Register to reply
Derivative discretization with fixed boundary condition
Share this thread:
debsankar
#1
Sep23-13, 08:31 AM
P: 11
Hi all,
It may be a trivial question. But, if I have a PDE of variable u(x,t)
[itex]\dot{u} = f(u,\partial_x{u},..)[/itex]
with boundary condition :
[itex]u(0,t) = u(L,t) =0.[/itex]
Now I need to calculate
[itex]\partial_x{u}[/itex]
for that can I define the discretisation differently only on the boundary (forward / backward)?
And inside the domain(1D) I am using central difference for the perpose.
Does doing this introduce any inconsistencies in the process? Or if there is any other
standard method of doing this...
please let me know.
Regards.
Phys.Org News Partner Physics news on Phys.org
Researchers demonstrate ultra low-field nuclear magnetic resonance using Earth's magnetic field
Bubbling down: Discovery suggests surprising uses for common bubbles
New non-metallic metamaterial enables team to 'compress' and contain light
AlephZero
#2
Sep23-13, 12:35 PM
Engineering
Sci Advisor
HW Helper
Thanks
P: 7,108
Quote Quote by debsankar View Post
Yes, that's a basic problem with finite difference methods.
The difference estimates of the derivative at the interior points are second-order accurate. If you take a forwards or backwards difference using two grid points at the boundary, that is only first order accurate.
See here for better ways to do it: http://www.scientificpython.net/1/po...rent-ways.html (these should be in any good book on FD methods).
Chestermiller
#3
Sep23-13, 08:43 PM
Sci Advisor
HW Helper
Thanks
PF Gold
Chestermiller's Avatar
P: 5,175
One way of doing this is to use a fictitious point at L + Δx in the discretized central difference version of the partial derivative of u with respect to x in the boundary condition. You then substitute this discretized relationship involving the fictitious point into your discretized PDE. This preserves the second order accuracy at the boundary.
debsankar
#4
Sep24-13, 04:32 AM
P: 11
@ AlephZero >>
Thanks for the reference. I will describe a bit what I did for the completeness of the thread and also to
clear misconceptions if I have got any in this regard.
To calculate [itex]\partial_x{u} [/itex] at boundaries I use >>
[itex]\partial_x{u} = \frac{-u(x+2h)+4u(x+h)-3u(x)}{2h} + O(h^2) [/itex] at x=0
and
[itex]\partial_x{u} = \frac{3u(x)-4u(x-h)+u(x-2h)}{2h} + O(h^2) [/itex] at x=L
and
[itex]\partial_x{u} = \frac{u(x+h)-u(x-h)}{2h} + O(h^2) [/itex] for all 0<x<L
So all the discretization schemes are now second order accurate.
@Chestermiller >>
The 'ghost' points you refer to is useful if I have a condition like >> [itex]\partial_x{u} =0 [/itex]. But for the mentioned case its not clear to me what values I should take at the ghost points? because I don't have any condition on boundary value of the derivative. So I think
using second order forward and backward FD at the boundaries with first order central FD inside
is appropriate. Please let me know if I am missing something.
Regards,
Deb.
Chestermiller
#5
Sep24-13, 06:30 AM
Sci Advisor
HW Helper
Thanks
PF Gold
P: 5,175
@ AlephZero >>
and
and
@Chestermiller >>
Regards,
Deb.
To answer this question, I need to know more about the boundary conditions at the two ends. What are the boundary conditions in your particular problem?
debsankar
#6
Sep24-13, 07:07 AM
P: 11
du/dt=f(u,du/dx,..)
u(0,t)=u(L,t)=0.
This is the problem the thread started with.
Regards.
Chestermiller
#7
Sep24-13, 07:36 AM
Sci Advisor
HW Helper
Thanks
PF Gold
P: 5,175
Regards.
I'm sorry. I didn't read your original post carefully enough. I totally agree with what AlephZero said regarding using one sided difference formulas to get the normal derivative to second order accuracy.
Chet
debsankar
#8
Sep24-13, 07:59 AM
P: 11
Also there is another small confusion..
say I have an eq like this >>
[itex]\dot{u} = \partial_x{f(\partial_x{u})} [/itex]
and if my BC now is >>
[itex]\partial_x{u} = 0[/itex] at both ends for all time.
Now I will use the 'ghost point' method to calculate du/dx at the ends.
I will just make(in case i use central FD) >>
u(-1)=u(1) and u(n-1) = u(n+1)
this will give me du/dx =0 on boundary(i.e. for u(0) and u(n)) all the time.
But when I again calculate df/dx I will use the previously discussed method >>
@ AlephZero >>
To calculate ∂xu at boundaries I use >>
[itex]
\partial_x{u}=[−u(x+2h)+4u(x+h)−3u(x)]/2h +O(h^2) at x=0 \\
and \\
\partial_x{u}=[3u(x)−4u(x−h)+u(x−2h)]/2h +O(h^2) at x=L \\
and \\
\partial_x{u}=[u(x+h)−u(x−h)]/2h +O(h^2) for all 0<x<L \\
[/itex]
because, I cannot use ghost points for 'f' as I do not have the information of df/dx
at boundaries. Am I right?
Chestermiller
#9
Sep24-13, 11:36 AM
Sci Advisor
HW Helper
Thanks
PF Gold
P: 5,175
If you are specifying df/dx at the boundary, then you know df/dx. But please do me a favor. Write out your DF approximation to the rhs of your pde above for point n, taking into account the zero flux boundary condition.
Chet
debsankar
#10
Sep24-13, 12:11 PM
P: 11
@ Chestermiller
I will get back to this tomorrow, I got what you said...
actually you are right I also have df/dx values at boundary....as I have du/dx.
I will explain in details my equations and what I am getting.
goodbye till then.
AlephZero
#11
Sep24-13, 03:15 PM
Engineering
Sci Advisor
HW Helper
Thanks
P: 7,108
You don't need to make that assumption.
You can write two equations that include the "ghost point". One is the finite difference approximation to your PDE at the boundary point. The other is the finite difference approximation for the derivative at the boundary.
Then, you can eliminate the ghost point from those two equations algebraically, or you can solve the problem numerically including both the ghost points and the extra equations.
That is the third method in the link I gave. It may or may not give "better answers" than the second method - it depends on the particular equation and boundary conditions. (The link seems to say the third method will always give better answers than the second - but I'm not convinced about that).
Register to reply
Related Discussions
What does this boundary condition mean? Classical Physics 4
Types of boundary condition Differential Equations 0
Boundary Condition Calculus & Beyond Homework 7
Boundary conditions for wave fixed at one end Advanced Physics Homework 1
SHO with a fixed boundary Advanced Physics Homework 1
