What Are the Advantages of Using Steel for Commercial Buildings?
  • Thread starter oldtobor
In summary: However, if the building is in a bad state, like has water damage, then you would need to repair it. If you're talking about a 600 year old house made of wood, it's probably pretty durable. A 100 year old house made of wood may not be as durable, but there's a good chance it will still be standing. Overuse affects our current interstate road system. Many interstate bridges have expected lifespans of less than forty years, and are rebuilt on that schedule.Structure maintenance is always a big part of a country's budget. Sometimes the structures could be restored, and sometimes they must be replaced. In the structural
oldtobor
132
How long do concrete - steel constructions last in time ? Does anyone know ? For example how long would the buildings (skyscrapers and even the normal 2 floor buildings) in NYC last without any further maintenance ? 200 or 1,000 years ?
And more in general how long can we expect concrete - steel buildings to last of any type, even one or two story buildings ? How long can wood frame homes last as is usual in suburbs of the US ? Is a wood home of 100 years old almost finished as far as lifetime goes ? Can they last more than 100 years ? Thanks if anyone has any ideas.
And at what point is maintenance costs higher than just tearing down the buildings and building a new one ?
Concrete constructions can fail due to several reasons, not restricted to just wear and tear. If you want to estimate the lifespan of a building, you would also have to take into consideration factors like whether new buildings will be built near it etc. Such factors may introduce cracking or differential settlement in the building, which may lead to failure over time.
Generally for steel constructions, you'd have to see if the steel has been prestressed before construction. Prestressed steel are typically more durable and able to sustain larger loads as compared to steel which have not been prestressed.
Wood frame homes are more susceptible to failure as they're prone to getting insect attacks (i.e. termites). If we're talking about timber, it generally lasts for about 20yrs if it has been treated before construction. Otherwise, its lifespan is significantly shorter.
Hope this helps a little. ^^
Huh? My father is living in a timber-framed house that is over 200 years old, and it shows no signs of falling down anytime soon. As long as you've got a decent roof, siding, etc to keep out the weather, wood is pretty durable.
So any quick estimates in general ? Wood frame 100 to 200 years ? Concrete and steel 200 to 300 years ? I ask also because I am thinking of how old the USA infrastructure is geting and how much it could cost. Also bridges, roads ? Will it cost too much ?
Yeah, there are a lot of 600+ (?) year old houses around, made from wood.
Not to digress, but there are adobe buildings in the Pueblo down the road that are at least 800 years old. There is documentation from the time of the Conquistadors for these buildings, and oral history dates them further back.
There is no one good answer because there are too many variables. All structures and infrastructure elements require maintenance. Bad maintenance = short longevity, good maintenance=longer usable lifespan.
What you are referring to is failure to maintain. This 'no spend' mentality will eventually cause more and more emergency repairs and rebuilds. We are far behind the curve right now in the US.
The American Society of Civil Engineers view things with this report card for the year 2005:
http://www.asce.org/reportcard/2005/page.cfm?id=103
The link above answers the 'will it cost too much' question...
The maintenance costs for structures is always a big part (billions) in a country's budget. Sometimes the structures could be restored, and sometimes they must be replaced. In the structural sense asphaltic concrete pavements tend to be more expensive rather than reinforced concrete, wood and steel structures. The reason is because of the long length of highways which require a sizable volume of asphaltic concrete mix. Sometimes patching is enough, but overlays are common.
Btw, Highways are designed commonly for periods of 20-30 years. This means the highways combined of the country need replacing in shorter time than buildings (assuming these are kept in working conditions).
Every now and then in Pennsylvania, someone will rip the siding off of their old house (not knowing just how old it is) and find they are living in a 250 year old log cabin.
The frames of buildings don't really need maintenance, just protection. The exterior needs maintenance, and what often kills buildings is that the maintenance isn't done on the exterior, which then leads to degredation of the frame.
You might take a look at some of the writings of Albert Speer, Hitler's architect. Forget the NAZI stuff - that was just idiotic - and read the work he did on the ruins value of various buildings, i.e., if you abandon a cathedral and come back in 500 years, what does it look like?
There are several kinds of commercial building construction commonly used in North America. So why would someone build a commercial warehouse, retail space, warehousing, a church, school, farm, or municipal structure choose a steel building?
The simple answer is that steel buildings offer a cost effective, flexible, low maintenance and energy efficient structure that can be designed to fit almost any situation.
The strength of steel also makes it an ideal material for buildings where a large open floor space is required. Steel buildings can have a clear-span of up to 300 feet wide. This gives the designer and builder of commercial buildings a very large space that is column-free, and adds the flexibility to satisfy complex space designs while maintaining an obstacle free space.
__________________________
www.cpint.hk/projects.php[/URL]
1. How is the lifespan of a building determined?
The lifespan of a building is determined by several factors including the quality of construction, materials used, maintenance, and environmental conditions. Generally, buildings are expected to last for at least 50 years, but this can vary depending on these factors.
2. Can buildings last forever?
No, buildings cannot last forever. Eventually, all buildings will deteriorate and require repairs or replacement. However, with proper maintenance and occasional renovations, the lifespan of a building can be extended significantly.
3. What are the most common causes of building deterioration?
The most common causes of building deterioration include natural disasters, moisture, pests, and wear and tear from daily use. Exposure to extreme weather conditions, such as strong winds, heavy rain, and snow, can also contribute to deterioration.
4. How can we increase the lifespan of a building?
Regular maintenance and timely repairs are crucial in increasing the lifespan of a building. This includes routine inspections, cleaning, and addressing any potential issues before they become major problems. Using high-quality materials and proper construction techniques can also help prolong a building's lifespan.
5. Are there any factors that can make a building last longer?
Yes, several factors can contribute to a building's longevity. These include using durable and sustainable materials, incorporating energy-efficient designs, and following proper construction techniques. Additionally, choosing a suitable location with minimal exposure to natural hazards can also help increase a building's lifespan.
  • General Engineering
  • Mechanical Engineering
9K
  • Materials and Chemical Engineering
