Measure the tensile strength using Young’s Modulus
In summary: If you double the moment of inertia, you double the stiffness.In summary, the conversation discusses measuring tensile strength using Young's Modulus for steel and brass, comparing results to published values, and understanding the use of formulas for calculating E. The application of steel and brass as structural materials is also discussed, with steel being more desirable due to its high YM. The conversation also touches on the concept of component stiffness vs material stiffness, and the ability to change stiffness by altering the size and shape of the material. The conversation ends with a question about finding published YM values for wood and potential ways to make wood and brass stiffer.
cmgames
Hi there, I am currently looking to measure the tensile strength using Young’s Modulus for steel and brass.
My results I have obtained are comparable with published values of E. My question is regarding the formulae, the one I used was: E = F/x X l/a
Where a is the original cross section of the steel and brass. The cross section measured was 8. The length was 50, however it was said that it was equal to 1 because the cylinder using pie r 2 of 50 would be approximating to 8 and therefore would be to one. I don’t really have much understanding of this, could you explain it to me.
Also regarding the application of steel and brass as a structural material. I have found that due to the high Young’s Modulus, steel is more desirable in structures as a high YM means it can span larger distances and is stiffer. Whereas brass is more flexible and so as a appropriate a resource than steel. Is there any other reasons for steel as the main application rather than brass?
I am looking at the difference between material stiffness and component stiffness. It is my understanding that component stiffness measure is by YM only. Whereas material stiffness tests using YM and also the size and shape of the material. Is this correct and is there any other differences between the two?
Lastly, I can't seem to find the YM values for wood – mahogany and parana pine. Where would I be able to find these published values and what would these values tell us when compared to actual results
looks like perhaps you measured the diameter of the cylinder as 8 units in which case its area is about 50 square units. l/a =50/50 = 1.
steel, concrete, wood, and aluminum are the most common structural materials. I don't know much about brass, but it's probably more expensive than steel. Aluminum has a lower modulus than steel, but its strength is for certain types greater than that of certain steels, so it has advantages in cases where deflection is not a major concern, and especially since it is so much lighter in weight than steel.
I'm not sure of the terminology, but I think you mean that where YM is a measure of the stiffness of the material, the actual deformation of a given component depends upon its size and shape, i.e., like in your problem, if the area is bigger or the length is shorter, the deformation is lower.
I suppose a web search will get you what you need...southern yellow pine has a YM of about 1600ksi (vs. 30000ksi for steel and 10000ksi for aluminum...I hope you're working in US units). Wood is a funny actor...deflections are oft greater than theory predicts.
From my results i have found that wood and brass is not inherently stiff. What examples are there of using wood and brass, that by changing it's shape or distribution would make it stiffer?
The modulus will change inversely to the cross-sectional area. So, if you change the shape in such a way that the cross-section decreases, the modulus will increase. That is to say it will become stiffer.
Young's modulus (E) of a material is what it is; you can't change its 'inherent stiffness', if that's how you define E. You can change the 'component stiffness' only by changing the size, shape, length, or boundary conditions at supports, of the material, by say increasing its cross section area, shortening its length, increasing its geometric moment of inertia, fixing its supports, etc. For tension/compression components, stiffness is proportional to AE/L. If you double its area, you double its stiffness, for example. In bending, stiffness is proportional to EI/L^3.
1. What is Young's Modulus and how does it relate to tensile strength?
Young's Modulus, also known as the modulus of elasticity, is a measure of a material's stiffness or resistance to deformation. It is the ratio of stress to strain in a material under tensile (stretching) forces. Tensile strength, on the other hand, is a measure of the maximum stress a material can withstand before breaking. Young's Modulus is directly related to tensile strength, as a higher modulus indicates a stiffer material with a higher resistance to deformation and therefore a higher tensile strength.
2. What is the formula for calculating Young's Modulus?
The formula for calculating Young's Modulus is E = (stress / strain), where E is the modulus of elasticity, stress is the force applied to the material, and strain is the resulting deformation. The units for Young's Modulus are typically in gigapascals (GPa) or pounds per square inch (psi).
3. How is Young's Modulus measured in practice?
To measure Young's Modulus, a tensile testing machine is used. A sample of the material is placed in the machine and stretched until it reaches its breaking point. The applied force and resulting deformation are measured, and Young's Modulus is calculated using the formula mentioned above. This process can also be done in reverse, by compressing the material to measure its compressive modulus.
4. What factors can affect Young's Modulus and tensile strength?
Young's Modulus and tensile strength can be affected by various factors, including the type and composition of the material, its microstructure, and any external forces or environmental conditions it is exposed to. The manufacturing process and any heat treatments can also influence these properties.
5. Why is measuring Young's Modulus and tensile strength important?
Measuring Young's Modulus and tensile strength is important for understanding the mechanical properties of a material. These properties can determine whether a material is suitable for a particular application, and can also help in the design and engineering of structures and products. Knowing the Young's Modulus and tensile strength can also help in predicting the behavior of a material under different types of stress or load, and can aid in quality control and materials testing.
  • Materials and Chemical Engineering
