Calculating Lamp Location Above x-Axis: Elliptical Shadow Problem
In summary, the lamp is located three units to the right of the y-axis and a shadow is created by the elliptical region x^2 + 4y^2 = 5. The point (-5,0) is on the edge of the shadow and in order to find the distance above the x-axis, we need to find a line tangent to the ellipse at another point (x_0, y_0) that goes through (-5,0). This can be done by solving for the point of tangency and using the derivative of the ellipse equation.
boarding4lif3
A lamp is located three units to the right of the y-axis and a shadow is created by the elliptical region x^2 + 4y^2 = 5. If the point (-5,0) is on the edge of the shadow, how far above the x-axis is the lamp located?
2. The attempt at a solution
Ive calculated the derivative with respect to X to be -x/4y = y'. But when i try to find the slope, I am stuck with an undefined when i try to use the point (-5,0)
Any help would be appriciated. Thanks.
Well, the ellipse itself does not include the point (-5, 0) so there is no tangent to the ellipse there. What you want is a line through (-5, 0) that is tangent to the ellipse at some other point.
Let [itex](x_0,y_0)[/itex] be the point of tangency. The line through (-5, 0) and [itex](x_0, y_0)[/itex] has slope [itex](y_0- 0)/(x_0-(-5))= y_0/(x_0+ 5)[/itex].
Yes, the derivative is given by [itex]y'= -x/(4y)[/itex] and at [itex](x_0, y_0)[/itex] that is [itex]-x_0/(4y_0)[/itex].
So you want to find [itex](x_0, y_0)[/itex] satisfying both [itex]y_0/(x_0+ 5)= -x_0/(4y_0)[/itex] and the equation of the ellipse, [itex]x_0^2+ 4y_0^2= 5[/itex]
1. What is an ellipse?
An ellipse is a type of curve that is created by intersecting a cone with a plane. It is a closed shape that resembles a flattened circle.
2. How do you find the equation of an ellipse?
The equation of an ellipse is: (x-h)^2/a^2 + (y-k)^2/b^2 = 1, where h and k are the coordinates of the center of the ellipse and a and b are the lengths of the semi-major and semi-minor axes, respectively.
3. What is the difference between a major and minor axis of an ellipse?
The major axis of an ellipse is the longest diameter of the ellipse, while the minor axis is the shortest diameter. The major axis is also known as the horizontal axis, while the minor axis is the vertical axis.
4. How do you find the foci of an ellipse?
The foci of an ellipse can be found by using the formula c^2 = a^2 - b^2, where c is the distance from the center to the focus, a is the length of the semi-major axis, and b is the length of the semi-minor axis.
5. Can calculus be used to find the area of an ellipse?
Yes, calculus can be used to find the area of an ellipse. By using the formula A = πab, where a and b are the lengths of the semi-major and semi-minor axes, respectively, the area of an ellipse can be calculated. This equation is derived using calculus methods such as integration.
