I want to buy a microscrope Need help picking one
  • Thread starter nukeman
In summary, the best microscopes for a research student are the Digital Blue QX3 or QX5 (depending on your budget), which are basic compound microscopes that are easy to use and have good performance.
nukeman
655
Hey everyone,
I do not know much about Microscopes, but am looking at buying one.
I am a Neuroscience (and physics but that's not important) major, and starting to do all kinds of research.
For my own personal research, and also research done at school with insects, DNA, cells, and whatever, I want to get a really good microscope that will serve me well as I further my education in neuroscience and microbiology.
So, here are some I am looking at. I was hoping major you can tell me the limitations of some of the ones I list below here. Maybe tell me important things to look for. I don't want a crappy one.
This one is cheap and has LCD, but I have a feeling it won't cut it for serious stuff?
http://www.islandeyepiece.com/shopexd.asp?id=1892
There is this one, that seems more advanced:
http://www.islandeyepiece.com/shopexd.asp?id=1492
This one seems pretty costly for my first microscope. What do you think?
http://www.islandeyepiece.com/shopexd.asp?id=1192
I think the best deal is this one...??
http://www.microscopenet.com/40x200...p-9110.html?osCsid=go5inj93pojo3dr6k5p7j3bg75
Or...if all these are no good, maybe you can recommend a good one for a research student?
Biology news on Phys.org
nukeman said:
Hey everyone,
Have you asked your professor?
The second one will be useless for anything on the cellular level. It's just a dissecting scope.
nukeman said:
Hey everyone,
<snip>
What is your experience using microscopes? If you have never used a microscope, I strongly recommend the Digital Blue QX3 or QX5 (depending on your budget), which appear similar to the Celestron LCD Digital Biological Microscope. I recommend these for beginners since they are cheap, easy to use, and when your skill exceeds the performance of these, you won't mind so much since you didn't spend a lot of money in the first place. The goal for the beginner is to have fun using the instrument and in the process, gain experience.
If you can, try and get some experience on research-level scopes around your lab; you'll learn what is important (a good focus stage, good condenser lighting, etc) and what is not important (magnification). The ones you listed all suffer from the same deficiencies: inexpensive lenses and inexpensive sample stages. Of the two, the sample stage will limit your ability to operate at even moderate magnifications due to vibrations and inability to fine focus.
Once you are ready to spend a moderate amount of money on a scope, in all honesty I recommend getting a used one (used lenses, also), since you will be able to get a higher-performing instrument within your budget.
Thank you very much Andy, appreciate that!
I have some experience with them. I use to have one a while back, a very nice basic one.
My budget is max $500 (I know that's not a lot), maybe a little more, but $500 is where I want to be right now.
With that budget, what should I be looking at?
Here is a site I have ordered from before and like them. They have sale, so hopefully I get a good one with my small $500 budget.
Any good ones you see? Or what would you recommend?
http://www.microscopenet.com/index.php
Thanks again!
I don't endorse any particular brand, but given your budget, you should be able to get a microscope that you can use for several years before you outgrow it. I recommend a basic binocular compound microscope unless there is a particular reason you are interested in a stereomicroscope.
Of the (new) instruments that I found in your price range, they all seem to be the same- manufactured in china/india, with whatever company (Amscope, Celestron, etc.) putting their label on the assembled instrument.
First, I recommend trying one before buying, if possible. Otherwise, here are a few thoughts:
I like LED illumination over halogen- less power, lasts longer, etc. Don't bother with a trinocular head- if you want to use a camera, you can go through the eyepieces. There seems to be two main body styles: keep in mind there are many suppliers for these, I am using these sites *only* for the images.
http://www.amscope.com/Picture-B490-1
and
http://www.amscope.com/Picture-B520-1
Of the two, I think the bottom style is more stable, but in all honesty it could be a style issue, not a mechanical stability issue. There are also lots of ways to reduce vibration coupling from the room- a 1/4" thick sheet of soft rubber, a sandpit (seriously!), etc.
The objective lenses should be (and probably are) DIN standard (160mm tube length), as opposed to infinity-corrected. This will give you more flexibility to upgrade your lenses when you are ready.
Go for it!
Edit: I forgot to mention, it's probably worth $10 to get some prepared slides. That way, you'll be able to start using the scope immediately.
Thank you very much for this great info. I think I have made my mind up. Also, I am going to pick up a eyepiece cam.
Really good idea getting some slides so I can use it right away. Thanks again Andy.
and
Go for it!
What is a microscope and why would I need one?
A microscope is a scientific instrument that is used to magnify and observe small objects or organisms that cannot be seen with the naked eye. It is commonly used in scientific research, medical diagnosis, and education.
What are the different types of microscopes available for purchase?
There are several types of microscopes available, including compound microscopes, stereo microscopes, digital microscopes, and electron microscopes. Each type has its own specific uses and features, so it is important to determine your specific needs before making a purchase.
How do I choose the best microscope for my needs?
When choosing a microscope, consider factors such as magnification power, resolution, illumination source, and portability. It is also important to consider your budget and the intended use of the microscope.
What are some reputable brands or manufacturers of microscopes?
Some reputable brands and manufacturers of microscopes include Nikon, Olympus, Leica, Zeiss, and AmScope. It is important to do research and read reviews to determine the best brand for your specific needs and budget.
Are there any additional accessories or equipment that I may need to purchase with a microscope?
Depending on your specific needs, you may need to purchase additional accessories such as slides, cover slips, immersion oil, and specimen preparation tools. It is important to research and determine which accessories are necessary for your intended use of the microscope.
  • Astronomy and Astrophysics
  • Biology and Medical
  • STEM Academic Advising
9K
