Resistor currect and voltage drop in a circuit.
In summary: R_4||(R_2+R_3)), we are ready for the next step: step back in the simplification again. We are now at picture 1. We see then that the voltage we JUST found across R_4||(R_2+R_3) is the same voltage across R_2 + R_3. Find the current through that 1 equivalent resistor then step it back to 2 series elements R_2 and R_3. We then use the current rule that current is the same through series elements so we know the current through R_2 as well. Ohms law then gives the voltage across R_2. In summary, by using the rules that the voltage across
davidepalmer
Consider this circuit with R1 = 30 ohm, R2 = 10 ohm, R3 = 10 ohm, R4 = 20 ohm,
R5 = 60 ohm. (the circuit is attached)
A. What is the current across the resistor R2, if a voltage of 110 Volt is applied to
the two terminals at the bottom of the figure?
B. What is the voltage drop across R2?
C. Keep all other resistances at the same value, but allow R2 to vary. What are the
minimum and maximum resistances that this circuit can have?
I know that i have to use V=IR to solve for the voltage drop and the current across the resistor.
I have already found the equivilent resistance of the arrangement. I am able to find the total current throughout the whole circuit, but after that I don't really know where to start.
  • circuit.doc
minimum and maximum resistances that this circuit can have?I know that i have to use V=IR to solve for the voltage drop and the current across the resistor.
After you have the total current through one jumbo resistor [tex] R_{eq}[/tex] you can begin to then reverse your resistor simplifications one step at a time to find the voltage and current for each resistor.
Use these two rules: the voltage across parallel resistors is the same and the current through series resistors is the same. Therefore, let's say you unsimplified your jumbo resistor into two parallel resistors. You know that the voltage across that 1 jumbo resistor is across both those parallel resistors. If you had expanded it to two series elements, you know the current through each of them is the same as the current through the jumbo resistor. So you keep stepping back and using these rules until you have everything you need.
Therefore if I'm able to find the voltage after R1, that voltage is the same through R4 and R23. So with this information I can find the current through R23 and since R2 and R3 are in series they have the same current as R23?
I'm not sure what you mean by "find the voltage after R1"
[tex]R_{eq} = R_1 + R_4||(R_2+R_3) +R_5[/tex]
This is how you simplified the circuit into 1 resistor. Here is each step shown visually:
http://img98.imageshack.us/img98/4800/49119358.jpg
So here you are with a current through the 1 resistor in step 3. Let's unsimplify the circuit by 1 step, and go back to step 2. As you can see, there are three series resistors. We know that the current through the series resistors is the same as the current of the one equivalent circuit -- where else would the current flow since the resistors are one a one way track? So with whatever that current is you found, use Ohm's law to find the voltage across the resistor that is or that contains the resistor we want to know about. In this example, the middle resistor contains R2, the resistor we want.
With the voltage across [tex]R_4||(R_2+R_3)[/tex] found by [tex] I *( R_4||(R_2+R_3))[/tex], we are ready for the next step: step back in the simplification again. We are now at picture 1. We see then that the voltage we JUST found across [tex]R_4||(R_2+R_3)[/tex] is the same voltage across [tex] R_2 + R_3[/tex]. Find the current through that 1 equivalent resistor then step it back to 2 series elements R_2 and R_3. We then use the current rule that current is the same through series elements so we know the current through R_2 as well. Ohms law then gives the voltage across R_2.
I think I've finally figured out what you've been explaining to me. I was able to work it backwards and get the answer now. Thank you so so much for your help!
1. What is the relationship between resistor current and voltage drop in a circuit?
The relationship between resistor current and voltage drop in a circuit is described by Ohm's Law, which states that the current flowing through a resistor is directly proportional to the voltage drop across it. This means that as the current increases, the voltage drop also increases, and vice versa.
2. How do I calculate the voltage drop across a resistor in a circuit?
The voltage drop across a resistor can be calculated using Ohm's Law: V = IR, where V is the voltage drop (in volts), I is the current (in amperes), and R is the resistance (in ohms) of the resistor. Simply plug in the values for current and resistance to find the voltage drop.
3. Can a resistor affect the current in a circuit?
Yes, a resistor can affect the current in a circuit by limiting the flow of electrons. This is due to the resistance of the material the resistor is made of, which impedes the flow of current. As a result, the current in the circuit will decrease.
4. What happens to the voltage drop in a circuit when the current increases?
When the current increases in a circuit, the voltage drop also increases. This is because the resistor is experiencing a greater amount of current flow, which causes a greater amount of energy to be dissipated as heat, resulting in a higher voltage drop across the resistor.
5. How does the resistance of a resistor affect the voltage drop in a circuit?
The resistance of a resistor directly affects the voltage drop in a circuit. As the resistance increases, the voltage drop also increases, as stated by Ohm's Law. This means that a higher resistance resistor will have a larger voltage drop compared to a lower resistance resistor in the same circuit.
