Integration of Planck's law to find photon density in space
In summary, the universe is filled with EM radiation from the Big Bang that has cooled to 3K. The distribution of the energy density of these photons is given by the Planck formula. By integrating over frequency, we can estimate the number of photons per unit volume and the number of Big Bang relic protons in intergalactic space. The average density of hydrogen atoms in the universe is just one per cubic meter, which is similar to the number of protons calculated using the Planck formula.
yankans
The universe is filled with EM radiation emanating from the Big Bang. This radiation was initially unimaginably hot but, as the universe has expanded, it has cooled to 3K. The distribution of the energy density of these photons in frequency (or wavelength) is given by the Planck formula. At this temperature, what is the wavelength of the photons at the peak of the Planck distribution? You can use the Planck formula to figure out how much total energy there is per unit volume by integrating over frequency. By dividing by hv and integrating over frequency, you can figure out how many photons there are per unit volume. Use your result to estimate how many Big Bang relic protons there are per cubic meter of intergalactic space. For comparison, the average density of hydrogen atoms in the universe is just one per cubic meter, you will find that there are a lot more protons.
from Wien displacement law:
λ_max*T = (hc)/4.9651*K
Planck's law:
du = (8*pi/c^3)[hv/(exp(hv/kT)-1)]v^2*dv
where h = Planck's constant, k = Boltzmann's constant; c = speed of light,
v = frequency
integrate Planck's law from 0 to infinity
replace hv/kT with x
and integrate from 0 to infinity
[(k^3*T^3)/(h^2)]*[8*pi/c^3][x^3/(exp(x)-1)]dx]
U = [(k^3*T^3)/(h^2)]*[8*pi/c^3](gamma(4)zeta(4))
= 9.76e-25 J/m^3
Use λ_max*T = (hc)/4.9651*K at T = 3K to find
λ_max = 9.68e-4m
v_max = c/λ_max = 3.1e11 Hz
photon density = U/hv = U/h*v_max (which is the highest distribution frequency for v)
= 0.0047 protons/m^3
But this isn't much larger than the number of hydrogen atoms per cubic meter, as the question says.
Hi!
How did you get:
This is very urgent please :)
1.
What is Planck's law and how is it related to photon density in space?
Planck's law, also known as the blackbody radiation law, describes the intensity and distribution of electromagnetic radiation emitted by a blackbody at a given temperature. It is related to photon density in space because it helps us understand the number of photons that exist at a specific energy level in a particular volume of space.
2.
Why is it important to integrate Planck's law in order to find photon density in space?
Integrating Planck's law allows us to obtain a more accurate and comprehensive understanding of photon density in space by taking into account all possible energy levels. This is because Planck's law is an equation that describes the entire spectrum of electromagnetic radiation rather than just a single point on the spectrum.
3.
What factors influence the photon density in space according to Planck's law?
The photon density in space is influenced by several factors, including temperature, frequency of the radiation, and the volume of space being considered. As temperature increases, the number of photons also increases. Additionally, higher frequency radiation contains more photons than lower frequency radiation, and a larger volume of space will have a higher photon density than a smaller volume.
4.
How can the integration of Planck's law be applied to study the cosmic microwave background?
The cosmic microwave background (CMB) is a form of radiation that permeates the entire universe and is a remnant of the Big Bang. By integrating Planck's law, we can analyze the CMB spectrum and determine the temperature of the universe at the time the radiation was emitted, providing valuable insights into the early stages of the universe's formation.
5.
What are some limitations of using Planck's law to find photon density in space?
One limitation is that Planck's law assumes that the radiation being emitted is from a perfect blackbody, which may not always be the case in real-world scenarios. Additionally, the law does not take into account the effects of interstellar dust and gas, which can absorb and scatter radiation, affecting the accuracy of photon density calculations.
  • Quantum Physics
