What is Euler's Criterion in plain simplified english
  • Thread starter jenzao
  • Tags
    English
In summary, Euler's Criterion is a mathematical concept used in multivariate analysis to determine if an expression is an exact differential of a given function. It involves taking partial derivatives and relies on the concept of potential and central forces. It is recommended to have a good understanding of partial derivatives before approaching this topic.
jenzao
48
What is "Euler's Criterion" in plain simplified english
This sentence in textbook reads: "If ∂M/∂y = ∂N/∂x the differential is exact (Euler’s Criterion)."
What does the equation mean, and also I am not familiar with the backwards number 6 symbol --what is that?
thanks
This has no "plain English" definition :) You should grab some multivariate analysis textbook. Or try this: http://en.wikipedia.org/wiki/Partial_derivative"
Given that f is a function of several variables, [itex]\frac{\partial f}{\partial x}[/itex] is the partial derivative of f with respect to the variable x. It is the same as the normal derivative of f if we take all other variables to be constants.
Suppose we have a function f(x,y). The differential of f(x,y) is defined to be [itex]df(x,y) = \frac{\partial f}{\partial x}(x,y) dx + \frac{\partial f}{\partial y}(x,y) dy[/itex]. If you have an expression M dx + N dy, it is called an exact differential if it is the differential of some f(x,y). The Euler criterion is one way of telling whether this is the case; it is easy to see that it should be the case.
"If you have an expression M dx + N dy, it is called an exact differential if it is the differential of some f(x,y). "
Could you please provide an example of this?
Suppose you have the vector field g(x,y) = (-x/r3/2) dx - (y/r3/2) dy, where r = [itex]\sqrt{x^2 + y^2}[/itex]. Then g(x,y) is an exact differential, because g(x,y) = df(x,y) where f(x,y) = r-1/2. Ie., f(x,y) is the potential of a central force g(x,y). You may also see [itex]f = -\nabla g[/itex].
If you don't know about partial derivatives, why are you worrying about "Euler's Criterion" and "exact differentials"? The latter requires that you be well versed in partial derivatives.
1. What is Euler's Criterion?
Euler's Criterion is a mathematical theorem that helps determine whether a given number is a quadratic residue modulo a prime number.
2. How does Euler's Criterion work?
Euler's Criterion states that if a number a is a quadratic residue modulo a prime number p, then a raised to the (p-1)/2 power is congruent to 1 modulo p. In simpler terms, if the square root of a can be found within the set of numbers less than p, then a is a quadratic residue modulo p.
3. What is a quadratic residue?
A quadratic residue is a number that when squared, gives a remainder of 1 when divided by a given prime number. For example, if we take the prime number 7, the numbers 1, 2, 4 are quadratic residues because when squared, they give remainders of 1 when divided by 7.
4. Why is Euler's Criterion important?
Euler's Criterion has numerous applications in number theory and cryptography. It helps in solving problems related to quadratic residues, which are essential in many areas of mathematics and computer science.
5. Are there any limitations to Euler's Criterion?
Yes, Euler's Criterion only applies to prime numbers. It cannot be used for composite numbers. Additionally, it only determines whether a number is a quadratic residue modulo a prime number, and not the actual square root of the number.
  • Differential Equations
  • Art, Music, History, and Linguistics
  • Classical Physics
