Home/shop vacuum system sizing/design question
In summary, when sizing a home/shop vacuum system, factors such as the area to be cleaned, type of debris, piping system, and vacuum unit requirements should be considered. The airflow requirements can be determined by the suction power needed and potential obstructions in the piping. It is possible to use a single vacuum unit for multiple workstations, but may require a larger and more complex system. PVC piping is commonly used, but other options may be more suitable. The frequency of cleaning and maintenance will depend on usage and type of debris, and it is important to follow manufacturer's recommendations for maintenance and promptly address any issues.
perfexion
I'm working on a home/shop use vacuum pick up system. I need to suck up some spherical objects about 3" in diameter which weigh about 2 oz.
First thing I want to do is size the blower for this project. Ignoring the losses of the hose I can calculate the velocity of the air at the inlet of the vacuum knowing that inlet diameter and the volumetric flow rate of the blower. Now, the objects at the inlet are comparable is size to the inlet area, so I figure I'm better off using just plane 1/2*rho*V^2*Cd*A for the estimate of the force on the object at the inlet rather than sediment entrainment equations or something.
For a 120CFM fan and 4" diameter inlet (letting rho=1.2 kg/m^3 and Cd = 0.45) I get something like 6.9 m/s of flow velocity and 0.06 N of pickup force at the inlet.
I have a few concerns with this admittedly crude calculation:
The first is that the velocity field around this spherical object is heavily affected by the fact that it's sitting on the ground. I'd expect to see a large reduction in the pickup force due to this fact.
The second thing is that once the object is actually inside the tube the effective cross sectional area decreases, the velocity around the object should speed up (small cross sectional area), the load on the blower goes up to the volumetric flow rate goes down, and because of all of this again I'd expect that prediction to be just bad. I would guess though that I get more force than predicted on the object inside my tube. I know it won't be as high as the blower sealed pressure times the cross sectional area of the tube, but I'd guess it's something like 1/8 to 1/3 of this.
The next issue is that I want this vacuum system to move objects which are not immediately adjacent to the inlet towards the inlet.
If I let the inlet be 1 inlet diameter above the floor (with the inlet area parallel to the floor) I can imagine a cylindrical volume of influence around the inlet. The diameter of this volume could be 2 inlet diameters, the top would be the plane of the inlet area, and the bottom would be the ground. I could calculate the area of the surface of this cylinder which will see inflow (the side, and the annular region of the top which is around the vacuum inlet).
Using this area I could estimate the average inflow velocity at this surface. For a 120CFM blower and a 4" inlet diameter I get something like 0.64 m/s. Using this velocity the force on a 3" spherical object would be something on the order of 1/1000 of a N. Not enough to get an irregular sphere weighing 2oz moving.
My question is do you think these calculations are on the right track for sizing the blower for this vacuum? Is there a better way to go about this?
For those who are wondering I also plan on putting a canister volume and filter further down the line (but before the blower) where these objects can accumulate. Really this thing is no different functionally than a shop vac from home depot or something, I just need to size the flow rate and tube to my particular needs.
The answer to your question is yes, these calculations are on the right track. However, there are some additional factors that need to be taken into consideration when sizing the blower for this vacuum system. First, it is important to consider the static pressure of the fan. This is the amount of pressure that the fan can generate while the air is not flowing through the system. This will affect the suction power of the fan, and therefore the force on the objects. Second, it is important to factor in the losses due to the hose and any bends or turns in the system. These losses will reduce the amount of airflow and the force on the objects. It is also important to make sure that the hose is rated for the airflow that you plan to use. Third, you need to make sure that the fan is capable of providing enough flow velocity to move the objects. As you mentioned, the force on the objects inside the tube will be less than the force at the inlet due to the decrease in cross sectional area. Therefore, it is important to make sure that the fan can provide enough flow velocity to overcome the drag on the objects and move them towards the inlet. Finally, you should also consider other factors such as the noise level of the fan, the power consumption, and the cost of the fan. These factors may influence your decision when selecting the appropriate fan for the job. In conclusion, the calculations that you have done are on the right track for sizing the blower for this vacuum system. However, it is important to factor in the static pressure, losses due to the hose, flow velocity, and other factors such as noise and power consumption when selecting a fan.
1. What factors should I consider when sizing a home/shop vacuum system?
When sizing a home/shop vacuum system, you should consider the size of the area to be cleaned, the type of debris or materials that will be collected, the length and diameter of the piping system, and the power and airflow requirements of the specific vacuum unit being used.
2. How do I determine the airflow requirements for my vacuum system?
The airflow requirements for a vacuum system are typically determined by the suction power needed to effectively collect the desired materials. This can be calculated by considering the type of debris and the distance it needs to be transported through the piping system. It is also important to factor in any potential obstructions or turns in the piping that may affect airflow.
3. Can I use a single vacuum unit for multiple workstations in my shop?
Yes, it is possible to use a single vacuum unit for multiple workstations in a shop. However, this may require a larger, more powerful vacuum unit and a more complex piping system to ensure adequate suction and airflow to all workstations.
4. What type of piping is best for a home/shop vacuum system?
The most commonly used piping for home/shop vacuum systems is PVC (polyvinyl chloride) due to its affordability and durability. However, other options such as metal or flexible tubing may be more suitable depending on the specific needs and requirements of the system.
5. How often should I clean or maintain my home/shop vacuum system?
The frequency of cleaning and maintenance for a home/shop vacuum system will depend on the usage and type of debris being collected. In general, it is recommended to clean or replace filters regularly and to inspect the system for any clogs or damage. It is also important to follow the manufacturer's recommendations for maintenance and to address any issues promptly to ensure the system continues to function properly.
  • Mechanical Engineering
