Designing a Reclining Binocular Chair: Ideas and Techniques
In summary: VDC power supply, overload protection, and low-voltage shutdown.I don't know whether or not they're all the same. The jaw-drive mechanism for my 'Alien' Hallowe'en costume was the 6-way pack from a '65 Mustang. It's essentially 3 motors in one case, with cable drives off of both ends of all 3 rotors. For my purposes, I removed 2 of the rotors, which still left it weighing at least a kilo. (That left me truckin' around with about 15 kg of steel on my head, but I had it suspended on springs from a welding helmet harness, so it was pain
Saladsamurai
3,020
Okay so completed a similar project the other day,but I am addicted now.
I built a parallelogram binocular mount similar to this.
Now I am trying to come up with ideas for a binocular chair...like this
I would like to make the chair recline though. This is where I need help. I need to make it so goes up and down slowly (since in my design, the binos will be attached directly to the chair) , perhaps by use of a hand crank.
I was thinking of using some kind of spiral jack or something...
It needs to be cheap and the premise should be something along the lines of, I turn a crank and it raises or lowers a cylinder or something to that effect.
Any ideas are appreciated and images of those ideas too if possible.
I am also going to use a similar method to make the chair rotate about the vertical axis too.
You will notice that most chairs do their reclining feature through the use of pulling a handle and allowing you to freely recline the chair while you hold that handle, and it relocks when you release it.
So what you do is you use a hinge, and you attach a ridged circle at the end, and then you attach another ridged circle that locks with the hinge, and connect it to a handle that has a pivot just before the second ridged circle, and a spring to keep it in place until moved. Then pivoting the handle will allow you to recline.
NOTE: I'll draw you a diagram and attach it in a few minutes.
Though the simplicity of the idea is attractive, the motion needs to be very slow and controlled. The motions cuased by this kind of mechanism, I believe, would be too jagged.
Thanks though!
Actually, it would not be jagged at all, as in pulling the handle, it would release the two ridged circles, and if you add a small amount of friction between the chair and the area that reclines, the movement will actually be very smooth.
(The drawing is terrible btw, so interpret the best you can)
You can buy one of those reclining chairs (or get a broken chair from somewhere) .. remove the base (those wheels) and just hammer it into your system
Is that something that PF does automatically...or did you really just link me to a definition of friction?:rofl:
Any ideas on the hand crank mechanism?
No. PF did that automatically.
I'm a really lazy bastard, so I'd go electric. There's nothing like good old scrap-yard power seat packs for strong, fluid movement. Of course, you need a 12VDC power supply, but that's never been a problem for me.
I had this idea too, I think. You mean getting pulling a motor out of a car seat? What do these look like after you remove one from the actual seat? Is it easy to convert for my purpose?
I don't know whether or not they're all the same. The jaw-drive mechanism for my 'Alien' Hallowe'en costume was the 6-way pack from a '65 Mustang. It's essentially 3 motors in one case, with cable drives off of both ends of all 3 rotors. For my purposes, I removed 2 of the rotors, which still left it weighing at least a kilo. (That left me truckin' around with about 15 kg of steel on my head, but I had it suspended on springs from a welding helmet harness, so it was painless. :biggrin:)
The pack itself was about 50% larger than a package of Smokies. (Maybe twice as big as a pack of wieners.)
these above mentioned measurements are standards from National Bureau of standard weights and measures. (Danger, your my hero)
instead of getting the electric motors from a car seat, why not use the whole car seat? everything is already there, just need power. pretty comfortable too
That's pretty much the way that I was thinking, although not all functions are necessary for the purpose. One advantage is that you can snipe the control buttons from the driver's door panel while on site. That can save a couple of bucks down the road.
Needs to be portable. I think I have ruled out the seat pack.
I am thinking of using some sort of combination of springs and dampeners...like a screen door or something...
I open to more suggestions...
If you want super simple, how about a car jack, i.e. screw jack, directly attached to the back of the chair? If you wanted, you could increase complexity by putting a right angled drive in the back, then run one end up to the back of the chair and then the other out the front between the legs of the person sitting in the chair. Then you could even look into providing a drive to attach a cordless drill to power it.
http://img.directindustry.com/images_di/photo-p/214004.jpg
Good idea, Fred. A screwjack is probably my favourite actuator mechanism for just about any purpose that doesn't require high speed. Awesome torque and controllability, and just about bullet-proof.
I like this idea...hopefully I can find a decent jack at the scrapyard for short money.
Thanks
I found one online. It goes from min height of 6.4" to max height of 13.5"
I am wondering if this what the best range of inclination I can get out of this will be.
Taking the horizontal as a reference axis and sitting upright to be 90 degrees.
Sitting at 90 and laying at 0 degrees are unnecessary.
Hmmm. Time to get out some paper here to see what the compromise will be.
No need to compromise, pal. You can always add secondary leverage or gearing to your primary unit to obtain the results that you want.
Could you elaborate on what you mean? I know there is a way around this...
I am thinking something like this
Where the circle is a hinge and where the length of the overhanging portion d is part of the back rest (all one piece). By changing the length of d and having the actuator act at the end of d i can vary the range of the angle of inclination.
I think this is a simple but effective idea. I like simple...less can go wrong...supposedly.
(remember when images actually showed up in threads? not just links to them...what gives?)
Can anyone tell me about http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=100595199&langId=-1&catalogId=10053&ci_src=14110944&ci_sku=100595199&cm_mmc=1hd.com2froogle-_-product_feed-_-D25X-_-100595199"?
What does it mean 2 stages?
W insisted upon hosting a BBQ for the the whole neighbourhood tonight, so I'm afraid that I'm far too drunk to address this right now. I'll take a crack at it tomorrow.
How about a set of bicycle cranks to operate the mechanism hands-free?
I planned on using the sprockets from a bike to operate the rotational aspect of the chair.
However, using the actual pedals with my feet was not something I had thought of. This is a great idea that I may use! thanks!
That's actually kind of cool! I've never seen a screw-jack in that configuration before; it looks like a hydraulic bottle jack. It appears obvious from the rotary input that 2-stage refers to a secondary gearing system incorporated before the screw mechanism. The 2-ton capacity would tend to support that. I can't be sure about this without seeing a cut-away of the unit, though.
I got that two stage screw jack. We'll see...
How about http://yhst-1469288697390.stores.yahoo.net/smsmch.html"
My chair will recline, which will eliminate the need to physically look up and thus eliminate neck and back discomfort.
So I am thinking of doing something like this now. The seat will be a box and the actuator will go inside of it here is a crappy drawing
the back rest looks like this from the front (before installation)
I just need to decide how large (diameter) a wooden dowel I should use (or can find) for the cylindrical part.
I need it to be sufficiently strong. I need to cut out a groove where I will set the backrest into and I also need to make a slot into which part B (the thing the actuator pushes on) will slide and be set.
Open to comments and ideas/opinions.
Thanks
I just thought of something. If you can find a scrapped recliner/rocker chair (such as a La-Z-Boy) at a scrapyard, you could just replace the lever assembly with a gear drive and reupholster it.
  • #31
The number one priority of the chair (besides to function) is to be portable. It needs to break down into enough pieces that it can be carried but not so many pieces that it's a pain to set up.
  • #32
Ah, I forgot about that. Sorry. La-Z-Boys are pretty much riveted together, (at least, the skeletons that I've seen were).
How about a lawn chair? The recliner ratchet mechanism could be decoupled and tied to an automotive electric window crank mechanism or a screwjack.
  • #33
chair would need electric massage, port for 110V for laptop power supply.
  • #34
Obviously. I mean...I didn't think that even needed to be said.
  • #35
has anyone suggested you look at the plans or the actual item called a steadicam. Buzz me back if you need some info or go to wiki.
1. What is a reclining binocular chair?
A reclining binocular chair is a specialized piece of furniture that combines the comfort of a recliner with the functionality of binoculars. It allows the user to comfortably sit and observe their surroundings through the attached binoculars.
2. What are the benefits of a reclining binocular chair?
One of the main benefits of a reclining binocular chair is its versatility. It can be used for various outdoor activities such as bird watching, stargazing, or sporting events. It also provides a comfortable and ergonomic seating option for extended periods of observation.
3. What are some important design considerations for a reclining binocular chair?
When designing a reclining binocular chair, it is important to consider the overall comfort and support of the user. This includes the angle of the recline, the height and width of the seat, and the placement and adjustability of the binoculars. It is also important to use durable and weather-resistant materials for outdoor use.
4. Are there any safety concerns with a reclining binocular chair?
Like any piece of furniture, there are some safety considerations to keep in mind when using a reclining binocular chair. It is important to ensure that the chair is stable and can support the weight of the user. The binoculars should also be securely attached to the chair to prevent any accidents or injuries.
5. Can a reclining binocular chair be customized?
Yes, a reclining binocular chair can be customized to fit the specific needs and preferences of the user. This can include different seat materials, adjustable features, and additional accessories such as cup holders or storage compartments. However, it is important to keep in mind that any modifications should not compromise the safety and functionality of the chair.
  • General Engineering
  • General Discussion
  • Mechanical Engineering
  • STEM Academic Advising
