Energy conservation vs momentum conservation in SHM
In summary, the question is about finding the ratio of amplitudes for a simple harmonic motion system with a mass M and a smaller mass m placed on it. The ratio is found by applying momentum conservation and energy conservation equations, but the energy conservation equation does not give the correct answer due to the presence of external forces, such as friction, which assist in the acceleration of the smaller mass by the larger one.
nikhilarora
a mass M , attached to a horizontal spring executes SHM(simple harmonic motion) with amplitude A1 . when the mass M passes through its mean position then a smaller mass m is placed over it and both of them move together with amplitude A2 . the ratio A1/A2 is ...?
taking angular frequency = ω
first taking two mass and spring as the system, since there is no external force momentum remain conserved , applying (M)(ω1)(A1) = (M+m)(ω2)(A2) , i get correct answer but while applying energy conservation equations, i get an incorrect answer!
will energy not remain conserved in such process?
please help!
Hi nikhilarora,
You might have done something wrong. Show your work.
ehild
ehild said:
Hi nikhilarora,
ehild
using k=spring constant
applying momentum conservation :
M*(ω1)*A1 = (m+M)*(ω2)*A2
=>M*(k/M)1/2*A1 = (m+M)*(k/m+M)1/2*A2
=> A1/A2 = (M+m/M)1/2
applying energy conservation :
1/2 * M*(ω1)2 * A12 = 1/2 * (m+M) * (ω2)2 * A22
=> M*(k/M)*A12 = (m+M)*(k/m+M)*A22
=> A12=A22
=> A1=A2
where have i done wrong ??
I see. The energy is not conserved when you put the small mass on the vibrating one. It is like an inelastic collision: the masses move together. So the bigger mass has to accelerate up the smaller one, and that happens with the assistance of friction or some other force which does work.
ehild
ehild
thanks a lot !
What is the difference between energy conservation and momentum conservation in SHM?
Energy conservation and momentum conservation are two important concepts in the study of simple harmonic motion (SHM). Energy conservation refers to the principle that the total energy of a system remains constant, while momentum conservation states that the total momentum of a system remains constant. In SHM, energy conservation focuses on the exchange between kinetic and potential energy, while momentum conservation focuses on the exchange between linear and angular momentum.
How do energy conservation and momentum conservation relate to each other in SHM?
In SHM, energy conservation and momentum conservation are closely related. Since both principles involve the exchange of energy between different forms, they are interconnected and must both be satisfied for SHM to occur. In simpler terms, if energy is conserved, momentum must also be conserved.
Which is more important in SHM, energy conservation or momentum conservation?
Both energy conservation and momentum conservation are equally important in SHM. As mentioned earlier, they are interconnected and must both be satisfied for SHM to occur. Without energy conservation, the system cannot maintain a constant energy level, while without momentum conservation, the system cannot maintain a constant motion.
Can energy conservation and momentum conservation be violated in SHM?
In theory, energy conservation and momentum conservation should always hold true in SHM. However, in real-world scenarios, there may be some external factors, such as friction or air resistance, that can cause a violation of these principles. In such cases, the energy or momentum of the system may decrease over time, leading to a decrease in the amplitude of the oscillations.
Are there any practical applications of energy conservation and momentum conservation in SHM?
Yes, there are many practical applications of energy conservation and momentum conservation in SHM. For example, these principles are used in the design of mechanical systems, such as springs and pendulums, to ensure that the system can sustain oscillations without losing too much energy. They are also essential in understanding the behavior of waves and vibrations, which have numerous applications in fields such as engineering, medicine, and technology.
