Classical Electromagnetism: Question on Ampere's Law and Displacement Current
In summary: The question I posed was whether every time-varying E-field would be associated with a displacement current. nicksauce said no, so how about those cases whereby we have a time-varying field but no displacement current or current flow? Are there such cases, and is any B-field induced?There are cases where a time-varying E-field is present but no current flow. In these cases, no displacement current is present, so the B-field cannot be induced.
jaseh86
37
Hi, just out of curiosity...
Ampere's Law describes that an electric current produces a magnetic field. When corrected with Maxwell's displacement current, it describes that a magnetic field is also created by a time-varying electric field.
Does this mean that an electric current produces the magnetic field purely BECAUSE of the changes in electric field associated with moving charges. Or is electric current one of two distinct ways (the other being changing electric field) to produce magnetic field.
A little confused on the matter.
Thanks.
Ampere's circuital law does not say that an electric current produces a magnetic field. That is the Biot-Savart law. I don't see how a changing electric field (without considering the current flow) can induce a B-field.
Thanks for the reply.
But doesn't Maxwell's Theory of Light explain that changing electric fields induce magnetic fields due to Ampere's Law / Biot-Savart Law. In vacuum for instance, there is no electric current, so why is it that a changing electric field without current flow can't produce magnetic field?
Good question. All we really can say from Maxwell's equations is that under time varying conditions, electric and magnetic fields cannot exist independently. It is futile to even attempt to ascertain which one comes first. Which is the cause and which is the effect is an endless vicious circle. In his 1905 paper "On The Electrodynamics Of Moving Bodies", Einstein states that "questions as to which one (electric or magnetic field) is the "seat" (root, fundamental, canonical, principle, basis) no longer have any point." The parentheses are mine.
Hmm, actually having taken a closer look at your thread title, I realize that I might have misunderstood your question. The displacement current, which is associated with a changing E-field does itself induce a B-field. The only question that remains if every time-varying E-field is associated with a displacement current.
To which I would definitely say no. The easiest case is solving Maxwell's equation in the absence of sources, and getting a wave equation for E (and B), which is certainly a time-varying field.
hunh?? that's what one of them 4 Maxwell's Equations tells us. of course a changing electric field induces a magnetic field.
imagine a simple two parallel plate capacitor with axial leads and a steady (DC) current flowing in one lead (and out the other lead). between the plates of the capacitor there is no current, but there is a magnetic field induced.
Solving which equation?
That is because of the displacement current. The question I posed was whether every time-varying E-field would be associated with a displacement current. nicksauce said no, so how about those cases whereby we have a time-varying field but no displacement current or current flow? Are there such cases, and is any B-field induced?
Can you defennd this statement a bit (mind the pun :rolleyes:)? Ampere's law clearly states that the presence of electric current induces a curling magnetic field. Does this not imply that electric current produces a magnetic field?
The laws of Ampere and Biot and Savart both say that current induces the magnetic field; I would call it a matter of convenience in choosing which law to invoke for a specific problem. Note that you may consider either law as an axiom to EM theory from which you can derive the other.
The term known as the displacement current (dD/dt) is called that because it is correct to think of it as a current in the traditional (or at least semi-traditional) sense; that is as the movement of charge. You have to remember that the electric displacement (D-field) contains in it two facets of information: 1) the electric field (E-field) and 2) the electric polarization (which is essentially a sum over electric dipole moments).
It is the time-varying realignment of dipole moments, when immersed in a time-varying electric field, that gives rise to the displacement current. Thus we can see the displacement current as a movement of real charge; the charge, however, is a bound charge as opposed to a free charge.
Now in freespace, the polarization vector is identically zero, thus (taking the freespace permittivity to be unity) D=E. Clearly then, what is called the displacement current has nothing to do with an actual current, but is a pure time-varying electric field. But seeing that we have already named Maxwell's correction to the Ampere law as the displacement current, we might as well keep calling it that (or so some would argue). Really, its a matter of taste.
I have already answered this part in my reply to rbj with my questions below. I can't edit my old posts so I'll appreciate if you'll read both my later replies as well as the earlier posts. As for the fact that Ampere's and Biot-Savart's law follows from one another, I am aware of that. I was only saying that the Biot-Savart law gives us a more explicit vector equation of B due to I, in comparison to Ampere's.
How does this answer the questions
1. Is every time-varying E-field would be associated with a displacement current D?
2. Are there any cases whereby you have a varying E-field but no associated displacement current?
3. If the answer to 2 is yes, then would there be a B field induced?
These are just yes/no questions. I don't see how you have answered them.
Anyway, here's what Wikipedia says:
http://en.wikipedia.org/wiki/Em_waves#Theory said:
According to Maxwell's equations, a time-varying electric field generates a magnetic field and vice versa. Therefore, as an oscillating electric field generates an oscillating magnetic field, the magnetic field in turn generates an oscillating electric field, and so on. These oscillating fields together form an electromagnetic wave.
But since it's Wikipedia, I'll leave it to the experts to verify it. Otherwise it answers all of my questions.
I believe I answered all these questions in my previous post. When asking a question, you learn nothing by just getting a yes or no response; hence my lengthy response. But, to be explicit:
1) Well first off D is not the displacement current, it is the electric displacement (sometimes called the flux density). The time-derivative of D is the displacement current. In principle, there is nothing wrong with talking about the D-field in freespace, but since it is equivalent to the E-field ( [tex]D=\epsilon_0E[/tex] ), there really is no point.
As I said before, whether you wish to call the time-derivative of the electric field in freespace a displacement current or not is really just a matter of taste.
2) See above.
3) As you Wikipedia article states, a time-varying electric field induces a time-varying magnetic field and vice-versa. This is the mechanism by which light propagates.
Thanks, got it. Should have read your post more closely. I was just trying to be sure I understood it correctly.
I think it just may have been your choice of wording in your first post that may lead some to confusion. To make it clear, Ampere's law does, in fact, state that a current induces a magnetic field. In principle, it is a fundamental law of nature. In practice, however, Ampere's law is not always so easy to play with and there are time when deference to the Biot-Savart law gives a simpler way to reach a solution for the magnetic field.
Hi everyone, thanks for all the input, even though it has kind of deviated from the intention of my original question.
Perhaps the questions I really should have asked are :
1. Does the movement of charges directly result in a displacement current (varying E-field)?
3. Can an electric current induce a magnetic field if there was NO consideration/existence of a displacement current?
Ultimately, from cabraham's post, I assume it becomes pointless to question whether moving charges induce a time-varying magnetic field which then induces a time varying E field (Faraday's), or moving charges have a time-varying electric field which then induce a B field (Maxwell-Ampere).
Thanks.
Well now your line of questioning is getting a bit more complex. It comes from the upper-level idea that "there is really no such thing as magnetostatics." What this means is that what is usually taught as "magnetostatics" should strictly be called magneto-quasi-statics. This, as you have said, is because a steady current is really a movement of charge which follows from it time-variances in the fields. But, we can often neglect these effects since they would add only the smallest of corrections (which is good because it is so much easier to write "magnetostatics").
To answer your questions:
1) Yes, the movement of charge implies modification in the electric field, but for a steady current, this can often be neglected. Note, however, that an AC current will induces an AC B-field by Ampere's law which, in turn, will induce an AC E-field by Faraday's which, in-turn, will induce an AC B-field by Maxwell's correction to Ampere's law which, in-turn, will ...
3) Sure. This is just Ampere's law without Maxwell's correction.
I'm getting the impression from some of the sources that I've read (Wikipedia and others) that this results in an electromagnetic wave. Does this explain why wires heat up or something? I guess not, since clearly Joules heating occurs in DC current flowing in wires. But if not, what happens to the EM waves?
I have trouble with the term "displacement current". Maxwell used it as a cheat, and it has no physical meaning. The example I always see is a charging parallel-plate capacitor: if you try Ampere's law with your loop between the plates, you get a nonsensical result because there is no current enclosed. If your loop encloses the wire connected to the plate, you get a sensible answer. But Ampere's law shouldn't depend on what loop you choose. So Maxwell conceived a "displacement current" which flowed between the plates and fixed this discrepancy. Nowadays we realize that it's not just moving particles which create magnetic fields, it's changes in the electric fields which do it, and furthermore, these two fields are inextricably intertwined.
For Defennder: I think that normal DC Joule heating also produces EM waves; they are in the infrared region. In the case of extreme Joule heating, like in a small length of thin nichrome wire (or imagine a DC toaster oven if you want), the energy of the EM waves is high enough to be in the visible spectrum.
You account of the history, to my knowledge, is correct; however, to say the displacement current has no physical meaning is incorrect. I will refer you back to my https://www.physicsforums.com/showpost.php?p=1833860&postcount=10".
Yes, direct application of Fariday's law and the Ampere-Maxwell law in a source-free region is sufficient to explain the prorogation of light. This does not directly explain why wires heat up though; Joule heating does (as you brought up).
I want to point out though, Joule heating will occur in both DC and AC conditions (ever use a hair dryer?). Joule heating occurs because you are flowing a current through an element that has a natural resistance to the flow of current. Microscopically, it is due to electron collisions that give up energy to the material lattice; we perceive this as heat.
So is it accurate to say that in AC conditions, heating occurs through both electron collisions with the lattice and EM waves induced by time-varying fields, whereas in DC conditions they only arise due to the former? (I am aware that heat itself would give off EM waves in DC, but this is due to phonons and not EM wave induction).
I think you're starting to mix up several concepts. First off, an EM wave is, by definition, a time-variance in the electromagnetic field. The induction of either electric or magnetic field from the other allows us to speak of it simply as a single entity.
Second, remember from thermodynamics that heat is simply energy. Heating occurs because of some mechanism that increases the energy of atoms in a material. Heat itself cannot emit light. What you may be thinking of is that a "hot" body (i.e. one that is hotter than absolute zero) does emit light. This is due to atomic transitions and not directly due to phonons.
Right, so let's drop the term phonons and use "electron collisions" in the lattice instead. But if as I posted earlier, an EM wave is created by an AC current, does such a wave contribute to the heating up of the wire?
Well if we're talking about a simple AC circuit, it's the AC voltage that drives the current. In principle, I suppose attenuation of the electric field in the wires and circuit elements could cause heating, but for most practical purposes I would think that this is completely negligible compared to standard Joule heating.
Would you please elaborate on "it's the AC voltage that drives the current." Are you referring to the fact that most every day ac power sources are constant voltage, and not constant current sources? If the ac power source is constant current, then what? Just wondering what you're saying. Thanks in advance.
Claude
That's pretty much what I meant by saying that the voltage drives the current. I suppose we can get into technicalities or very specific examples. But even then, isn't a current source ultimately controlled by a source voltage?
I would say no. A current source outputs whatever voltage necessary to sustain a fixed current value, and vice-versa for a voltage source. Neither one "drives " the other. Both are driven by the work being done. An AC generator, for instance, converts mechanical power to electrical. The current and voltage are both driven by the mechanical power, the product of torque and speed. Voltage doesn't drive current, nor the converse. BR.
cabraham:
Your example of an AC generator doesn't really follow from the previous discussion nor is your description completely accurate. So that we don't confuse anybody trying to learn from this thread, we'll disregard it for now.
I don't follow your line of thinking in your previous post. Current flows because of the application of a voltage. You place a voltage across a resistor and it will drive the current.
From a more fundamental viewpoint, current is the movement of charge. Charge carriers (e.g. electrons) are compelled to move when immersed in an electric field. Electric field is just the (negative) gradient of the electric potential (i.e. voltage). When you apply a voltage you are, in essence, applying an electric field. Thus, it is the voltage that drives the current; not the other way around.
In a current source, the output current is determined by the source voltage and the circuit elements making up the current source. That is why I said that even in a current source, you are still ultimately driving the current with a voltage.
Sorry to the OP for getting grossly off the original topic. I hope that by now everything makes sense.
cmos said:
cabraham:
cmos:
You make statements having no basis at all. E field can be expressed as the negative of grad V, but V can be expressed as the line integral of E. Also, J = sigma*E, where J is current density, sigma is conductivity, and E is electric field intensity. There is a functional relationship between J and E, E and V, etc. Also, an electric field cannot be set up unless current and voltage are both present. To change the E field requires work since E fields store energy. Work takes time. The work divided by the time is power. For non-zero power, both I and V must be non-zero. These equations do not imply "causality". Also, E = -grad V only holds for charged particles. For induction in time changing case, E = -dA/dt, where B = curl A. The relation between E, H, I, and V is mutual inclusion. They cannot exist independently, and neither drives the other. Einstein in his 1905 "On The Electrodynamics Of Moving Bodies" stated E and H as having no pecking order. Also, there is no such thing as "applying a voltage". Read up on transmission lines.
Regarding current sources, a photodiode across the op amp input terminals is a constant current generator proportional to incident light. There is no "voltage" controlling said current. An inductor tends to exhibit constant current behavior. In a switched mode power supply, when the power switch is turned off, the inductor de-energizes through the output rectifier and load as well as current sense resistor. The current in the inductor is the fixed quantity and the voltage developed across the current sense resistor is determined by the current and the resistance. In this case the "current drives the voltage". A resistor can be driven either way. There is no pecking order.
The notion that current is driven by voltage is just a prejudice. It stems from the fact that all batteries and generators in common everyday use are designed and optimized to function in the constant voltage mode. We can get sloppy and easy fall into the "apply a voltage and get a current" misconception.
  • #31
Hi cabraham,
I don't why you choose to belabor this point repeatedly as you have done so in other threads. The conventional understanding is that charges move under an electric field (they accelerate but effectively move at a constant drift velocity due to electron collisions) which is associated with a potential difference, and it is the rate of net movement of these charges through a given plane (flux) which we call current.
And it's not true you cannot have an electric field without current, simply consider a fully charged capacitor in a circuit. The current flowing through that loop is zero when it is fully charged, yet clearly there is an electric field in the di-electric. I'm not talking about displacement current here because D here is time-invarying. The same thing can be said of any case in which there is a general separation of positive and negative charge. E-field yes, pd yes, current no.
Consider a cell then. What drives the current in the circuit when the cell is connected across a bulb or resistor? Certainly the current isn't already present before you set up the circuit.
  • #32
Defennder said:
Hi cabraham,
Defennder,
I've explained thoroughly and you just aren't listening. Regarding the charged cap with E field and no I, I've already stated the case. In order to change the E from zero to non-zero, a current was needed. As far as a separation of pos and neg charge, how is that accomplished without current? Also, a current loop with no loss will susain current indefinitely with no E field. Inductance tends to sustain current, but voltage is needed to change current.
The fact that charges move in an E field is not under dispute. You would mislead all to believe that the voltage is solely responsible for the E field, which is incorrect. A static E has no current, but a static charged cap didn't get that way without a current momentarily. ALso, per our good buddy "Eli the ice man", take a cap uncharged, a battery and a switch. At t=0, close the switch. The cap voltage at t=0 is zero but the current is non-zero. The current is present in the cap before the voltage. Eli the ice man has NEVER LIED to us.
Regarding a cell circuit, you don't seem to understand transmission lines at all. Take a cell, a switch, a t-line (2 parallel conductors), and a load resistor. If the switch is closed at time t = 0, the relation between E, I, and V in the load is as follows. At t = 0, the t-line characteristic impedance is Zo, so that the current at t = 0 is Vs/Zo (Vs = cell voltage). This current I = Vs/Zo propogates towards the load. The E field, I, and potential diffreence V are all simultaneous and in unison. At t = 0, all 3 are established at the source end, and travel together. When the E-I-V traveling wave (H is also present) arrives at the load, the relation is Il = Vl/Rl, where Vl = load voltage, Rl = load resistance, Il = load current. If the load resistance Rl matches Zo, then I = Vs/Rl. Otherwise reflections take place and the system eventually settles.
Point is that the load resistance is characterized by Ohm's law, J = sigma*E. The J (current density, A/m^2) and the E arrive in unison.
One does not "drive" the other.
As far as my "bringing up the issue" goes, I didn't start this. The thread was moving along nicely when out of nowhere "V drives I" was brought in. Regarding Ampere's law and displacement current, I would rather stay focused solely on that, as it is the OP's question.
The notion that V drives I is a result of life long use of cells, generators, and electronic bench top power sources that are optimized for constant voltage mode of operation. Some erroneously conclude that constant V and variable I is Mother Nature, when it really is a man made condition. If you were to pedal a bicycle driven ac generator you could monitor the speed, torque, current, and voltage. As the load changes, adjusting the right mechanical quantity allows control of a corresponding electrical quantity. If you force a constant torque, you then adjust the speed so that constant current is maintained as the load varies, resulting in variable voltage. Holding the speed constant, and varying the torque results in constant voltage and variable current, which is very familiar to us all.
  • #33
Hi cabraham,
I'm a little busy these few days and may not have time to respond to you promptly, so you may have to wait a little longer before getting a response. Thanks for your understanding.
Now, you claim, among other things that you can't get I without E and V and vice versa. This simply isn't true. I've said earlier that E and V can be obtained by mere charge separation. One poster pointed out some time back in another thread that if one considers the triboelectric phenomenon, that of charging insulators by rubbing them together, you get a separation of charges, and hence a potential difference and electric field without the aid of a current. Now of course you may say that any movement of charges would constitute a current and the triboelectric effect requires a movement of charges in order to obtain a separation, but that is a very loose generalisation of the term current.
Consider this then: A neutral body attracts charged particles, by virtue of gravitational attraction; would you consider the subsequent movement of charges to be a current? This would depend on whether you consider movement due to electric field "current" or just any movement of a charged body. By Newton's 1st law, a charged body (with mass) would travel at a constant velocity if no net force acts on it. Would you consider this current as well? Suppose you do, then this is further evidence that current exists indepedent of voltage and E-field; the E-field associated by the moving charge does not affect itself.
And with regards to there being a current without a driving emf, consider the photocurrent from the photoelectric effect. Photocurrent flows in the photoelectric setup without an applied emf or even one in which the applied emf is set up in opposition to the photocurrent.
This shows clearly that one can de-couple E-fields, V and current density. Your point about there being a non-zero current at t=0, but where V=0 across the capacitor in an RC circuit misses the point. The voltage across the potential difference is zero, but there is clearly a potential difference and hence voltage across other circuit elements.
Thirdly, my point earlier about a simple cell circuit was assuming a quasi-static electric setup where the wires are assumed to be ideal, so I don't know why you're bringing in propagation in a transmission line when I did not bring that up in the first place.
Anyway thanks for posting. I have learned more about this and have also clarified certain doubts after I revisited some material I had semi-forgotten.
  • #34
Defennder,
What part of the following am I not making clear:
I and V can exist independently only under static conditions. A charged cap or energized inductor without loss demonstrates that either can exist on its own. Neither is the cause. By definition a cause comes first, and the effect can never exist in the absence of the cause. I does not "drive" V, and V does not drive I.
I and V cannot exist independently under dynamic, or time-varying conditions. Regarding the charging of a cap, of course there is voltage elsewhere in the circuit. But, wherever there is voltage there is also a current, except for the cap at t = 0. In a resistor they cannot be decoupled, not even at dc (static). But if the source is a lossless inductor, and the switch across it is opened, the inductor will energize the capacitor. Here, the inductive energy is driving the cap, and then when the inductor empties, the cap drives energy back into the inductor. "I drives, V, V drives I, I drives V," etc.
The "driver" is energy, not I or V. Now with the photodiode, I mentioned it to show that I, the photocurrent, is NOT driven by a voltage. You then proceed to lecture me on exactly what I originally said. Read my previous post. When you said that V drives I, I brought in the photodiode to demonstrate otherwise. Now you're telling me that I and V (and E as well) can be "de-coupled", the exact opposite of your original premise. Once again, what "drives" I in a photodiode is *energy* in the form of photons. In a pd, photons incident on the surface transfer energy to the lattice and electrons are elevated from valence to conduction. In an LED, the opposite takes place. The forward current is set up, and electrons dropping from conduction to valence incur an energy decrease. Energy is conserved in the way of photon emission. Once again, the driver is energy.
Changing your position is not a bad thing necessarily. I think it is clear to all reading this, that "apply a voltage and get a current" is just a prejudice based on faulty intuition. I'm glad you don't completely buy into it. You seem to have a good understanding of the photocurrent process. I think we can agree that energy is the key player, or prime mover.
As far as decpupling goes, under dynamic conditions, no one has ever been able to decouple, I, V, H, and/or E. From Ampere to Faraday to Maxwell to Einstein it has been that way. Who are we to argue?
  • #35
cabraham,
Perhaps you should reread your OP which spawned my response. Here it is in part:
I responded initially that V and I are independent (I did not make the distinction between time-varying and time-invariant conditions)
I brought up the photocurrent, as you did, though I think I might have missed your initial mention of it just to show that I and V are independent (as you did).
The point I was trying to make was that saying "V drives I" is not incorrect, but "V always drives I" is incorrect, as I mentioned earlier about separation of charges and photocurrent. Saying that "V drives I" does not preclude "I drives V" is true as well. Just consider this: A force is exerted on a mass and it accelerates by Newton's 2nd law. Suppose someone says that the force causes the mass to accelerate. Would you then argue that the person is indeed sinfully wrong, since the mass accelerates at the same time the force is applied to it? I have argued analogously there is nothing wrong with the notion "V drives I" here. Oddly enough, you have accused me of changing my stand, which is patently untrue.
It's a good thing you finally clarified your point here. It wasn't evident in your original post. I don't think we are in disagreement on this, only the impression that we disagree.
I and V can exist independently only under static conditions...I and V cannot exist independently under dynamic, or time-varying conditions.
  • Electromagnetism
