| New Reply |
Gravitational force on objects |
Share Thread | Thread Tools |
| Aug11-12, 05:04 AM | #1 |
If I take a feather and a rock and drop them at the same time, because of the effect of the gravitational force, we know that the rock will hit the ground first. (The rock experiences a larger gravitational force).
My question is if these objects are dropped at the same time and vertically, then the velocity can be described as [itex] v = gt [/itex], for both objects. Therefore, at [itex] t = 1, v = 9.81 m s^{-1} [/itex] and at [itex] t = 2, v = 19.6 m s^{-1} [/itex]. However, i find it difficult to believe the feather will have this velocity. So how does the differences in gravitational force be accounted for in this equation? Many thanks |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Aug11-12, 05:26 AM | #2 |
Mentor
| Aug11-12, 05:30 AM | #3 |
I see, many thanks.
So essentially the formula only works when considering zero air resistance |
| Aug11-12, 12:17 PM | #4 |
yes and no...
Just before an object is dropped it has some energy lets call it Estart where Estart = PEstart + KEstart Since it's stationary KEstart = 0 so Estart = PEstart = mgh When it hits the ground it has some energy, lets call it Eend then Eend = PEend + KEend but PEend = 0 so Eend = KEend = 0.5mv2 If we assume there is no air resistance to be overcome (or any other way for energy to leave the system) then the law of Conservation of Energy says Estart = Eend or mgh = 0.5mv2 Notice how the mass cancels and the velocity of impact is independant of mass v = SQRT(2gh) |
| Aug11-12, 01:19 PM | #5 |
And if it takes [itex] t [/itex] seconds to cover this distance [itex] h [/itex], either [itex] v = gt [/itex] or [itex] v = \sqrt{2gh} [/itex] can be used to determine this impact velocity, I presume?
| Aug11-12, 01:30 PM | #6 |
| Aug11-12, 04:10 PM | #7 |
you have two objects of mass M and m, with M>m .
if you let them fall, you get from Newton's 2nd law: M a1= - M g m a2= - m g from that you see immediately that a1=a2 which means the speed of the mass M will change by the same ammount in the same time interval as will the speed of mass m. The mass of the falling object, does not appear in your motion equations. It doesn't affect it. Even if I didn't use the "static model", that the grav force is mg, but used the force: F= G M' m /r (M':Earth's Mass) the masses of the falling objects would again drop out. Of course that is not obvious, it comes thanks to the equivalence principle, which says that the mass that appears in ma, and the mass that appears in m* (GM'/r) is the same m=m* |
| New Reply |
| Thread Tools | |
Similar Threads for: Gravitational force on objects
| Thread | Forum | Replies | ||
| Gravitational force between everyday objects............ | Classical Physics | 4 | ||
| The gravitational force between and around 2 objects | Introductory Physics Homework | 2 | ||
| Gravitational Force: between 3 objects...? | Introductory Physics Homework | 2 | ||
| Gravitational Force Vector exerted by 2 charged objects | Introductory Physics Homework | 4 | ||
| The Gravitational Force (between two spherical objects) | Introductory Physics Homework | 6 | ||
