Help understanding infinity and applications to automaton theory
In summary: This kind of notation is designed to make it clear that the reader is not dealing with a number that is just a little bit bigger than a regular number. The reason that a DFA needs an infinite amount of states to accept all strings is because, in general, a DFA will need to check every string against every state in order to determine whether or not the string is accepted. Suppose, for example, that the DFA has the states "accept", "not accept", and "undecided". A string x is accepted by the DFA if and only if x leads to and ends on an accept state. Suppose also that the DFA has the state
Jarvis323
1,243
986
Relevant Information
A language is a set of strings over an alphabet
A string is a finite set of characters from an alphabet
An alphabet is a finite non-empty set
A DFA is a deterministic finite state machine
A subset of it's states are accept states
A string is accepted by a DFA if the string leads to and ends on an accept state
A language accepted by a DFA if all strings in L, and only those strings are accepted by the DFA
I often have a hard time making sense of infinities.
Example: the language L = { e, 01, 0011, 000111, 00001111, ... } is not DFA acceptable because a machine capable of accepting it would require an infinite amount of states.
I can draw a DFA with ellipses in the middle to represent it's expansion. I can prove that:
For all strings x in L, using a machine M = mentioned DFA, under some finite expansion, I can accept all strings y in L, such that |y| <= x and such that M has |x| + 2 states and such that all strings in compliment(L) are not accepted by M.
All of those machines are finite.
The problem that prevents me from making the leap to claim that L is then DFA acceptable, is that I need to prove that there exists a largest string in L, but there is no largest string in L.
In short, when a DFA needs a state for each character of a string in order to accept the string, and the language is an infinite set of strings who's enumeration could be represented as a sequence of strings increasing in length, how is it that a DFA needs an infinite amount of states to accept all of those strings, given each string is finite?
Also, is the mainstream concept of infinities considered to be the only valid school of thought? What fundamental axioms do our notions of infinities rely on?
I'm sure people will tell you about the various sizes of Cardinal (and perhaps Ordinal) infinities. However, I think your question concerns the difference between the statements that such-and-such is "True for each finite integer N" vs "True for all integers" (i.e. True for the infinity of integers).
For example, for each integer N, there is an integer M such that M is larger than N. However there is no single integer M such that M is larger than all integers.
This has to do with the distinction between saying "For each thing x, there is a thing T(x)..." vs saying "There is a thing T, such that for each thing x ...". The first claim allows T(x) to depend upon x ("vary with it", so to speak) and the second claim does not.
Likes 1 person
Can you comment on a rewording of the fundamental issue.
If no DFA can represent {e, ab, aabb, ... } then there cannot exist a finite series of cells such that for all natural numbers x, x's digits can fit in the cells, at most one digit for one cell.
So the issue I am having a hard time with is the idea that you need an infinite number of places to store an arbitrary finite number.
At least these are the logical consequences that seam to follow.
If you think you can store a arbitrary finite number of things in N cells, where N is a finite number, then what value do you have in mind for N? N = 100? N = 10,000 ? Can you set a value for N before someone tells you how many things need to be stored?
Likes 1 person
I guess I am starting to feel better about it. I still cannot grasp it intuitively, but I do grasp the mathematical concepts. One day I would like to complete my understanding by working my way up through these concepts starting from a set of simple axioms.
Very few people (none I have ever met) have a tidy of understanding of mathematics that begins with a few simple axioms and builds up to advanced subject matter. I would take too long to learn that. As a cultural activity, mathematics begins with simple axioms and builds up to complicated topics, but I don't know any single individuals who have replicated the work of an entire culture.
Understanding mathematics is complicated by the fact that even respectable mathematical texts often don't use precise language. You have to get used to mathematical "slang". For example, the common phrase "an infinite number" suggests that there is some number with the property that it is "infinite". In special contexts, people may introduce a symbol [itex] \infty [/itex] to the number system and define some operations for it. But in the typical context , to say something needs "an infinite number" of things only has the meaning that "no (finite) number" satisfies the requirement. If you say that a set of strings requires a machine with "an infinite number" of states to accept it then you might mean "There is no machine that has only a finite number of states and can accept this language" or you might actually be considering a hypothetical machine that has a state for every integer or a state for every real number etc.
1. What is infinity and why is it important in automaton theory?
Infinity is the concept of something being without limits or boundless. In automaton theory, it is used to represent the idea of an infinite number of possible states or inputs for a machine or system. Understanding infinity is crucial in automaton theory as it allows us to analyze and design machines that can handle an infinite number of inputs.
2. How does infinity affect the complexity of automata?
Infinite automata, which can process an infinite number of inputs, are more complex than finite automata. This is because infinite automata must consider all possible inputs, while finite automata only need to consider a finite set of inputs. As a result, the time and memory required to process inputs for infinite automata are significantly greater, making them more complex.
3. Can automata handle infinite languages?
Yes, automata can handle infinite languages. In fact, there are certain types of automata, such as pushdown automata and Turing machines, that are specifically designed to handle infinite languages. These machines have the ability to process an infinite number of inputs and have been used in various applications, such as natural language processing and programming language design.
4. How is infinity represented in automaton theory?
In automaton theory, infinity is typically represented using mathematical symbols, such as the symbol ∞ or the notation "ω" for an infinite sequence. These symbols are used to represent the idea of something being without limits or boundless, which is the concept of infinity.
5. What are some real-world applications of automaton theory and infinity?
Automaton theory and the concept of infinity have many applications in the real world. One example is in computer science, where automata are used to design and analyze computer algorithms and programming languages. In physics, automata are used to model complex systems, such as the behavior of particles in a gas. Additionally, the concept of infinity is used in fields like economics, where it is used to represent the idea of infinite resources or demand.
  • Beyond the Standard Models
