New Reply
double slit experiement?
Share Thread Thread Tools
Dec26-12, 12:36 PM   #1
in the experiement does the electron/photon always split and physically go through both slits or is this just an interpretation of the results?
I believe this is Feynmans interpretation. is it universally accepted?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Dec26-12, 01:46 PM   #2
I just dont understand if its actually a proven fact that it goes through both(or indeed all possible infinte paths) or is just an interpretation.
Please help
Dec26-12, 02:48 PM   #3
Recognitions:
Quote by I2004 View Post
I just dont understand if its actually a proven fact that it goes through both(or indeed all possible infinite paths) or is just an interpretation.
The proven fact is:
If both slits are open and you make no attempt to interfere with the electrons (for example, by trying to detect their position) while they are in flight, and send the electrons one at a time, then
- Each individual electron will make a single discrete dot on the screen.
- Run the experiment long enough, and the dots will build up to form a pattern on the screen.
- The pattern is not two blotches, one behind each slit, as you would expect if each individual electron went through one slit or the other. Instead it is the interference pattern that would be produced by waves going through both slits at once, and that you can calculate using the sum-of-all-paths method.
Just about anything beyond "the math works and predicts this result" is an interpretation.
Dec26-12, 09:46 PM   #4
You mention Feynman, and I think he may be the only person who does not characterize this as having the electron split and interfere with itself.
Instead, he prefers the approach where you combine all possible timelines and let them interact. So it is more like the electron is free to go back and forth freely in time before deciding on its ultimate destination, but all of the forward paths interfere with all of the 'previous' forward paths in this very long 'lifetime' of time-reversals. So when it comes forward again, it needs to avoid the other paths that it 'tried out' and chose not to take, as if there were another electron that *did* choose to take them.
To make the point in an extreme way, he once proposed that there is only one electron in all the universe, but it has gone back in time often enough to be all of the existing electrons we see now. It captures a way of looking at quantum mechanics that is less bizarre than the possibility function with a collapsing wavefront.
I think it is the view that Hawking proposed we should take for why black holes last as long as they do before they evaporate into virtual particles. (I gather that it did not go over well, and was seen as cheating, but it is among the historically proper approaches to the problem.)
Dec27-12, 03:16 AM   #5
A photon interferes with itself.If you measure from which hole photon gets through interference disappears.
Dec27-12, 07:52 AM   #6
The wavefunction that describes the electron is calculated based on the geometry of the experiment and provides a statistical prediction of which screen locations are more probable than others. The wavefunction is a vector field, and so when two of them are superimposed, the vectors at each point are summed. Vector addition is what makes interference patterns emerge when you would expect to see two blobs in the double slit experiment.
"Particles" interact via forces. They do not interfere with eachother or themselves. The vector field which predicts probable outcomes of an experiment does interfere, which is simply stating that sometimes the sum of two vectors has a smaller absolute value than the absolute value of either of the vectors.
This doesn't answer your question, its just me being fussy because I'm annoyed that certain popular statements about QM imply incorrect, magical things because of their inaccurate wording.
The wavefunction is formulated with no assumptions about the number of "particles" that are present, on the contrary, it would be much more difficult if particle-particle interactions were considered. It can be normalized to any number you want so it shouldn't be surprising when it works as well for low intensities as for high...
The one assumption that all paradoxical and unintuitive scenarios share is the assertion that there is any such thing as "particles" in the first place. So I would say that the "particle" splitting and taking both paths is an interpretation of the results, as well as the existence of the particle. I know this is not what you wanted to hear. Sorry.
Quote by jobermark View Post
I love this idea, since the arrow of time is something that arises from the tendency of thermal systems to maximize disorder purely because all states are equally likely and the number of states of maximum disorder is astronomically large compared to all others, there is no reason for it to apply to a single electron.
But since the wavefunction does not consider particle-particle interactions, and would be different if it did so, how can a model in which the particle reverses direction in time and affects itself, through the electromagnetic force I assume, produce the same predictions?
Jan5-13, 06:40 PM   #7
my original question is, is it accepted that the particle splits and goes through both slits at once so the particle is in 2 places at one?
anyone have an answer please?
Jan5-13, 07:48 PM   #8
Recognitions:
No, that is not universally accepted. As with any interpretation, nothing awful will happen if you think about it that way, but you could reasonably choose to think about it some other way if you would rather.
(I feel like repeating #3 in this thread. I thought it answered your question).
Jan5-13, 08:27 PM   #9
Recognitions:
Gold Membership Gold Member
No.
New Reply
Thread Tools
Similar Threads for: double slit experiement?
Thread Forum Replies
Young's double slit experiment with one slit covered with block of refractive index Introductory Physics Homework 4
Determine the slit-with and slit-distance of a double slit laser diffraction Introductory Physics Homework 1
rearranging the doulbe slit experiement? Quantum Physics 0
Absorbing Material Over a Slit in Deriving Double Slit Fraunhofer Interfernce Pattern Advanced Physics Homework 1
Young's double slit experiment (shallow slit and deep slit) General Physics 4
