Register to reply
Electric field
by sanoo
Tags: electric, field
Share this thread:
sanoo
#1
Apr19-13, 12:54 PM
P: 2
In an irregular shaped charged conductor will the electric field E at all points within the conductor be zero? If yes, then how?
Phys.Org News Partner Physics news on Phys.org
Vibrational motion of a single molecule measured in real time
Researchers demonstrate ultra low-field nuclear magnetic resonance using Earth's magnetic field
Bubbling down: Discovery suggests surprising uses for common bubbles
Barloud
#2
Apr20-13, 07:53 AM
P: 17
I assume you are talking about a purely static situation.
Without external electric field, the net electric charge in each point of the conductor is zero (lets keep it simple: I assume there are no excess charges in the conductor).
Under the action of an external field, the positive and negative charges in the conductor displaces, so that the net electric charge in each point of the conductor (local charge) is not zero. If you sum the charge of all these points over the whole volume (global charge), it will however remains equal to zero.
The local charges are so smart that they arrange themselves so that the field is zero in the whole conductor. It is however a very difficult task to compute the local distribution for complex geometries.
sanoo
#3
Apr21-13, 01:44 PM
P: 2
Thanks for the reply. But if a conductor is charged, the charges are spread on its surface. Will not those charges impose an electric field within the conductor? Will the local charges again arrange themselves to cancel the field produced?
vanhees71
#4
Apr21-13, 02:59 PM
Sci Advisor
Thanks
P: 2,438
Electric field
The trick is that the charges are distributed over the surface precisely such that there is no electric field inside the conductor. This is only true for the static case!
Register to reply
Related Discussions
Is Postive Electric Field at high potential or Negative electric field? Classical Physics 5
Electric field, Electric Potencial, Electric Force, Potential Electric Energy Classical Physics 1
Two charges create an electric field-electric field strenght at a point above h.fiel Introductory Physics Homework 4
1.) Net electric field and 2.) Maximum electric field from centre of a ring Introductory Physics Homework 7
Electric field in a dielectric in terms of the electric field in the vacuum Introductory Physics Homework 0
