gif/autopsy-flashlight-tube.jpg
If the solenoid were to cover the entire length of the interior, and thus the magnet is only moving within the solenoid, will there still be an effective magnetic flux linkage to induce a current? Why or why not?
I understand that Lenz law states that a current is produced because the solenoid opposes the motion of the magnet, by setting up an like pole to repel it away. So if the magnet is contained entirely within a solenoid, what will happen? Is it still able to generate an EMF?
Thanks for your help. :)
Science news on Phys.org
Yes there will still be an induced emf and thus current - owing to the finite length of that solenoid a differential flux linkage always exists for two-an-fro magnet motion. But will lessen as the solenoid grows ever longer. [That assumes solenoid length extends equally beyond the motion range of magnet. If magnet motion range continues to match solenoid spatial extent, the net emf will be roughly unchanged in maximum magnitude (bounce at ends unchanged), but is overall less efficient since the period will increase hence less voltage pulses per second.]
Answer is the same since the question is the same! :rolleyes:
Hi Q-reeus, thanks for your reply.
I'm just a high school student, so I'm not very sure what a 'differential flux linkage' is. Could you please tell me more?
You see, I was discussing with my physics teacher about this, and he's contention is that, since the magnet is entirely contained in the solenoid, the solenoid cannot set up a like pole to oppose the magnet's motion, and hence no magnetic work can be done to induce an EMF, so the LED won't light up.
I'd like to think of one long solenoid as multiple short solenoids, and so each part of the solenoid is still able to set up a repelling pole to oppose the motion for work to be done. I'm not really sure about this.
Thanks. :)
A pleasure. :smile:
It simply means that, at each furtherest excursion of that sliding magnet, the number of magnet flux lines linking through all the coil turns of the solenoid, is less than when that magnet is at the center of solenoid. A little difficult to calculate exactly, but unless that solenoid is either infinitely long, or wraps around on itself to form a toroid, there will be such a differential.
He is using an energy argument in effect - based on an infinitely long solenoid and finite excursion magnet motion. And that's valid if, as I have also earlier done, we neglect possible phase delay effects and assume 'instantaneous' flux linkage - a very good approximation for shaking-magnet device.
No that's not valid - intermediate 'poles' will exactly cancel leaving only the end 'poles' to consider.
[Edit: Just a clarification from your #1: "I understand that Lenz law states that a current is produced because the solenoid opposes the motion of the magnet, by setting up an like pole to repel it away."
That is not actually correct although there is such a correspondence in respect of currents opposing motion. It is the Maxwell-Faraday law that determines whether an emf in circuit is produced]
Hi Q-reeus, thank you very much for your time and the detailed explanation.
I understood the differential equations, but I don't get why d(B-field) cannot be 0. Could you take a look at this picture please?
This is what my physics teacher drew, to explain. The EMF induced by either sides are supposed to cancel out, thus d(B-field) = 0, and no EMF or current induced.
Well, it does seems quite reasonable, could you please explain what is wrong with it?
Thanks again for your patience and time.
You have been very friendly and helpful, leaving me with an excellent impression of this forum (I'm new here), and I'm encouraged to participate here more actively in the future. :smile:
You are probably referring to the B term in integral form expression. That is not B field but magnetic flux: the integrated amount of B field threading through a given area which the circuit encloses. No time-varying flux linkage = no emf. On the other hand, there is a finite ∇×E 'at a point' because it relates to rates-of-change not absolute value around a circuit.
[STRIKE]Just guessing for now. I'd say it involves having a closed circuit lying just outside of a region containing a magnetic field (say a very long magnetized rod). There is no appreciable threading flux through circuit, but if the flux in the rod or whatever is time-varying, it generates a circular E field that acts on the circuit. If the circuit has a sector shape, it becomes clear why cancellation applies to the inner and outer curving sides - E varies as 1/r thus voltage induced in each curved side are equal in strength but cancel direction wise as far as circulation around the loop. Straight radial sides intersect E field normal to their direction so no voltage acts in them. Thus net emf is zero, in keeping with Faraday's law of induction. Is that about right? [No - but leaving it now anyway!][/STRIKE]
OK - guessing over. Tried three different browsers and finally had luck with Google Chrome - others didn't show any image! So basically it gets back to scenario in #1. It's a fair/crude approximation depending on pov. It's true the net flux-linkage will be fairly small when both magnet ends are well inside of a long solenoid. However if that magnet is moving there will always be some net change in flux-linkage except at dead-center. You can see this by noting magnet approximates to a dipole and since the axial field of a dipole drops off as 1/r3, there is a difference in threading flux through solenoid ends - and thus through solenoid as a whole in general. Voltage in coil will be fairly 'spiky' as large changes in threading flux will occur only when magnet end(s) exits/re-enters the coil. In that sense he is right.
Glad you feel that way Spock2230 and hope your stay is pleasant and beneficial! :wink:
1. How does a solenoid work?
A solenoid is a type of electromagnet that consists of a coil of wire wrapped around a metal core. When an electric current flows through the wire, it creates a magnetic field that can be used to move objects or generate electricity.
2. What is a shake flashlight?
A shake flashlight is a type of flashlight that does not require batteries. Instead, it uses the motion of shaking the flashlight to generate electricity through a process called electromagnetic induction.
3. Can a solenoid power a shake flashlight?
Yes, a solenoid can be used to power a shake flashlight by converting the mechanical energy from shaking into electrical energy through electromagnetic induction. The solenoid acts as a generator, producing electricity to power the flashlight.
4. How does a solenoid cover the whole length of a shake flashlight?
A solenoid can cover the whole length of a shake flashlight by being wrapped around the metal core of the flashlight. This allows for maximum contact between the solenoid and the core, optimizing the production of electricity through electromagnetic induction.
5. Will the shake flashlight light up if the solenoid covers the whole length?
Yes, the shake flashlight will light up if the solenoid covers the whole length. The solenoid acts as a generator, producing electricity through electromagnetic induction when the flashlight is shaken. This electricity powers the light source of the flashlight, causing it to light up.
13K
10K
