Could you help me better understand covers, open covers, subcovers ?
  • Thread starter Pen_to_Paper
In summary, the definition of open cover states that a set E may or may not be open, while the definition of compactness states that a subset K is contained in the union of finitely many indices, alpha-1 to alpha-n.
Pen_to_Paper
First off, I'm using Rudin in my Analysis class, and although I have the written definition of a cover, I don't quite grasp it:
"An open cover of a set E in a metric space X is a collection of {G sub-alpha} (G indexed by alpha's) of open subsets of X such that E is contained in the union of the collection of open subsets of G indexed the alpha's"
(3rd edition of Principles/Analysis; Definition 2.31)
and then the extension (Heine-Borel) that a subset K of a metric space X is said to be compact if every open cover of K contains a finite subcover
I'm really trying to intuitively grasp this defintion and I went through some of the older posts discussing subcovers, but that didn't really illuminate the meaning for me.First, in the definition of open cover, the set E may or may not be open, is this correct?
so can be E = (1,2) or E=[1,2] and then an open cover of E may be this: let H = (1/2, 3/2) U (4/3, 7/3) ?
Thus, the set H forms an open cover of E ? Granted, this is a very simple example but I want to be able to grasp it at layman's terms so that I don't assume the wrong things for a large set of G-alpha's (large indexing set)Ok, now, onto subcover. Is a subcover open or closed? or does the term cover always imply that said cover is open?
Does the term subcover simply mean a subset of covers? I realize that in terms of the definition of compactness, a compact subset K is contained in the union of finitely many indices, alpha-1 to alpha-n, so now, this might be a trivial question but I'm just trying to think about it in terms of the real number line so here goes; if there are infinitely many numbers in (0,1) aren't there infinitely many numbers in [0,1]? (Yes, I know one is a closed interval and the other open) if so, wouldn't there still be infinitely many non-empty unions of subsets in [0,1]?
I know I am wrong because of the very definition of compactness (the definition in terms of finite subcover) but I'm trying to grasp it intuitively. For example; I like the idea of explaining compactness like this: in a closed set, [a,b] a<b, if you start at one point and take infinitely many steps in one direction, you will get (some arbitrary distance) closer to another point; by extension, it's easy to see why the real line isn't compact. But obviously I'm in Analysis because I also want to be able to extend the definitions to other proofs, not just simple descriptions.
I just try to start with simple examples just to make sure I'm clear on the meanings of these definitions, and I'm not just memorizing their notations.Any help with simple, numerical examples will be much appreciated - thank you for your help in advance!
Correct.
Correct. But allow me to pedantic here. In the definition you supplied, you have only defined a cover for a metric space. Here you are taking a cover of a subset of the metric space [tex]\mathbb{R}[/tex].
Of course, you can view E as a metric space itself. But then the sets in your cover need to be open sets IN E! Thus an open cover of [1,2] will consist of the sets [1,3/2) and (4/3,2].
Yes, a subcover is just a subset of the cover such that this subset still covers the entire space.
For example, {(0,1),(1/2,2),(1/2,3/2)} will be an open cover of (0,2). A subcover would be
{(0,1),(1/2,2)}. A subcover would NOT be {(0,1),(1/2,3/2)}.
That said, all the elements of an open cover are open. Thus a subcover of an open cover is again an open cover. If the cover is not necessairily open, then the subcover doesn't need to be open to (but it can be).
Yes, [0,1] may have infinitely many open subsets. But the point is, that among these subsets, you will find finitely many which will still cover [0,1].
Take (0,1), an open cover of this is {(1/2,1),(1/4,1),(1/8,1),...}. But this does not have an open subcover (thus we cannot find finitely many elements in this cover which still cover (0,1) ).
The example you should start of with is the difference between [tex]\{0\}\cup\{1/n~\vert~n>0\}[/tex] and [tex]\{1/n~\vert~n>0\}[/tex].
We can find an open cover of the second set which does not have an open subcover (try to find one!). But we cannot do this for the first set (even though it has more elements!). Indeed, take an open cover {G_i}_i of the first set. Then there must exist an i such that G_i contains 0. But since 0 is the limit of the sequence, there must be an N, such that [tex]1/n\in G_i[/tex] for all i>N. So all but finitely many indices remain uncovered. But we can easily cover these points by finitely many sets. Thus we obtain an finite subcover.
Thank you! I found this part in particular very, very helpful:
"Yes, a subcover is just a subset of the cover such that this subset still covers the entire space.
That said, all the elements of an open cover are open. Thus a subcover of an open cover is again an open cover. If the cover is not necessairily open, then the subcover doesn't need to be open to (but it can be)."I had seen the {0}U{1/n | n>0} and {1/n | n>0} example before (online) but I feel like I can really appreciate the difference now; "So all but finitely many indices remain uncovered." It never occurred to me that all but the finitely many indices remain uncovered (perhaps I was reading it wrong?)
Nonetheless, I really appreciate your examples! Thank you, thank you!
1. What is a cover in mathematics?
A cover in mathematics refers to a collection of sets that completely covers or contains a given set. In other words, every element in the given set is also an element in at least one of the sets in the cover.
2. What is an open cover?
An open cover is a cover where all the sets in the collection are open sets. This is commonly used in topology, where open sets are used to define the structure of a topological space.
3. How is a subcover different from a cover?
A subcover is a cover that is a subset of another cover. In other words, a subcover is a smaller collection of sets that still completely covers the given set. This is useful when working with infinite sets, as it allows us to reduce the size of the cover while still retaining its properties.
4. Can a cover have an infinite number of sets?
Yes, a cover can have an infinite number of sets. This is often the case in topology, where open covers are used to define the structure of a topological space and may involve an infinite number of open sets.
5. How are covers and subcovers used in mathematical proofs?
Covers and subcovers are commonly used in mathematical proofs, particularly in topology and analysis. They are used to show that a given set or space has certain properties, such as being compact or connected. They also allow us to break down complex problems into smaller, more manageable pieces.
  • Topology and Analysis
