Solvable group: decomposable in prime order groups?
In summary, a solvable group is a group with a normal series where each factor is Abelian. For finite groups, this means that all composition indices are prime numbers. This is a special case because for infinite groups, there may not be a normal series where the subgroups are maximal. This is illustrated by the fact that the group of integers cannot have a composition series as it is not simple.
nonequilibrium
1,439
Hey!
From MathWorld on solvable group:
A solvable group is a group having a normal series such that each normal factor is Abelian. The special case of a solvable finite group is a group whose composition indices are all prime numbers.
But why is that a special case? The way I understand it: the normal series can always be made such that all composition factors are simple, but then the composition factors are both simple and Abelian, and hence (isomorphic to) [itex]\mathbb Z_p[/itex], i.e. the composition index is p (= prime)...
It is only for a finite group that you are guaranteed to have a composition series. For an infinite group, there may be no normal series where the subgroups are maximal. For instance, ##\mathbb{Z}## cannot have a composition series, since it is not itself simple (every subgroup of ##\mathbb{Z}## is itself isomorphic to ##\mathbb{Z}##).
Thank you! I see, so for a finite group the "special case" is always true; that clarifies!
1. What is a solvable group?
A solvable group is a type of mathematical group that can be broken down into simpler, smaller groups through a series of normal subgroups. This process eventually leads to a group that is considered to be "simple" and cannot be broken down further.
2. What does it mean for a solvable group to be decomposable in prime order groups?
A solvable group is considered to be decomposable in prime order groups if it can be broken down into a series of subgroups, each with prime order. This means that the group can be reduced to its basic building blocks, which are prime order groups.
3. How is the solvability of a group determined?
The solvability of a group can be determined by examining its composition series, which is a series of normal subgroups that lead to a simple group. If there exists a composition series where each subgroup is an abelian group, then the group is considered to be solvable.
4. What are some examples of solvable groups?
Some examples of solvable groups include abelian groups, symmetric groups, and alternating groups. Other examples include certain types of matrix groups and certain types of dihedral groups.
5. What is the significance of studying solvable groups?
Studying solvable groups is important in understanding the structure of groups and their subgroups. It also has applications in various areas of mathematics, such as number theory and geometry. Additionally, the concept of solvability has implications in other fields, such as physics and chemistry.
  • Linear and Abstract Algebra
