Gravity, Pressure and forces - a thought experiment
In summary, the conversation discusses a thought experiment about pressure and force between atoms, and how it relates to mass and gravitation. It also explores the effects of spin on a sphere of atoms, resulting in the formation of a void, a shell, and eventually a hollow toroid. The speaker welcomes constructive feedback on the experiment.
johnnyD36
Hi,
I just wanted to get some peoples opinions on a thought experiment I've had. If you can provide references to your input this would be helpful. If you only want to pass comment then keep that to yourself. I'm really looking for constructive feedback in terms of science, learning and education.
So her goes - let me know what's right and wrong and correct the thought experiment where necessary:
If pressure is the effect of a force applied to a surface, then we can say that the pressure felt on one atom(generalised) is the force applied to it from another atom.
Since atoms have mass and the gravitation between atoms is proportional to their mass, we can calculate the gravitation force that is to be felt as pressure between two atoms.
______
If we visualise an empty universe with only 2 atoms separated by any distance, the two atoms would be drawn together through gravitation.
Since F = MA, we can say that the atoms will collide with a given amount of force with force being higher the greater the initial distance.
Depending on the type of atoms and their kinetic energy, the two atoms will either bounce off each other in an endless loop, form a chemical bond or fuse together to form a new element.
______
If we visualise an empty universe with only 10 atoms, constrained inside a straight tube as wide as one atom and as long as 10 atoms, the force felt by the two outermost atoms would be the equivalent to the force it applies to the atom next to it, plus the lesser force felt by each of the other atoms proportional to their distance. Thus the centre most atoms would feel the greatest force/pressure as a result of their resulting mass/gravitation.
______
If we visualise an empty universe with a sphere of 1000 atoms, we can say that the atoms at the surface of the sphere feel the lowest force/pressure. We can also say that the force/pressure felt by the centre most atoms would be the highest.
______
If we then apply a constant angular force to the sphere of atoms to effectuate a spin, each atom will begin to have potential energy (F= MA).
______
As spin increases, the Angular force of the outer atoms will be greatest and the angular force will gradually cause the atoms to draw away from the centre of the sphere.
______
As the outermost and fastest moving atoms draw away from the centre of the sphere, those atoms will have a lesser gravitation effect on the other atoms as distance decreases the gravimetric force.
______
As we move away from the fastest moving atoms on the spheres' surface towards the slowest moving atoms on the spheres' surface, these slower atoms will feel less gravimetric force than before as the faster moving atoms are now further away.
______
Because the outer most atoms have a greater angular momentum and effectively a momentum force away from the centre, the closer to the centre of the sphere, the greater the net 'pull' away from the centre will be as a result of the sum gravimetric force. As a result, a void will form in the centre of the sphere.
______
A shell forms as spin increases, with the shell thickness being proportional to the mass of atoms and the angular momentum.
______
If spin increases further, the sphere will begin to flatten as a result of centrifugal forces.
______
If spin increases yet further, the flattened sphere will form a hollow toroid.
______
If spin is increased even further, the toroid hollow diameter will narrow and the diameter of the toroid will increase.
_______
And that's it! I hope you enjoyed and please, constructive input is welcome. All others can keep to themselves.
Hmm.. I counted 16 statements with errors in at least 10. I'll just deal with the first one.
Pressure is not force. Pressure is force per unit area. Pressure on an atom is therefore meaningless.
1. What is gravity?
Gravity is a natural phenomenon by which all objects with mass are brought towards each other. It is the force that holds us to the earth and keeps the planets in orbit around the sun.
2. How does gravity work?
Gravity works by the principle of mass attracting mass. The larger the mass of an object, the stronger its gravitational pull. This is why we experience a stronger pull towards the earth than towards smaller objects like a book or a pencil.
3. What is pressure?
Pressure is the force per unit area that is exerted on a surface. It is measured in units of force divided by area, such as pounds per square inch or newtons per square meter. It is the force applied perpendicular to the surface of an object.
4. How is pressure related to gravity?
Pressure and gravity are related in that the force of gravity can cause pressure on an object by pushing it down towards the surface it is resting on. The greater the force of gravity, the greater the pressure on the object.
5. What is the relationship between forces and motion?
Forces and motion are closely related as forces can cause changes in the motion of an object. A force can either speed up, slow down, or change the direction of motion of an object. This is described by Newton's Second Law of Motion, which states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass.
  • Mechanics
  • Other Physics Topics
