Register to reply
Trigonometry on a transformer
by johann1301
Tags: transformer, trigonometry
Share this thread:
johann1301
#1
Apr22-14, 05:48 AM
P: 147
On a trafo i just bought, it says COS = 0,99. What does this mean?
Is there some angle involved in changing the voltage?
Phys.Org News Partner Engineering news on Phys.org
Future phones to use blood and speech to monitor HIV, stress, nutrition
Neuron circuit may enable pitch perception applications
Quasi-distributed temperature sensors from draw-tower fabrication technology
PhysicoRaj
#2
Apr22-14, 06:00 AM
PF Gold
PhysicoRaj's Avatar
P: 437
That is the 'Power factor'. To be simple, the ratio of actual power consumed to the product of voltage and current through the trafo is 0.99, it means.
See this:
http://en.wikipedia.org/wiki/Power_factor
PhysicoRaj
#3
Apr22-14, 06:02 AM
PF Gold
PhysicoRaj's Avatar
P: 437
Here's a simpler version:http://www.tvss.net/pq/pf.htm
jim hardy
#4
Apr22-14, 09:49 AM
Sci Advisor
PF Gold
jim hardy's Avatar
P: 3,636
trafo ?
http://www.trafo.co.in/
To your trig question:
cos-1(0.99) = 8.1 degrees
and that's the angle between primary side volts and amps at rated resistive load.
draw a right triangle with a hypotenuse of 1, base of 0.99 and an opposite side of 0.1424
this represents primary current at rated conditions with resistive load
small angle is 8.1 degrees
base is 0.99 units and is load current corrected for turns ratio
opposite side is 0.1424 units and is magnetizing current
hypotenuse is total current flowing into primary
so this transformer draws 14.24% magnetizing current.
Register to reply
Related Discussions
Trigonometry problem help Precalculus Mathematics Homework 0
Solving trigonometric equation Precalculus Mathematics Homework 2
Is Aluminum-Aluminum wound transformer better than Copper-Copper Transformer? Electrical Engineering 13
Prove cosign problem Precalculus Mathematics Homework 5
C3 Trigonometry help Calculus & Beyond Homework 1
