Artificially Induced subcritical Heavy Ion fission
In summary, the conversation discusses the idea of using heavy nuclei to induce fusion and produce energy. The main concept is to create an unstable isotope through partial fusion, which would then release energy when it eventually fissions. This process is compared to pushing a rock off a cliff to increase the chances of it falling and releasing potential energy. However, some doubt the practicality of this idea due to the inefficiency of current methods for producing fast moving ions.
maxmc1027
This is an idea I had and felt it worth publishing. The reason fusion is so difficult is because the particles are so light, small, and have difficulty overcoming the coulomb barrier. Well I got to thinking and noticed that it'd be a lot easier to get heavy nuclei to fuse, but naturally they'd be incredibly unstable. Then it hit me, incredible instablility is a GREAT thing! When two heavy nuclei collide and neutrons/protons join or fall off, an unstable ion is inevitably created. Think about it, each atom on the periodic table, including isotopes, is usually stable for the most part, even radioactive elements(stable in terms that they don't randomly explode into several different atoms). When two lead atoms for instance are ionized and accelerated towards each other, the inertia alone would be enough to overcome the coulomb forces, not to mention increased chance of impact due to size. While the collision products are almost completely incalculable, the resulting instability will inevitably result in fission to more stable elements. What's even better is that even these reaction products, radioactive or not, can be reused and accelerated again into something like a lead atom.
An example of how this works would be to think of a rock atop a tall cliff. The rock at this point has a lot of potential energy, but it isn't near the cliff and thus no energy will be produced. The process I speak of is equivalent to pushing the rock to the edge, increasing the chances of falling and thus a much higher chance to reach a ground state(releasing energy in the process). Lead is a stable atom, but only slightly so, a couple more protons or neutrons and it becomes unstable and fissions. I'm not sure what sort of radiations or reaction products it'd give off, but I do have an experimental setup in mind to make it happen. I'd like to see some responses to this topic, and maybe a reason why I don't see ideas like this anywhere else. Thanks for reading.MaxP.S. If this didn't make sense please say something. I'm not great at explaining things =P
This sounds to me very much the basic idea used to produce superheavy elements in various accelerators worldwide. For example to produce element 114, plutonium-242 atoms are bombarded with calcium-48 ions. The cross section for this reaction (probability of a reaction) is however very small and it takes a six weeks experiment to produce a single atom of element 114. For more information see the section on superheavy elements in http://www.nucleonica.net/poster.aspx
The difference is that the scientists doing those experiments are specifically trying to create one element, and even one proton missing will completely ruin the whole collision. (thus it takes weeks) The purpose of my idea is to purposely induce an unstable isotope through partial fusion. The odds of a stable isotope formed through fusions of heavy atoms is almost non-existent, that's another reason why it takes so long to get the specified atom. Anyway, when the unstable isotope inevitably forms, no energy is released, it's only when the instability actually fissions the atom that it releases the energy. I hope this kinda cleared things up, and please tell me what you think, I'm just bouncing ideas around.
Max
I understand your idea, but I don't think the numbers are practical. The methods we have for producing fast moving ions are very inefficient (converting from electrical energy to kinetic energy). I don't think that you would ever get sufficient energy out to produce net usable energy.
Accelerators have been used to produce fusion in light element, the issue has always been that it take more usable energy to make it happen than can be extracted from the reaction.
You could run the numbers to figure out the required minimum collision energies for heavy nuclei to over come the coulomb barrier. That would give a starting point to see what kind of acceleration device you would need to achieve those energies. Then you could look at the efficiency of those systems.
Max
Actually, it is rather difficult to 'fission' elements below Th. In most cases, one will get a spallation reaction, and usually more energy is put in per reaction than obtained form the subsequent reaction. Fission systems work because of the neutrons which do not need energy input from an accelerator.
What is Artificially Induced subcritical Heavy Ion fission?
Artificially Induced subcritical Heavy Ion fission (AIHIF) is a process in which a subcritical mass of heavy ions is bombarded with high-energy particles, causing it to undergo nuclear fission. This process can be used to produce energy or to create new elements.
How is AIHIF different from traditional nuclear fission?
AIHIF differs from traditional nuclear fission in that it does not require a critical mass of fissile material to sustain the chain reaction. Instead, the heavy ions are bombarded with particles that cause them to split, releasing energy and creating new elements.
What are the potential applications of AIHIF?
AIHIF has potential applications in both energy production and nuclear research. It could be used to produce energy in a similar way to traditional nuclear reactors, but with less risk of a meltdown. It could also be used to create new elements for scientific research or medical treatments.
What are the safety considerations for AIHIF?
As with any nuclear process, safety is a major concern for AIHIF. The high-energy particles used to induce fission can be dangerous if not handled properly. Additionally, there is a risk of radiation exposure and the potential for radioactive waste to be produced.
What are the challenges facing the development of AIHIF?
One of the main challenges facing the development of AIHIF is the technical difficulty of creating and controlling the necessary high-energy particles. The process also requires precise and complex equipment, making it expensive to implement. There are also ethical considerations surrounding the use of nuclear technology and potential misuse of AIHIF for weapons development.
  • Nuclear Engineering
12K
  • Atomic and Condensed Matter
10K
  • Electrical Engineering
