Register to reply
Chem Eng rate of heat transfer qts
by tcaldwell
Tags: chemical, engineering, heat, reynolds, transfer
Share this thread:
tcaldwell
#1
Mar30-13, 11:47 AM
P: 7
Heat Transfer Qts
Engine oil at 60 oC flows over flat plate whose temperature is at 20 oC with a velocity of 2 m s-1. The length of the plate is 5m. What is the film temperature and the rate of heat transfer per unit width of the entire plate?
Additional information (at the film temperature):
Thermal conductivity of oil: Prandtl number:
Dynamic viscosity:
k1 = 0.144 W m-1 K-1
Pr = 2870
u = 0.21 kg m-1 s-1
Help!!!!!!
Can't get a Reynolds number without density..
Is film temperature 40 degrees Celsius????
Phys.Org News Partner Engineering news on Phys.org
Future phones to use blood and speech to monitor HIV, stress, nutrition
Neuron circuit may enable pitch perception applications
Quasi-distributed temperature sensors from draw-tower fabrication technology
tcaldwell
#2
Mar30-13, 05:33 PM
P: 7
Qts solved...
Was right..lecturer wrong AGAIN..was then provided with engine oil density in qts
Register to reply
Related Discussions
Heat Transfer: Calculating heat transfer rate? Engineering, Comp Sci, & Technology Homework 4
Rate of heat transfer / specific heat General Physics 2
Heat transfer rate Materials & Chemical Engineering 6
Heat transfer rate Mechanical Engineering 5
Rate of heat transfer and heat conductors General Physics 3
