What does the probabilistic interpretation of QM claim?
In summary, the conversation discusses the probability interpretation of quantum mechanics and how it relates to observable operators and measurements. The probability interpretation states that the probability of observing a particular eigenvalue is equal to the square of the state function for that eigenvalue. However, this interpretation does not determine which operators can be measured, as this is a matter of theoretical and experimental developments. The conversation also delves into the issue of measuring position and momentum, and how quantum uncertainty rules out continuity in position. The example of the double-slit experiment is used to demonstrate the wave-mechanics interpretation of position and momentum in quantum mechanics. The conversation ends with a mention of experiments done in strong magnetic fields and how they measure position and momentum in particle tracks.
A. Neumaier
Insights Author
8,595
4,620
I collect here info from another thread, to have a more focussed discussion.
A. Neumaier said:
The probability interpretation says that _if_ you can set up an experiment that measures a self-adjoint operator for a system in state psi then the probability of observing the k-th eigenvalue is psi^* P_k psi, where P_k is the projector to the k-th eigenspace. It says _nothing_ at all about which particular operators are observable in this sense.
Everything beyond that is interpretation, and hence (at the current state of affairs) a matter of philosophy. In particular, which operators can be measured is not part of the probability interpretation but a matter of theoretical and experimental developments.
Regarding what is arbitrarily _precisely_ measurable, there is a no go theorem by Wigner (I can give references if you want to check that) that states that _only_ quantities commuting with all additive conserved quantities are precisely measurable. The position operator is not among these.
Nobody comparing QM with experiments is making use of this particular assumption.
''this particular assumption'' refers to the assumption that |psi(x_1,...,x_n|^2 is the probability density of observing simultaneously particle k at position x_k (k=1:N).
A. Neumaier said:
It is stated in the beginning as an interpretation aid without proof, and never taken up again in the context of real measurements where the claim would have to be justified. It is very common to make this sort of idealized assumption to get started; but once the formalism is established, this assumption is never used again.
For example, Landau & Lifgarbagez begin in Section 2 of their Vol. 3 with such a statement, but immediately replace it in (2.1) and (3.10) by the more correct version about the interpretation of the expectation value <K> = Psi^* K Psi, where K is an arbitrary observable (linear integral operator) depending on the form and values of the measurement. From then on, only the latter interpretation is used; never the fictitious, idealized introductory remark.
And it cannot be different, since quantum mechanics is used in many situations where the state vectors used in the formalism have no interpretation as a function of position - the whole of quantum information theory and the whole of quantum optics belonging to this category.
Avodyne said:
For nonrelativistic particles, absolutely everyone comparing QM with experiments does make use of the wave-mechanics interpretation of [itex]|\psi(x)|^2[/itex] as a probability density.
Please show me a comparison with experiment that does this.
Nonrelativistic particles have no different interpretation than relativistic ones.
Particle detectors respond to the momentum of a particle, not to its position.
Scattering experiments are interpreted in the momentum picture. Nobody is interested in the position of particle tracks, only in their momentum (which tells about masses).
meopemuk said:
Yes, this is true. QM does not talk about the specifics of observations and measuring devices. For example, P_k can be a projection on the k-th eigenvalue of the position operator.
It could be this _only_ if you can prepare an experiment that realizes such a P_k. But this is a matter of experimental technique and not one about the interpretation of quantum mechanics. But there are no such operators since the spectrum of position is continuous.
meopemuk said:
Yes, this is true. QM does not talk about the specifics of observations and measuring devices. For example, P_k can be a projection on the k-th eigenvalue of the position operator. Then psi^* P_k psi is the probability (density) for measuring position k in the state described by psi. QM tacitly assumes that some ideal precise measuring device can be constructed, which does exactly that
No. This unrealistic assumption is needed _only_when one wants to insists on a probability density interpretation of |psi(x)|^2. And for the position representation of an N-particle state, one would need an even more ideal precise measuring device that can measure the simultaneous presence of N particles in N different, arbitrarily small regions
covering the size of an uranium atom (N=92), say.
This is ridiculous - such measurement devices are impossible!
Whereas the form in which I stated the probability interpretation assumes nothing. it makes claims only for those projectors that are actually realizable. it is therefore much more realistic.
Quantum uncertaqinty rules out continuity in position.
_PJ_ said:
Quantum uncertainty rules out continuity in position.
Wigner's theorem (p.298 in: Wheeler & Zurek, Quantum theory and measurement, Princeton 1983) even rules out projective measurements of a particle being in a given region, since the corresponding projector does not commute with all additive conserved quantities.
Would you then agree that [tex]|\psi(p)|^2 [/tex] is the probability (density) of finding the particle with momentum p? Of course, [tex]\psi(p) [/tex] is the wave function in the momentum representation.
Eugene.
Avodyne said:
For nonrelativistic particles, absolutely everyone comparing QM with experiments does make use of the wave-mechanics interpretation of as a probability density.
The double-slit experiment is a good example. See Feynman's Lectures on physics.
Eugene.
I also reproduce what I wrote on this point in the other thread:
Experimenters have been recording particle tracks in position space with cloud chambers, bubble chambers, spark chambers, and drift chambers for many decades. The experiments are typically done in a strong magnetic field, which allows for measuring the momentum of charged particles by measuring the curvature of a track in position space. Modern experiments also have calorimeters at the boundaries of detectors that measure energy deposited; this does give a direct measurement of a particle's energy, but not its momentum.
For some recent pictures of particle tracks in position space from the LHC see
http://public.web.cern.ch/press/pressreleases/Releases2010/PR15.10E.html [Broken]
I certainly believe that the superposition principle even applies when you can consider a quantum object in a definite state (Quantum Enigma, pg. 191; Entanglement, pg. 79; Absolutely Small, 371-372). So if it is in a definite state (this is obviously determined through what you see) then you can also consider all the other states it COULD be in as potentials (as you cannot see those other states). Of course, we can only talk about what we see. Perhaps those potentials ARE really real too, we just can't see them? But such questions are pointless as what we work with is from what we see.
The Mental Universe -> http://henry.pha.jhu.edu/The.mental.universe.pdf
When the particles in these chambers pass the medium, they ionise their surroundings. This interaction itself causes a collapse of the wafefunction.
The resultant ionised particles of media are what is detected, the momentum can be calculated as can the energy of the particle, but since there is delay between the initial ionisation and the detectoin of the ionised media particles, the initial particle is no longer in that state and cannot be correlated with the measurement of its energy (velocity).
Definitely yes! Momentum is measurable, and (in direction, often also in magnitude) measured in every scattering experiment. And this doesn't contradict Wigner's theorem since momentum is one of the additively conserved quantities.
It cannot, since photons (usually used in the double slit experiment) have no Schroedinger position picture.
If it doesn't in the most important case, there is no reason to believe it should in other cases.
Yes; one measures the momentum by finding the curvature of the track. Nobody is interested in the position of the particle. Just as the photon in a double slit experiment is a spherical wave which leaves a detector click at a random detector position, so
the particle is a spherical wave which leaves a track in the detector (according to Mott's famous analysis) in a random initial direction - the scattering direction and the particle energy (which together give the momentum) form the observables, not the position.
I don't think its really correct to say that no one is interested in particle tracks. Although I'm not a particle experimentalist, I certainly think they're interesting to look at!
More seriously, detailed reconstruction of particle tracks is important for determining interaction vertices. For example, interesting unstable particles may decay after traveling some macroscopic distance, thus leading to an offset in the positions of the decay products. Deciding whether certain decay products came from a "primary vertex" or from some "secondary vertex" is critical for determining the nature of the unstable particles. For example, it helps in deciding what invariant mass to compute. At least that's my understanding from chatting with my experimentalist friends.
See here: http://lhcb-public.web.cern.ch/lhcb-public/ for an example. The April 21, 2010 entry.
Whether or not anyone is interested in the position of the particle is irrelevant. The point is that position of the particle has been measured. You had claimed that "Particle detectors respond to the momentum of a particle, not to its position." This is wrong. Particle detectors at the LHC respond to, and record, the position of a particle at a sequence of times, and then infer the momentum from the path of that the particle took.
So, you are not against probabilistic interpretation per se. You are against probabilistic interpretation of position measurements.
But experimentalists do measure particle positions all the time. They use rulers, photographic plates, bubble chambers and other not-so-sophisticated devices to do so. Then they can specify a certain volume in space and count how many times particle passed through that volume (e.g., using a Geiger counter). So, experimentalists can calculate the probability of the particle being in that volume. Probabilistic interpretation of position measurements exists experimentally. However, for some reason, you do not allow us to do the same in theory.
I would appreciate if you give an original reference to the "Wigner theorem", which, as you say, does not allow us to measure position and interpret it probabilistically. This claim sounds unbelievable to me.
Eugene.
When a photon hits the photographic plate or a CCD detector it leaves a clear trace, whose position is well-defined (at least in our macroscopic world). So, it seems that there is no problem in measuring photon position with the precision of few micrometers, or so. We must have a theory, which would explain these kinds of measurements. Quantum mechanics is exactly this kind of theory, and the probabilistic interpretation of measurements of position (and all other obervables) is the cornerstone of quantum mechanics. If you deny that, then you invite a major revision of the entire foundation of quantum mechanics.
I don't know what would happen if we tried to determine photon's position with the precision of, say, less than 1 Angstrom. Perhaps, in this case we would meet some difficulties that you are referring to. However, there are no experimental devices, which can measure photon's position so precisely. So, the issue of the absence of a photon's position operator is an academic issue, in my opinion.
You do not deny the existence of photon's momentum eigenstates. And I can always form linear combinations of these eigenstates (with factors like exp(ipx)) which would behave *almost* like position eigenstates. For example, the linear combinations with different x and x' will be (almost) orthogonal. A space translation of an x-combination will move it to the x+a-combination. So, all properties characteristic to position will be approximately satisfied.
This should be sufficient for defining position measurements and related probabilities at least in our macroscopic world with micrometer-or-so-precision measurements.
All these problems are absent for massive particles, like electrons. So, to keep our discussion simple, let us focus on the double-slit experiment with electrons.
Eugene.
Yes. particle tracks _are_ important; but because they allow one to measure the momentum of a particle. But particle position is irrelevant, and doesn't exist on the quantum field level.
No. The position of a particle has been ''measured'' only in the same sense as the position of a photon has been ''measured'' when a photodetector clicks. But neither of them exists at the quantum field theory level.
For photons one not even has a Schroedinger picture in which photon position would be well-defined, hence clicks cannot be said to measure a photon position. Instead, the analysis in the book by Mandel & Wold shows that the clicks in the photodetector are produced by the photodetector already for a classical external e/m radiation field, showing that photodetection is a random measurement of the intensity of the incident radiation field, and nothing else. See the thread https://www.physicsforums.com/showthread.php?t=474537
For alpha particles, the corresponding analysi analysis is given in Mott's 1929 paper (reprinted in pp.129-134 in: Wheeler & Zurek, Quantum theory and measurement, Princeton 1983). He shows that the tracks formed in a cloud chamber are already produced by the cloud chamber in a classical external radial charged field - in which case the quantum system considered does not contain an alpha-particle at all. Thus the tracks cannot be said to measure a particle position. Instead they form a random measurement of the intensity and direction of the incident charged field, and nothing else.
Yes. In quantum field theory and hence in multiparticle quantum mechanics where particles are indistinguishable, position is a mere parameter, like time, that cannot be measured. Only for a single massive particle it seems to be different - but even here it causes the typical qauntum weirdness of propertyless particles suddenly materializing when measured.
How do you measure a particle position by a rule? Rules only serve to measure local discontinuities or maxima of a macroscopic color field.
These never measure particles, but macroscopic distributions of silver atoms or bubbles.
The most accessible reference (in English translation) is the one I gave already; the book is a very useful reprint volume. The original is in German: Z. Phys. 133, 101-108.
I deny that a photodetector measures the position of photons, or that a bubble chamber measures the position of charged quantum particles. (The trace is a trace of particle excitations as the result of the external charged field and a constant magnetic field in case of curved traces.) They measure the incident fields, nothing else.
In my lecture http://arnold-neumaier.at/ms/optslides.pdf , I call this revision the thermal interpretation of quantum mechanics. It does not require the slightest alteration of quantum mechanics or quantum field theory. I only changed the currently accepted weird way of talking about quantum system (a long tradition introduced by many years of brainwashing) into one which matches common sense much better. So it is not a change in the foundations but only a change in the interpretation - one that is more consistent with the mathematics (such as the nonexistent of a photon position operator, and Wigner's theorem).
Indeed, photon momenta are measurable if they are large enough. (Only soft photons cannot be measured, because of the infrared problem.)
Do you deny that the position of an electron can be measured by letting it fall on a photographic plate?
According to the quantum field theoretic view, position is only a field label, not an observable.
The plate responds to the field strength of the beam containing the electrons: Random atoms are ionized, with a rate proportional to the field strength. This effect that is subsequently magnified and becomes visible.
What is measured is therefore the field strength, although because of the randomness involved, the measurement becomes reliable only if the exposure is sufficiently long.
Mr Neumaier,
I'm also suprised to read such a statement! (That the tracks in a bubble chamber are not a position measurement). I don't deny this immediately, i just want to understand what you're saying.
Let me say first how i would define a position measurement. If the incident field/particle has a state |Ψ>, and expand this state on the basis of position eigenstates, then i would call a position measurement something that would make the wavefunction of the particle in the position representation "gather" around a point. So that, we will be able to say that it was here, in that box, and not in the andromeda galaxy. Knowing that the field/particle is located in a subregion of space, i think defines a position measurement.
When charged fields/particles interact with the bubble chamber we see a trajectory. This trajectory has dimension, for example 0.5x0.5 mm^2 and that defines a subregion of space. I agree that what we see is the effect of the interaction of the particle with the atoms of the liquid, but there can be an interaction only if the paticle's wavefunction is nonzero at the point of the interaction with an atom. The fact that we see only a small trajectory -to my mind- means that the wavefunction of the particle is non-zero only in that subregion of space. It doesn't interact with the rest of the chamber, and its not in my house either.
So, that fits my definition of position measurement, the wavefunction is 'gathered' in a subregion of space.
Am i wrong?
John
On Wigner's no-go theorem for exact measurement:
The paper J. Math. Phys. 25 (1984), 79 -87 by Ozawa might also be of interest.
The position is of course a field label, since the quantum field is essentially the position version of momentum mode creation operators. But why does that imply that the position of an electron cannot be measured? As far as I know, the fact that momentum is a label of the creation operators for momentum modes does not imply that the momentum of an electron cannot be measured, so what's the difference?
In my opinion, we should first define what we mean by a 'position measurement' and then see if the tracks in a bubble chamber, for example, qualify.
The difference is that momenta (like other conserved additive quantities) are asymptotic quantities, and quantum particles have meaning in an asymptotic sense only.
Things start to get semiclassical (where the particle concept begins to be applicable) only when field concentrations are so large that their density peaks at reasonably well-defined locations in phase space. At this point, these peaks behave like particles, and position and momentum of the peak behaves approximately classically.
Why don't you start with a proposal for a definition what _you_ mean by a 'position measurement'?
I've done it at post #22.
Could you expand on this part a bit. What's an asymptotic quantity?
An observable still visible at times t-->inf or t-->-inf, so that scattering theory says something interesting about it. This is relevant since quantum dynamics is very fast but measurements take time. Measuring times are already very well approximated by infinity, on the time scale of typical quantum processes. Thus only asymptotic quantities have a reasonably well-defined response.
That's why information about microsystems is always collected via scattering experiments described by the S-matrix, which connects asymptotic preparation at time t=-inf with asymptotic measurement at time t=+inf.
  • #31
Ah, I missed the details in that post.
JK423 said:
Let me say first how i would define a position measurement. If the incident field/particle has a state |Ψ>, and expand this state on the basis of position eigenstates, then i would call a position measurement something that would make the wavefunction of the particle in the position representation "gather" around a point. So that, we will be able to say that it was here, in that box, and not in the andromeda galaxy. Knowing that the field/particle is located in a subregion of space, I think defines a position measurement.
This recipe cannot cover a photon position measurement since the photon disappears upon exciting an electron. Do you want to improve upon your definition of a position measurement, or do you want to treat photons and electrons on a different footing?
JK423 said:
When charged fields/particles interact with the bubble chamber we see a trajectory. This trajectory has dimension, for example 0.5x0.5 mm^2 and that defines a subregion of space. I agree that what we see is the effect of the interaction of the particle with the atoms of the liquid, but there can be an interaction only if the particle's wavefunction is nonzero at the point of the interaction with an atom.
In the quantum field view, one would say that there can be a response only if the field intensity is nonzero at the point of interaction. This works independent of the number of particles present.
Am I wrong?
If you assume the collapse postulate, your view is consistent, as long as you don't claim that position can be measured arbitrarily well. This is just the Copenhagen interpretation.
The problem with this is that there is no known mechanism for causing the collapse. (Decoherence reduces the pure state to a mixture, but we don't observe a mixture of tracks - only a single one. This accounts correctly for the long-term average, but not of the collapse at each single instance.)
The quantum field picture doesn't need to assume a collapse; ordinary randomness is enough.
  • #32
I agree with you that parameter x in quantum field [tex] \psi(x,t) [/tex] has absolutely no relationship to physically measurable position. However, this does not mean that the observable of position cannot be defined in quantum field theory. We've discussed this point with you already. In any n-particle sector of the Fock space I can define a state in which one particle has position x_1, second particle has position x_2, third particle ... etc. You were correct to point out that in the case of indistinguishable particles this does not allow to form a Hermitian "particle position" operator. But the above construction of n-particle localized states is sufficient to describe position measurements in the Fock space.
You would possibly object that the Fock space is not valid for interacting particles. But this has no relevance, because we've been discussing the measurements of position of a single electron, which is not interacting with anything.
Another point is that refusing the measurability of positions you are are not saving yourself from the "weird" quantum collapse. You've mentioned elsewhere that the momentum-space wavefunction [tex] \psi(p) [/tex] does have a measurable probabilistic interpretation. So, it does require a collapse. This time in the momentum space.
Our difference is that I believe that the blackening of silver atoms or the formation of bubbles are direct local effects of incident particles. So, by measuring positions of exposed grains of photoemulsion or bubbles we measure (albeit indirectly) positions of particles, which created these effects.
If I understand correctly, your position is that the blackened grain of photoemulsion or the formed bubble is not a proof that the particle really hit that spot. You invoke a (rather strange, in my opinion) detection theory from Mandel & Wolf, where they represent the particle by an extended continuous field. Then creation of the local photographic image or a small bubble is "explained" by a sequence of non-trivial condensation events happening in the bulk of the detector. These events require migration of charge to macroscopic distances, entanglement, and other complicated and not fully explained things.
If I understand correctly, your motivation for applying these non-trivial models of particle detection is to avoid using the quantum-mechanical wave function collapse. So, you replace the collapse with some chaotic and yet mysteriously choreographed (condensation of the originally distributed particle energy at one fixed but random point) processes inside the macroscopic detector.
Eugene.
  • #33
A. Neumaier said:
[...] the analysis in the book by Mandel & Wold shows that the clicks
and nothing else. [...]
To others who may be interested in studying the latter (formation of
tracks by charged particles) in more detail...
There's an extended treatment in Schiff's textbook, pp335-339. He uses
2nd-order perturbation theory to consider the probability of a fast
electron participating in an ionizing interaction with the electrons in
two separate atoms. The result is that the probability is very small
unless the atoms are on a line parallel to the momentum of the incident
electron (approximated as an incident plane wave field).
Thus, Mandel & Wolf are not the only ones who treat the subject in
this more careful way.
  • #34
strangerep,
I agree that some aspects of particle detection can be explained by Mandel & Wolf type arguments. However, there are situations, where these arguments fail completely. I think the most spectacular failure is related to electrons registered by a photographic plate. If you describe the incident electron by a plane wave or other continuous charge density field, you will have a hard time to explain how this distributed charge density condenses to a single location of one emulsion grain. I think it is well established that after "observation" the entire electron charge is located in the neighborhood of the blackened emulsion grain. Apparently, there should be a mechanism by which the distributed charge density condenses to a point and overcomes a strong Coulomb repulsion in the process. This doesn't look plausible even from the point of view of energy conservation.
Eugene.
  • #35
I'm sorry, but this statement is simply false. I just gave an example where particle position is relevant. One can mention quantum fields all one wants, but that doesn't change the fact that as a practical matter particle positions can be meaningful and useful approximations. Even in quantum field theory.
<h2>1. What is the probabilistic interpretation of QM?</h2><p>The probabilistic interpretation of QM is a fundamental principle of quantum mechanics that states that the behavior of particles at the quantum level cannot be predicted with certainty, but only with a certain probability. This means that the outcome of any measurement or observation of a quantum system is not determined, but rather described in terms of probabilities.</p><h2>2. How does the probabilistic interpretation of QM differ from classical mechanics?</h2><p>Classical mechanics, which describes the behavior of macroscopic objects, is based on deterministic principles where the future state of a system can be predicted with certainty. In contrast, the probabilistic interpretation of QM introduces an element of randomness and uncertainty at the quantum level, which is not present in classical mechanics.</p><h2>3. What evidence supports the probabilistic interpretation of QM?</h2><p>There is a wealth of experimental evidence that supports the probabilistic interpretation of QM. For example, the famous double-slit experiment demonstrates the wave-like behavior of particles at the quantum level, which can only be described in terms of probabilities. Additionally, various other experiments have shown that particles can exist in multiple states simultaneously, further supporting the probabilistic nature of quantum mechanics.</p><h2>4. Does the probabilistic interpretation of QM apply to all physical systems?</h2><p>Yes, the probabilistic interpretation of QM applies to all physical systems, regardless of their size or complexity. However, the effects of quantum mechanics are usually only noticeable at the microscopic level, and classical mechanics is still a highly accurate and useful model for describing the behavior of macroscopic objects.</p><h2>5. How does the probabilistic interpretation of QM impact our understanding of reality?</h2><p>The probabilistic interpretation of QM challenges our traditional understanding of reality, as it suggests that the behavior of particles is inherently uncertain and unpredictable. It also raises philosophical questions about the nature of reality and our ability to truly understand and describe it. However, despite its counterintuitive nature, the probabilistic interpretation of QM has been extensively tested and has been shown to be a highly accurate and useful model for describing the behavior of particles at the quantum level.</p>
  • Quantum Interpretations and Foundations
