Electromagnetic systems always dissapative?
In summary, the scenario described involves a system of charged particles confined to a small region, which will exert forces on each other and cause accelerations, leading to the emission of radiation. As the particles continue to move away from each other, their accelerations will decrease and they will retain some kinetic energy indefinitely. This process ultimately results in the transfer of energy from the electromagnetic field to the kinetic energy of the particles.
HomogenousCow
737
213
Imagine a blob of continuous charge in vacuum, the fluid elements will exert a force on each other and thus radiate away energy to infinity and thus be forever lost, does this mean that charged continuums will always lose all of its energy?
Well...
1) surface tension of the fluid in question will definitely hold it onto a certain level.
2) the fluid particles will perform work on each other so it would be reasonable to say that they will acquire Kinetic Energy. Intrinsic potential energy of the system will however be lost...
that's all i can say for now... can you give the the specifics of the problem?
Well for simplicity sake let's say you have n charged particles confined to some small region, they will exert a force on each other causing accelerations which in term causes energy to be radiated off to infinity. My question is, once all the energy at the start have been lost what will the particles do?
The amount of energy in the system will not change. The energy starts as potential (prior to release) and gets converted to kinetic (as the particles accelerate away from one another). It is not a matter of "losing" energy, but a change from potential to kinetic energy.
I am talking about electrodynamics, potentials are not well defimed here
accelerating charges will radiate away their energy
Accelerated charges radiate electromagnetic waves. From the point of view of the particles alone, the process is dissipative, because the charges loose energy when being accelerated. Of course the total amount of energy of a closed system of charges and the electromagnetic field is conserved. The energy lost by the particles is carried away by the (radiative part of the) electromagnetic field.
You should be warned that the quantitative understanding of this issue within classical electrodynamics is a very tough subject. It has been solved for practical purposes only quite recently. This is treated in great detail in the marvelous book
Fritz Rohrlich, Classical Charged Particles, World Scientific, 2007
Oh, so I'm assuming as t approaches infinity, the particles shoot off away from each other at constant speeds?
Say we begin with n particles with charge of the same sign, initially kept still by other forces, and assume that fields are given by retarded solution of the Maxwell equations. Let's assume that the system has rest energy equal to sum of rest energy of the particles and the energy of the electrostatic field.
The particles will repel each other. After the constraints are removed, the particles will accelerate and produce radiation, which will propagate away to all directions. After a while, the particles will be all far away from each other, so the accelerations will be smaller. They will continue to move almost uniformly and will most probably retain some kinetic energy indefinitely. As a result, some energy has thus been transferred from the EM field to the kinetic energy of the particles.
1. What is an electromagnetic system?
An electromagnetic system is a physical system that involves the interaction of electric and magnetic fields. This can include a wide range of systems, from electronic circuits to electromagnetic radiation.
2. What does it mean for an electromagnetic system to be dissipative?
A dissipative electromagnetic system is one that loses energy over time. This can occur due to resistive effects, such as the conversion of electrical energy into heat, or through the emission of electromagnetic radiation.
3. Why are electromagnetic systems always dissipative?
This is due to the fundamental laws of thermodynamics, which state that energy cannot be created or destroyed, only converted from one form to another. In an electromagnetic system, energy is constantly being converted and dissipated.
4. Can dissipative effects be minimized in electromagnetic systems?
Yes, dissipative effects can be minimized through the use of materials with low resistance, efficient design of circuits, and proper shielding to reduce electromagnetic radiation.
5. What are some practical applications of understanding dissipative electromagnetic systems?
Understanding dissipative effects in electromagnetic systems is important for designing efficient electronic devices, such as computers and smartphones. It also has applications in fields such as power generation and transmission, where minimizing energy loss is crucial for efficiency.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electrical Engineering
