Magnetizing Current: Questions Answered
  • Thread starter tonyjk
  • Tags
    Current
In summary, the magnetizing current is always present in a transformer, whether it is at no-load or full-load conditions. This current is responsible for establishing the flux in the soft iron core. When a load is applied on the secondary side, there is still a magnetizing current in the primary coil, in addition to the current required to produce the necessary flux for the load. This is because the secondary current produces a flux that is in opposition to the flux produced by the primary coil, and the primary coil must increase its current to maintain the required flux. The magnetizing inductance is put in parallel in the equivalent circuit to correctly represent the physical model and ensure that the magnetizing current remains constant regardless of
tonyjk
227
Hello.. I have a question : why when a transformer is loaded on the secondary, in the primary coil there's still the magnetizing current? I know that's the magnetizing current is the current for the no load condition and it's used to establish the flux in the soft iron. But when a load conditon applies there's a bigger current in the primary coil so why there's also a magnetizing current? Thanks
Magnetizing current is present all the time, at no-load or in full load. During No-load whole of the primary current is Magnetizing current but during full Load, magnetizing current is only a fraction of the primary current.
In terms of equation
I_primary = I_magnetizing (No-load)
I_primary = I_magnetizing + I_secondary*K (Full-Load) (K is turns ratio)
However, I_magnetizing and I_secondary will not be in phase and won't add algebraically (needs phasor addition)
Yeah i know this but why there will always be a magnetizing current in load condition? Plus i have another question: the magnetizing inductance is also the inductance of the primary coil no? So why we put it in parallel in the equivalent circuit? And if this inductance is high how come there's an increasing current on load condition? Thanks again
Can we say that the inductance of the primary coil is the magnetizing inductance and when there's a current in the secondary it produce a counter emf in the
Primary coil so that's why the current increase?
So we can say that the equivalence impedance view by the source is the magnetizing impedance and impedance due to the counter emf produced by the secondsry coil in the primary coil?
PS: SORRY IM TALKING TOO MUCH
For any coil, E = N*d(phi)/dt. Always.
If E is the applied voltage phi will be the flux produced.
If phi is the applied flux to the coil, E will be the emf produced.
Lets look at this step by step.
1. When there is no load on the secondary side (i.e. No load condition)
E is the emf applied to the primary coil, then the coil will produce phi flux in the core.
You can see that, if E is sinusoidal, phi will be cosinusoidal.
The coil will consume that much current as required to produce the phi flux.
since, phi = N*I / reluctance_of_core we can calculate what will be the current required to produce the flux phi.
This current is the magnetizing current.
But since there is cosinusoidal flux in the core, the same rule applies to the secondary coil and there will be Emf induced in the secondary coil given by
E2 = N2*d(phi)/dt.
2. When there is Load in Secondary.
When you connect load to the secondary, then there will be secondary current. The secondary current flowing in the secondary coil will produce flux phi2 which will be in opposition with the flux previously being produced by the primary coil (by virtue of the primary magnetizing current). So, in effect the net flux in the core will reduce to phi-phi2. But Since Emf E is still being applied to primary coil, it demands that the flux linkage of primary coil still be phi. So what happens is the current in primary coil increases so that it now produces the flux: phi + phi2 so that the net flux linkage of the coil (that is flux in the core) becomes: phi + phi2 - phi2 = phi again. The additional current required in primary coil to restore the flux will not be equal to the current in the secondary unless the no. of turns are same in both of the coil. Hence, the secondary current that flows when load is connected to the secondary coil will be reflected in the primary coil on top of the already present magnetizing current (not as a replacement for it).
I hope you can now see the inner workings and understand why the magnetizing current is always present. Too answer in short, the flux produced by the secondary and the flux produced by primary would exactly cancel each other but because there is additional magnetizing current in primary, there will still flux in the core (hence the electromagnetic coupling)
I hope that wasn't too messy. I wish I knew LaTex.
Thank you but can anyone please explain wjy we p
ut the magnetizing inductance in parallel?
Because that's the only way the equivalent circuit diagram would correctly represent the physical model.
If it is put in series then magnetizing current will vary according to load current.
Only by putting it in parallel, the magnetizing current will be constant regardless of the load current.
thank you but even the current due to load is moving through the primary coil that's why i asked the question and still i didnt understand why
1. What is magnetizing current?
Magnetizing current is the current that flows through an inductor or transformer when it is initially energized. It is also known as excitation current or inrush current.
2. What causes magnetizing current?
Magnetizing current is caused by the creation of a magnetic field when an inductor or transformer is energized. This is due to the interaction between the current and the inductor's or transformer's magnetic core.
3. Why is magnetizing current important?
Magnetizing current is important because it is necessary for the proper functioning of inductors and transformers. It creates the magnetic field needed for the devices to perform their intended functions, such as stepping up or down voltage.
4. How is magnetizing current different from operating current?
Magnetizing current is different from operating current in that it only flows during the initial energization of an inductor or transformer. Operating current, on the other hand, flows continuously during the device's normal operation.
5. How can magnetizing current be reduced?
Magnetizing current can be reduced by using materials with high permeability for the inductor or transformer's core. Additionally, using capacitors in parallel with the device can help to reduce the inrush current. Properly sizing the inductor or transformer for the intended application can also help to minimize magnetizing current.
  • Electrical Engineering
10K
