Maximal, greatest, minimal and least elements of a set
In summary, a maximal element of a set is the largest element in the set, a greatest element is the largest element in a partially ordered set, a minimal element is the smallest element in the set, and a least element is the smallest element in a partially ordered set. To determine these elements, one must understand the order or relation defined for the set and compare the elements to find the appropriate element.
Vishera
72
Definition of maximal, greatest, minimal and least elements of a set: http://i.stack.imgur.com/PnI9V.png
Since c is a minimal element but c is not a least element, this implies that there is one element that is not comparable to c. What is that element? What about d and i?
The elements ##d##, ##i##, ##e##, ##f## and ##h## are not comparable to ##c##.
1. What is a maximal element of a set?
A maximal element of a set is an element that is greater than or equal to all other elements in the set. In other words, there is no other element in the set that is larger than the maximal element.
2. What is a greatest element of a set?
A greatest element of a set is similar to a maximal element, but it is only defined in partially ordered sets. It is the element that is greater than or equal to all other elements in the set, but it may not exist in all sets.
3. What is a minimal element of a set?
A minimal element of a set is an element that is less than or equal to all other elements in the set. In other words, there is no other element in the set that is smaller than the minimal element.
4. What is a least element of a set?
A least element of a set is similar to a minimal element, but it is only defined in partially ordered sets. It is the element that is less than or equal to all other elements in the set, but it may not exist in all sets.
5. How do you determine the maximal, greatest, minimal, and least elements of a set?
To determine these elements, you must first understand the order or relation that is defined for the set. For example, in a set of integers, the greatest element would be the largest integer in the set. In a set of real numbers, the maximal element would be the element closest to infinity. Once you understand the order, you can compare the elements in the set to find the maximal, greatest, minimal, and least elements.
