Interacting Photons at Planck Energy: What are the Properties and Possibilities?
In summary, the properties of a photon with Planck energy are speculative and not fully understood. Colliding a photon with the Planck energy with something on Earth would not go beyond the limit of current theories, but could potentially produce gravitons. There is a limit for cosmic radiation that is far less than the Planck energy and a high-energy photon would likely break apart before reaching it. However, there is a possibility of indirect interaction between photons through quantum mechanical effects.
Abstractness
33
What are the properties of a photon with Planck energy? Is it even possible to interact with it, or does it just travel trough all matter?
The Planck energy is an approximate energy, not an exact one. It is believed to be the energy range at which the quantum effects of gravity become important.
They talk a lot about the Planck energy on TV. However our best current theory, the Standard Model, is not expected to remain valid at such a high energy, and what actually does happen at the Planck energy, to the photon or to any other particle, is at this stage pure speculation.
To reach the Planck scale, you have to collide two particles with an energy of the order of the Planck scale.
A photon with the Planck energy (in our lab), colliding with something on Earth would be certainly a very interesting collision, but it would not go beyond the limit of our current theories (there could be new physics, but there does not have to be).The energy of a photon is frame-dependent. For every photon, there is a frame where its energy reaches (or even exceeds) the Planck scale.
It would likely produce gravitons, which goes beyond the limit of our current theories.
Let's collide the photon with a proton:
(E_P,E_P,0,0) + (m_p,0,0,0) leads to a center of mass energy of ##\sqrt{(E_P+m_p)^2-E_P^2} \approx 5 EeV = 5 \cdot 10^6 TeV##. More than we can produce in collider experiments, but way below the Planck scale of 1016 TeV where gravity becomes significant.
Abstractness said:
What are the properties of a photon with Planck energy? Is it even possible to interact with it, or does it just travel through all matter?
There is a Greisen–Zatsepin–Kuzmin limit for cosmic radiation - about 8 joules. This is far less than the 2 billion joules for your photon. So, if this particle could exist at all, it would immediately begin breaking apart into less energetic particles because of its interaction with the microwave background radiation.
But before that happened, I would wonder if it would constitute a tiny black hole that would instantly evaporate - releasing a shower of other particles.
So you're saying that photons can interact with photons ?
I don't think he meant to. The GZK limit applies to high-energy protons, not photons.
(But we should still be somewhat skeptical about any extrapolation of current theory to such a remarkably energetic photon).
Photons can indeed interact indirectly with other photons. This is a purely quantum mechanical effect that is basically unavoidable as long as the photon interacts with any other charged particles. One will always have processes where there is a virtual charged particle in a loop of the diagram for a process, with some number of external photons attached to the loop. It turns out that at least 4 photons must be involved (see this thread for a discussion of the kinematical reasons why), so, for example, a pair of photons in the initial state can interact in such a way that there is still a pair of photons in the final state, which is what we'd usually think of as a light-by-light scattering process.
Edit: I should add that the amplitude for the lowest-order process for light-by-light scattering, at high enough energies, is about 10000 times smaller than the amplitude for photon-electron scattering.
What is a photon with Planck energy?
A photon with Planck energy is a particle of light that has the maximum amount of energy allowed by the Planck constant. It is the smallest unit of energy that can exist in the universe.
How is the energy of a photon with Planck energy calculated?
The energy of a photon with Planck energy is calculated using the formula E = hf, where E is energy, h is the Planck constant, and f is the frequency of the light wave. The Planck constant is a fundamental constant of nature that relates a particle's energy to its frequency.
What is the significance of a photon with Planck energy?
A photon with Planck energy is significant because it represents the limit of energy in the universe. It is a fundamental particle that plays a crucial role in many physical phenomena, including the photoelectric effect and the emission of light by atoms.
Can a photon with Planck energy be observed?
No, a photon with Planck energy cannot be observed directly. It is a theoretical concept that represents the maximum energy that a photon can have. However, scientists can indirectly observe the effects of photons with Planck energy through experiments and observations.
How does the energy of a photon with Planck energy compare to other particles?
The energy of a photon with Planck energy is significantly higher than the energy of other particles. For example, the energy of a proton is around 10^19 times smaller than the energy of a photon with Planck energy. This shows the vast difference in energy scales between different particles in the universe.
  • High Energy, Nuclear, Particle Physics
