Projectile motion with air resistance
In summary, bodies without air resistance will travel in a parabola, but when air resistance is included, the curve traveled will depend on factors such as shape and mass distribution of the body, orientation, and rotation. Laminar flow can also affect the curve, but this is only in very specific circumstances. In most cases, there is no simple closed form for the curve with air resistance, except in certain extraordinary cases.
guysensei1
31
Without air resistance, bodies travel in a parabola.
What is the curve that is traveled when air resistance is included?
I found that there are different air resistances, which curves would these types produce?
With air resistance, you don't get a nice curve (such as a simple parabola). I don't think there is a special name for all those types of curves you can get.
For air resistance proportional to the velocity, you may derive analytical expressions for the curve, that typically(if I remember correctly) involves the hyperbolic functions and their inverses.
Unfortunately, for the vast majority of cases, this is not a physically realistic solution, since air resistance is proportional to the square of the velocity (and there is no nice, analytical solution for that).
Your point being?
arildno said:
Your point being?
My point being that if you care about physical reality, rather than mathematical prettiness, the existence of a solution for drag proportional to velocity isn't terribly useful or relevant.
Any relevance to my first post?
Some objects (mainly small objects) can have laminar flow where drag grows linear with the velocity.
Unfortunately, their typical timescale is so short that you cannot really call their motion "falling".
This question is not well posed. When there is air resistance, there is also lift. Both depend on the shape and the mass distribution of the body, and its orientation and rotation. These effects can be very significant, in which you can certainly convince yourself by comparing the flight of a glider and a ball.
It's not so much that the flow is laminar, it's that the flow (for very low reynolds numbers) is dominated by viscous, rather than inertial forces. Laminar (but inertially-dominated) flow still has drag that scales as v2. As you noted, in air, the only time you would have viscous-dominated flow is for very small, slow moving objects. There are however some physical cases where this could occur at larger scales. In a fairly viscous fluid (corn syrup, for example), a BB, marble, or even golf-ball sized object could have drag that scales with v rather than v2. Most of the time, though, when people ask about drag, they aren't thinking of a marble falling through corn syrup :smile:
Short answer: there is no simple closed form except in very extraordinary circumstances.
Quite so.
And?
It doesn't follow from this that what I wrote in my post was wrong. I pointed out that there were cases with air resistance in which analytical expressions could be found, I did not say that that was generally true.
1. What is projectile motion with air resistance?
Projectile motion with air resistance is the motion of an object through the air, affected by both gravity and air resistance. It is a combination of both vertical and horizontal motion.
2. How does air resistance affect projectile motion?
Air resistance acts in the opposite direction of the object's motion, slowing it down and altering its trajectory. This is due to the friction between the object and the air molecules it encounters.
3. What factors affect the amount of air resistance on a projectile?
The amount of air resistance on a projectile is affected by its speed, surface area, and shape. Objects with larger surface areas and irregular shapes experience more air resistance.
4. How is air resistance calculated in projectile motion?
The calculation of air resistance in projectile motion involves taking into account the object's velocity, density of the air, and its cross-sectional area. This can be done using mathematical equations or through experimentation.
5. How does air resistance impact the trajectory of a projectile?
Air resistance causes a decrease in the vertical acceleration of a projectile, leading to a flatter trajectory. It also causes a decrease in the horizontal component of the object's velocity, resulting in a shorter range.
  • Electromagnetism
  • Mechanical Engineering
  • Classical Physics
