Relative Motion (Swimmer Crossing River Question)
In summary, a swimmer with a speed of 0.80m/s in still water crosses a river 86m wide and lands 54m downstream from the starting point. The swimmer takes 107.5 seconds to cross the river, resulting in a current speed of 0.5 m/s [E]. The swimmer must aim upwards in a direction of [W 51 N] to end up straight across from the starting point due to the asymmetry of the situation.
Aristata
A swimmer who can swim at a speed of 0.80m/s in still water heads directly across a river 86m wide. The swimmer lands at a position on the far bank 54 m downstream from the starting point. Determine:
(C) The direction of departure that would have taken the swimmer directly across the river.
(s - swimmer
g - ground
w - water
Vsw = 0.8 m/s
d across stream = 86m)
(n/a - see bellow)
From the previous two parts of the question I determined that it took the swimmer 107.5s to cross the river and thus the speed of the current is 0.5 m/s [E]. And that the velocity of the swimmer relative to the shore was 0.94 m/s [58 N of E]. (Which according to my textbook is correct.)
(t=107.5s
Vwg = 0.5 m/s [E]
Vsg=0.94 m/s [58 N of E])
Now, I figured that in order to end up straight across where you start from, you would have to swim [58 N of W] since the current resulted in the swimmer following a path of [58 N of E]. (So this would negate the effect of the current?) However, according to the textbook the answer is [W 51 N] and I have no clue how else to approach this question. Any help/tips please?
the situation isn't symmetric as one might intuit at first glance. In the first case, all the velocity goes to crossing the river, in the second some is lost; ie
t=86/.8=107.5 as you posted. The velocity of the current downstream then just 54/107.5=0.5 m/s
so now you need to aim upwards to compensate for the drift--in other words total velocity^2=0.64=Vx^2+0.5^2 solve for Vx, then angle should fall out.
Relative motion is a concept that is often used in physics to describe the motion of an object with respect to another moving object. In this case, the swimmer is moving with a constant velocity of 0.8 m/s in still water, while the river's current is moving at a velocity of 0.5 m/s to the east. This creates a relative motion between the swimmer and the shore, resulting in the swimmer landing 54 m downstream from the starting point.
To determine the direction of departure that would have taken the swimmer directly across the river, we can use vector addition to find the resultant velocity. The swimmer's velocity relative to the ground is 0.94 m/s [58 N of E], and the current's velocity is 0.5 m/s [E]. Using the Pythagorean theorem, we can find the magnitude of the resultant velocity, which is 1.06 m/s.
Now, to find the direction of the resultant velocity, we can use trigonometry. The angle between the swimmer's velocity relative to the ground and the resultant velocity is the same as the angle between the river's current and the shore. This angle can be found using the inverse tangent function, which gives us approximately 26.6 degrees. Therefore, the direction of departure that would have taken the swimmer directly across the river is 26.6 degrees west of north, or [W 51 N]. This takes into account the effect of the current and allows the swimmer to cross the river in a straight path.
It is important to note that relative motion can be a complex concept, and it is important to fully understand the velocities and directions involved in order to accurately determine the resultant velocity. I would recommend reviewing the concepts and equations used in this problem and practicing with similar problems to solidify your understanding.
1. What is relative motion?
Relative motion is the concept that an object's motion is described relative to another object's motion, rather than to a fixed point or frame of reference.
2. How does relative motion apply to the "swimmer crossing river" question?
In the "swimmer crossing river" question, relative motion is used to describe the motion of the swimmer relative to the motion of the river. This allows us to calculate the swimmer's velocity and direction of motion.
3. What factors affect the swimmer's velocity when crossing a river?
The swimmer's velocity when crossing a river is affected by the velocity of the river, the swimmer's own velocity, and the angle at which the swimmer is crossing the river.
4. How does the angle at which the swimmer crosses the river affect their velocity?
The angle at which the swimmer crosses the river affects their velocity because it determines the component of the river's velocity that is parallel to the swimmer's motion. A smaller angle will result in a greater component of the river's velocity being in the same direction as the swimmer's motion, resulting in a faster velocity.
5. Can relative motion be applied to other scenarios besides the "swimmer crossing river" question?
Yes, relative motion can be applied to any situation where the motion of one object is described relative to the motion of another object. For example, relative motion can be used to describe the motion of two cars on a highway or the motion of a person walking on a moving train.
