Proof Gauss's Law - Understanding, Deriving & Applying
In summary: A proof of Gauss's law is that the flux through any closed surface surrounding a point charge is equal to the charge enclosed by that surface divided by the permittivity of free space. This can be derived mathematically using the divergence and inverse-square laws, or intuitively by considering the concept of flux and intensity. The proof can be found in most E&M fields books.
Swapnil
459
I was wondering, how would you prove Gauss's law (either mathematically or intuitively)? I mean, I know that sometimes people take it as the fundamental law (one without proof) but how would you derive such a law from Coulomb's law?
Any help would be extremely appreciated. I have been fussing over this topic for a month now.
http://www.rpi.edu/dept/phys/Dept2/phys2/activities/gauss/proof.html
Thank you very much. That was a good website that gave an intuitive feel for the Gauss's law. Is it possible for you (or someone else) to give me a link that explains the mathematical derivation of Gauss's law (possible using Stoke's theorem or something)?
That IS the mathematical derivation of Gauss's law. Stoke's theorem has nothing to do with gauss's law. However, we can go from the integral form of gauss's law to the differential form of gauss's law using the DIVERGENCE theorem, but the application of the divergence theorem in order to do this is quite trivial.
Stokes theorem is used to transform the integral forms of maxwell's third equation (Faraday's law) and fourth equation (ampere's law) into their differential forms.
Oh yeah. Sorry about that. I was thinking Divergence theorem but I wrote down Stokes' theorem.
Wait. Is that what Divergence theorem is used for, just to tranform Gauss' law from integral form to differential form and vice-versa? This whole time I was thinking that Divegence theorem was used to derive Gauss' law from Coulomb's law. :blushing:
So in the end there is no rigorous proof of Gauss' law (the fact that it works for ANY closed surface)?
A simple derivation uses the definition of differential solid angle:
d\Omega=r.dA/r^3. Then \int qdA.r/r^3=4\pi q.
For q outside the closed surface, the sign of the solid angle has to be used.
the divergence
[tex] \nabla \cdot \mathbf{E} = \frac{\rho}{\epsilon_0} [/tex]
is saying the same thing as
[tex] \oint_S \mathbf{E} \cdot d\mathbf{A} = \int_V \frac{\rho}{\epsilon_0} dV = \frac{Q}{\epsilon_0} [/tex]
one is the differential form, the other is the integral form.
there are plenty of decent E&M fields books that prove it rigorously. can you check one out and look it up?
rbj said:
There are plenty of decent E&M fields books that prove it rigorously. can you check one out and look it up?
I have read/looked-over a lot of EM books, but none of 'em offer a satisfying proof of Gauss' law. The most common response is in terms of field lines, which I think is just a clever trick to avoid answering the question.
Here's the idea of the proof in short, you can work out the details yourself:
(I): Show that [itex]\nabla \cdot \vec F =0[/itex] if F has the form: [itex]\hat F=K\hat r/r^2[/itex] ([itex]r\neq 0[/itex]).
(II)The divergence theorem holds for simple solid regions, but can be extended to hold for regions that are finite unions of simple solid regions. Any volume region with a 'hole' in it can be viewed as a union of two simple solid regions. (For example: A solid sphere with a cavity in it, the outer surface is the surface of the sphere and the inner one is the surace of the cavity.)
(III) Show that the flux through such a surface is zero (if the inner surface surrounds the origin). This means the flux through both surfaces is equal. Since the surfaces were arbitrary, it means the flux through any connected closed surface that surrounds the origin has the same value. It thus suffices to calculate the flux through a sphere.
Do you call a proof that uses
[tex] \nabla \cdot \frac{\vec{r}-\vec{r}'}{|\vec{r}-\vec{r}'|^3} = 4\pi \delta^3(\vec{r}-\vec{r}') [/tex]
rigorous? Just curious.
Okay, let's begin with the concept of flux and the natural justification of the inverse-square law in our existence in 3 spatial dimensions.
As an illustrative example, let's think about the concept of power and intensity. At the beach, when you feel the sun's radiation on your skin, what you are measuring is how much energy (in a particular band of frequencies) is impinging upon your skin in a particular amount of time. If you're out in the sun longer, more energy falls on your skin (this is the concept of power: how much energy per unit time) and, in the same intensity of sunlight, the bigger you are, the more of that sunlight you will scoop up: more area exposed to the sun, more power that falls on that area. So, whether it is light or sound waves (or something else), intensity is amount of power that falls on a unit area that is positioned perpendicular to the oncoming wave. it's watts/m2. double the area, you get twice as much power. Double the intensity of radiation, you also get twice as much power.
Okay, consider a [itex]P_0[/itex] watt light bulb and assume we're measuring all of the radiation (infared, too) at a distance of [itex]r[/itex] meters. Imagine a sphere of radius of [itex]r[/itex] surrounding and centered at the light bulb. Conservation of energy says that the entire [itex]P_0[/itex] watts is distributed over the entire surface area of that sphere , which is [itex]4 \pi r^2[/itex] and the argument of symmetry says that every one of those m2 gets the same amount of power. And every little snippet of area is directly facing the light bulb and is perpendicular to the wave front. So, at that distance the power, [itex]P_A[/itex], falling on an area of [itex]A[/itex] is
[tex] P_A = \frac{P_0}{4 \pi r^2} A [/tex]
the factor
[tex] I = \frac{P_0}{4 \pi r^2} [/tex]
is the intensity of radiation and is proportional to the power of the point source, as one would expect. Note also, that with a constant source power, the intensity is also proportional to the reciprocal of the square of the distance from the source. A natural inverse-square behavior. Note also that if one were to integrate the intensity (which is [itex] \frac{P_0}{4 \pi r^2} [/itex] over the entire spherical surface area (which is [itex] 4 \pi r^2 [/itex]) i would be adding up all the little snippets of power falling on the little snippets of area and that would add to the total power [itex] P_0 [/itex] emitted by the point source. Doesn't matter how big the sphere is. If the sphere is twice as big, it has 4 times the surface area, but the intensity is 1/4 as large and it comes out to be the same total power. Adding up all of the little snippets of power impinging upon the surface of the sphere equals the power emitted by the source inside and we can thank the Conservation of Energy law for that simple fact.
Now here's a little example:
Someone, somewhere measured the intensity of radiation from the sun (the power falling on a square meter facing the sun out in a vacuum in Earth orbit) to be: 1360.77 W/m2. We also know that we are 149.6 x 109 meters (about 93 million miles) from the sun. From that we can calculate how big of a light bulb that the sun is:
[tex] 1360.77 \ \mbox{W/m}^2 = \frac{P_0}{4 \pi (149.6 \times 10^9 \ \mbox{m})^2} [/tex]
results in:
[tex] P_0 = 1360.77 \ (\mbox{W/m}^2) 4 \pi (149.6 \times 10^9 \ \mbox{m})^2 = 3.827 \times 10^{26} \ \mbox{W} [/tex]Now this is intensity, not electric field, but both share the same mathematics. Both are proportional to the source agent (power of point source vs. electric charge of point source) and both are a inverse-square relationship with distance. Now, instead of calling this quantity "intensity" which is power per unit area, for electric charges this natural inverse-square quantity is called "flux density" or "electrostatic flux density", and if we were talking about this other inverse-square phenomenon called gravity, it would be "gravitational flux density". These are those field lines that they like to draw and you don't like. But it doesn't matter, if experimental evidence shows that the electrostatic force follows the inverse-square law precisely (and it does, experiment confirms the exponent of [itex]r^{-n}[/itex] to be be [itex]1.99999999 < n < 2.00000001[/itex], then whether or not you like it, that density of lines of field model is valid, even if it comes from our imagination. If the E field is inverse-square, we can imagine a point source radially emitting a bunch of field lines (a.k.a. "total flux"), the quantity of which is proportional to the amount of charge, and the density of those field lines crossing a perpendicular surfaces (a.k.a. "flux density") is proportional to the number emitted and inversely proportional to the square of the distance.
Now we're moving toward proving:
[tex] \oint_S \mathbf{E} \cdot d\mathbf{A} = \frac{Q}{\epsilon_0} [/tex]
but I want you to get used to these first concepts before moving on. If you don't like any of the above, I ain't going to waste time continuing.
Another installment to follow.
Is anything misssing?
You mean [itex]\nabla \cdot \vec F \neq 0[/itex], right?
(No, he meant =0)
No, he meant = 0. The only point where there is a non-zero divergence in that particular vector field is where r = 0, but he excluded that point. Everywhere else the divergence is zero.
I did the calculation for [tex] \vec{r} = x\hat{i} + y\hat{j} + z\hat{k}[/tex] and I get [tex]\frac{1}{x^2+y^2+z^2}[/tex].
Also, why should the divergence be zero, don't we have a radial field?:confused:
Well, that's one of the special properties of inverse square field. It may look like it has a divergence, but it doesn't and it's the underlying reason for Gauss' law.
You could do it in cartesian coordinates:
[tex]\vec F(x,y,z)=K \frac{\hat r}{r^2}=K \frac{\vec r}{r^3}=K \frac{x\hat{i} + y\hat{j} + z\hat{k}}{(x^2+y^2+z^2)^{3/2}}[/tex]
but that's really a bit of a hassle.
Try it in spherical coordinates, whhich makes it trivial.
It seems you're having trouble grasping divergence.
The divergence of a point in space is the NET outward flux through an arbitrarily small volume, per unit volume, enclosing this point, where the small volume approaches zero. BY DEFINITION, a radial field HAS NO DIVERGENCE except at r = 0. All flux going into all arbitrarily small volumes must go out of the small volume, causing a net outward flux of zero, or, a divergence of zero at all points. However, if you determine the divergence at the point where there is charge, you are at the point where flux lines EMANATE, so through an arbitrarily small volume enclosing this point there IS a net outward flux. Gauss's law in differential form states that the divergence of the electric flux density is equal to the volume charge density at that point.
We can apply the integral form of Gauss's law and find the net outward flux through a surface enclosing a charge distribution, and then take the limit of the outward flux as the volume approaches zero. However, you might notice that this limit is zero. In fact, this limit is zero for all charge distributions and all fields, which is quite obvious. This is where divergence of a point comes in. It is, as I stated above, the net outward flux of an arbitrarily small volume, PER UNIT VOLUME, enclosing a point in a vector field. IF we find the limit of the integral form of gauss's law to a volume where the size of that volume goes to zero about a point, the result is zero. However, if we find the divergence, we get the limit of the charge per unit volume, at that point, which is a finite number.
The derivation for Gauss's law, in its most simple form, is a calculation of the net outward flux through a closed surface, where that closed surface encloses a point charge, and this calculation is performed using a closed surface with radial symmetry, and the center of this surface is centered at the point charge. Due to symmetry, E is a constant and da is a constant, and both vectors E and da are at an angle of 0 degrees, so the flux simply becomes Q/ep_0. So, we have proved that for a point charge with a spherical closed surface enclosing it, the net outward flux of the E-field is Q/ep_0. We can rewrite this by finding the net outward flux of the D-field for this configuration, and we simply get Q.
The issue, as you stated, is applying this to all charge distributions and all volumes, ans gauss's law says we can do this. Well, I suppose you could just say that no matter what surface you have enclosing the charge, your net ourward flux will be the same, and therefore enclosed charge will be the same. But this is where I bring in intuition...
Gauss's law is just something that is second nature to me I suppose.
Not true. Radial means that [itex]\vec F(\vec r)=F(r)\hat r[/itex], so the field just points away radially from the origin (or wherever the source may be).
A field like [itex]\vec F(\vec r)=K \hat r/r^3[/itex] is radial, but not divergenceless. That is a property unique to the inverse square relationship. In fact, an inverse square field is the only radial field that is divergenceless.
ok, this is true. There can be radial fields with divergence of zero everywhere, if for instance, the magnitude of the field at r = 0 is 0. I had my mind in electrostatics world and was visualizing the electric fields due to charges, and not just fields in general.
leright said:
It seems ...I suppose.
Thank you leright for your explanation. I think I have a more better understanding of divergence now.
I think I am wrong, but isn't [tex]\vec{r}[/tex] the follwoing in spherical coordinates?:
[tex] \vec{r} = r\,\hat{r} + \arctan(\frac{y}{x})\,\hat{\phi} + \arcsin(\frac{\sqrt{x^2+y^2}}{\sqrt{x^2+y^2+z^2}})\,\hat{\theta}[/tex]
How is this more easier?
No way. In spherical coordinates the field is simply [itex]\hat r/r^2[/itex]. There is no phi or theta dependence in there, since it's radial remember? All you have to do is lookup the divergence in spherical coordinates and do a simply derivative.
Oh yeah! Sorry, I guess I wasn't thinking straight now that I think about it...:blushing:
If you happen to have an E&M book handy, there's probably some derivation of the integral form of Gauss's law from the generalized coulomb's law, and then the derivation of the differential form from the integral form, which is fairly trivial using the divergence theorem.
There's a fairly rigorous derivation in Classical Electrodynamics, by Jackson p27-29, and a somewhat less-than-rigorous (but quite descriptive) derivation in Introduction to Electrodynamics, by Grffiths, p65-70
Try page 12 of "Classical Electromagnetism" by Franklin for a rigorous, intuitive, mathematical proof.
Checked out Jackson. I agree that he gives a fairly rigorous derivation of Gauss' law. :approve:
Hey i have a new proof of gauss law.now i am listing it below
let there be an arbitaraly shaped body.let there be a charge Q,e='epsilon not',E=electric field,dS=small surface element.
let the body be consisting of many small surface elements dS1,dS2...
let the individual surfaces be so small that radius here are constant and be r1,r2... respectively
therefore surface integral of E.dS=E1.dS1+E2.dS2+...
since theta =0 therefore E.dS=E*dS
therefore putting values
Q*dS1/(4*pi*e*r12)+Q*dS2/(4*pi*e*r22)+...
d(theta1)=dS1/dr12,d(theta2)=dS2/dr22,etc (from definition of solid angle)
taking everything in common
net elctric flux=Q/(4*pi*e)(dS1/dr12+dS2/dr22+...)
=Q/(4*pi*e)(d(theta1)+d(theta2)+...)
=Q/(4*pi*e)(4*pi)=Q/(e)
(since sum of all solid angle around the charge is 4*pi)
In general the electric field of a point charge with arbitrary motion does NOT vary as 1/r^2. For a rigorous formula for the E field of a point charge, see Griffiths, "Introduction to Electrodynamics," 2nd Edition, Eq. 9.107. I have considered the case of a relativistically oscillating charge (wA=.99c) inside a variety of shapes ... sphere, ellipsoid, egg-shape ... and have found (using a computer) that Gauss' law was satisfied in each case. I must confess I was surprised! Others have argued that Gauss' law is one of Maxwell's equations, and is therefore completely general. It appears they're right. I'm convinced that the law holds for all charge motions, including relativistic ones, and for all (fixed) shapes in space (both those enclosing the charge and those external to the charge).
Not sure why you're reviving a 4 year old thread, but I suppose if you are looking for the Electrodynamic (as opposed to electrostatic) analog to Griffiths' derivation, you could simply apply the Divergence theorem to Jefimenko's equation for [itex]\textbf{E}[/itex]. However, unlike the static case where both Gauss' Law and Coulomb's are easy enough to derive from experiments (empirically), and are hence both valid axioms for the theory, I've never seen Jefimenko's equations derived empirically. Hence, I'd consider Gauss' Law to be more fundamental than Jefimenko's equations (although I suppose you could transform Coulomb's law to a moving reference frame and take Coulomb's law and the two (or 3) axioms of SR as axioms for your theory of electrodynamics), and question the importance of "deriving" Gauss' Law from Jefimenko's equations.
[itex] \vec E = \frac{\hat r}{4 \pi r^2} \times \frac{Q}{\epsilon_0} \\
\vec E \cdot \hat r 4 \pi r^2 = \frac{Q}{\epsilon_0} \\
\text{Total Flux} = \frac{Q}{\epsilon_0} \\
\oint_s \vec E \cdot \hat n ds = \frac Q{\epsilon_0}[/itex]
Which is integral form of Gauss law.
  • #31
I'm fairly sure this can be done with lagrangians as long as you are comfortable with the jump from lagrangians to lagrangian densities.
1. What is Gauss's Law and why is it important in science?
Gauss's Law is a fundamental law in electromagnetism that relates the distribution of electric charge to the resulting electric field. It is important because it allows us to mathematically describe and predict the behavior of electric fields, which is crucial in understanding and designing various electrical devices.
2. How is Gauss's Law derived?
Gauss's Law is derived from Maxwell's equations, which are a set of four fundamental equations that describe the behavior of electric and magnetic fields. Specifically, Gauss's Law is derived from the first of Maxwell's equations, known as Gauss's Law for electric fields.
3. Can you explain the mathematical formulation of Gauss's Law?
Gauss's Law can be mathematically expressed as ∮SE·dA = qenc0, where ∮SE·dA represents the flux of the electric field E through a closed surface S, qenc is the total charge enclosed by the surface, and ε0 is the permittivity of free space.
4. How is Gauss's Law applied in real-world situations?
Gauss's Law has many practical applications in science and engineering, such as in the design of capacitors, electric motors, and generators. It is also used in the analysis of electric fields in various systems, such as in the study of lightning and the behavior of charged particles in a plasma.
5. Are there any limitations or exceptions to Gauss's Law?
While Gauss's Law is a powerful tool for understanding electric fields, it does have some limitations and exceptions. For example, it only applies to static electric fields and does not account for magnetic fields. Additionally, it assumes a vacuum or uniform medium, so it may not accurately describe more complex situations with varying materials or non-uniform electric fields.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
