SHM question with no other details
  • Thread starter hemetite
  • Tags
    Shm
In summary: Actually, that's not really necessary because you can just use the absolute value of the cosine function instead. So the answer would be: A=9.81/(-w2(\cos(wt+teta)+1))
hemetite
50
Qns: A block rest on a flat plate that executes vertical simple harmonic motion with a period of 1.5s. What is the maximum amplitude of the motion if the block were to be in contact with the plate thoughout the motion?
Can help me how to start?...there is not much details in this questions.
You really don't need anymore detail than what the question gives. You need to find out how fast can the flat plate travel as not to give the block enough momentum to leave the plate when it starts to travel in the negative direction. Since you know the period is 1.5s, the velocity of the plate is then a function of its amplitude or displacement. The only assumption to be made is that the plates position is sinusoidal and not stepped.
Hint: When the plate reaches its top peak, the block should experience an acceleration of 0.
still catch no ball... :(
Ok, find a ball or box or some solid object. Put it in your open hand and start moving your hand up and down slowly. Then start moving it up and down faster until the ball in your hand starts to leave it when you move your hand from going up to going down. This the point you need to calculate by finding the distance you move your hand in a certain amount of time. You know the acceleration of gravity(9.81 m/s^2) and now you need to find the acceleration of the plate and ball. You will find when you start manipulating the equations that the mass of the ball cancels out.
man, i understand all of it...but getting the equations up is mind boggling. These are what i gotten.
velocity= 2A/1.5s
-kx=ma
-kx=m9.81
at the top peak which can be either -A or A
acceleation = kA=0
therefor A=k at the top peak.
anybody can give the equations to play around with?
Hi hemetite,
velocity= 2A/1.5s
-kx=ma
-kx=m9.81
acceleation = kA=0
The acceleration is not zero at the amplitude.
In this case you're looking for the amplitude at which the block is just barely leaving the plate at the highest point. The reason it is leaving the plate is because the spring is pulling the plate down faster than the ball can keep up. So if the block has lost contact with the plate, what is its acceleration?
Once you have that, how is maximum acceleration related to amplitude?
okay... Acceleration of the plate cannot be more than 9.81ms or else the box will lose contact.
diSplacement is proportional to force. So at the peak.
F=m9.81
Displacement
m9.81=A cos(wt + teta)
Acceleation
9.81= -w2 A cos(wt + teta)
w=2pi/1.5
Correct so far?
That's right; so you want to find the amplitude that gives a maximum acceleration of 9.81 m/s.
F=m9.81
Displacement
This does not look right; you have a force on the left and distance on the right.
Acceleation
w=2pi/1.5
These last two are right and will give you the answer. What do you get for A?
Acceleration
w=2pi/1.5
A=9.81/(-w2 A cos (wt + teta)
i thought of this...
what puzzle me...is how to calculate the
cos (wt + teta) part...was the value of t and teta?
hemetite said:
Acceleration
w=2pi/1.5
You had already determined that 9.81 was the maximum acceleration. Think about what range of values the cosine function is able to have; what then is the cosine equal to? In other words, when the acceleration is a maximum, what is the value of the cosine function?
Omg!...on my way home from school...it struck me and i solve it...hurray hurray...
Acceleration
w=2pi/1.5
A=9.81/(-w2 cos (wt + teta)
at maximum amplitude the cos (0) which will give a value of 1.
that will give us
A=9.81/(-w2 (1) )
Hurray! hurray!...finally got it...
Thank you guys...
Acceleration
w=2pi/1.5
that will give us
A=9.81/(-w2 (1) )
Thank you guys...
That's right. To take care of the minus sign, you might want to think of using [itex]\cos(\pi)=-1[/itex], which will give the same magnitude of the amplitude.
1. What is SHM?
SHM stands for Simple Harmonic Motion. It is a type of periodic motion in which an object moves back and forth along a straight line.
2. What are the factors that affect SHM?
The factors that affect SHM include the amplitude, frequency, and mass of the object, as well as the spring constant and any external forces acting on the object.
3. How is SHM different from other types of motion?
SHM is different from other types of motion because it follows a specific pattern and can be described by mathematical equations, such as the simple harmonic oscillator equation.
4. What are some real life examples of SHM?
Some real life examples of SHM include the motion of a swing, a pendulum, a mass-spring system, and the vibration of atoms in a solid material.
5. How is SHM useful in the field of science?
SHM is useful in the field of science because it helps us understand and predict the behavior of systems that exhibit periodic motion, such as mechanical and electrical systems. It also has applications in areas such as engineering, physics, and biology.
