Hooke's Law / Potential Energy
In summary, the jumper's body mass stretches the elastic cord by 1.5 m, and he experiences a maximum acceleration of 10 m/s2.
twotaileddemon
260
A daredevil plans to bungee jump from a balloon 65.0 m above a carnival midway. He will use a uniform elastic cord, tied to a harness around his body, to stop his fall at a point 10.0 m above the ground. Model his body as a particle and the cord as having negligible mass and obeying Hooke's law. In a preliminary test, hanging at rest from a 5.00 m length of the cord, he finds that his body weight stretches it by 1.50 m. He will drop from rest at the point where the top end of a longer section of the cord is attached to the stationary balloon.
(a) What length of cord should he use?
(b) What maximum acceleration will he experience?
F_cord = -kx
F_gravity = mg
U_cord = .5kx^2
U_body = mgh
Uh.. well, I searched the forum and someone had asked a strikingly similar question. From what I read, I should find k by setting the F_gravity to the F_cord, so mg = -kx
In that case.. k would be -mg/x
Then, the potential energy lost from traveling from 65 m to 10 m should equal the potential energy of the cord at 10 m. Thus,
mgh_f-mgh_i=.5kx^2
mgh_f-mgh_i = .5(-mg/x)x^2
h_f-h_i = -.5x
-55 = -.5x
110 = x
... but that would be the length the cord stretched... right? And that would be... the farthest distance it could cover.. Then, the length of the cord would be 110 m?
Then.. to find the max acceleration, ... I'm quite confused. I know the only forces acting on the person is due to gravity and that in the spring.. but what acceleration is there?
Thanks for any help
The balloon is at 65 m, so the length of the cord must not be 110 m or the jumper goes splat.
OK, think about the problem.
Falling from 65 m to stop at 10 m, the jumper plans to fall 55 m.
The jumper will 'free-fall' a distance x, the length of the cord, before it starts stretching, so the jumper has kinetic energy = mgx at this point. Then the jumper must decelerate to stop at 10 m from the ground or total distance of 55 m.
The jumper then recoils, subject to a force F = kd, where d is the extension of the cord from equilibrium, and k is the spring constant.
Determine the spring constant from this.
How? We have no force variable given
I know that F = -kx, and U = 1/2kx^2.. but...
What is weight? If k is in terms of m, the do what one did with
mgh_f-mgh_i=.5kx^2
mgh_f = mgh_i = .5kx^2
k = 2mgh/x^2...?
the weight should just be.. mg?
so mg = kx?
k = mg/x
so mg = kx?
k = mg/x
Be careful there, the x needs to be the displacement of the spring/cord.
The 5 m length stetches 1.5 m, so k(1.5m) = mg.
using k = mg/1.5 then...
mg(hf-hi) = .5kx^2
mg(hf_hi) = .5(mg/1.5)x^2
h = .5x^2/1.5
3(55) = x^2
x = 12.84 m.. which still doesn't make sense, because the length shold be much greater
Try writing the energy balance equation.
Assuming no dissipative forces, the energy in the spring must equal the GPE of the free fall (which equals the kinetic energy of the jumper before the cord stretches) and the work done by the cord when it stretches.
Now the cord has length L which one is trying to find, so the jumper freefalls this length (height). Then the cord stretches, some length d, and decelerates the jumper to a stop (v=0). BUT, since the stretched cord must stop at 10 m, and the jumper started at 65 m, the stretched core must have length 55 m, so the displacement d of the core must be 55-L.
See where that takes one.
Think about an elevator slowing down. Think of g+a.
What is Hooke's Law?
Hooke's Law is a physical principle that states that the force required to extend or compress a spring by some distance is directly proportional to that distance. It describes the relationship between the force applied to a spring and the resulting displacement of the spring.
What is the formula for Hooke's Law?
The formula for Hooke's Law is F = -kx, where F is the force applied to the spring, k is the spring constant (a measure of the stiffness of the spring), and x is the displacement of the spring from its equilibrium position.
What is potential energy in relation to Hooke's Law?
In the context of Hooke's Law, potential energy refers to the energy stored in a spring when it is compressed or extended. This energy is potential because it has the potential to do work when the spring returns to its equilibrium position.
What is the difference between elastic potential energy and gravitational potential energy?
Elastic potential energy is the energy stored in a spring or other elastic material, while gravitational potential energy is the energy stored in an object due to its position in a gravitational field. Both types of potential energy involve the storage of energy, but their sources and mechanisms are different.
How is Hooke's Law used in real-world applications?
Hooke's Law is used in many real-world applications, including the design of springs for various devices such as mattresses, trampolines, and car suspensions. It is also used in the design of shock absorbers and measuring devices such as force gauges and weighing scales.
