How long for a computer to write out a Googolplex
  • Thread starter MathJakob
  • Tags
    Computer
In summary, the conversation discussed the concept of a Googolplex, which is 1010100. The question was how long it would take a computer to print out this number, assuming it could print 100 billion 0's per second. The estimated time was approximately 1010100 seconds or years, which is an incomprehensibly long time. The conversation also included various calculations and estimations to determine the exact time it would take.
MathJakob
161
Just curious, for a start, I don't think there is enough hard drive space in the world to document the number but if a computer could printout 100 billion 0's a second, how many years would it take before the computer had printed out the full number?
I have no idea how to possibly work this out, I tried using Wolfram but I don't even know how to type lol.
A googolplex is an extremely large number, often used informally to refer to a number that is far greater than anything that has practical relevance. It is defined as 10 to the power of a googol, where a googol is 10 to the power of 100. In other words:
1 googol = 10^1001 googolplex = 10^(10^100)
Mathematics news on Phys.org
MathJakob said:
Just curious, for a start I don't think there is enough hard drive space in the world to document the number but if a computer could printout 100billion 0's a second, how many years would it take before the computer had printed out the full number?
I have no idea how to possibly work this out, I tried using wolfram but I don't even know to type lol.
A Googol is 10100, which is 1 followed by 100 zeroes.
How big is a Googolplex?
Googolplex is [tex]10^{googol}[/tex]
Also no SteamKing that does not answer my question unfortunately. It mentions nothing about a computer being able to printout or run through 100billion 0's per second.
I know there is not enough room to write the number out, but if there was, how long would it take a computer printing 100billion 0's per second?
So what is this number without the word "googol"?
100 billion is 1 X 1011 (by American reckoning, with 1 billion being 1,000 million).
This problem isn't hard if you write the numbers in scientific notation.
The googolplex = 10^(10^100)
If there isn't enough material (and enough atoms) in the universe with which to print the value, its pretty safe to say that the time required > the age of the universe.
You're not listening to what I'm saying... I'm not talking about printing the number out onto physical objects, I said this many many times. I simply want to know, if a computer can read 100 billion 0's per second, then how many years will that computer take, until it's read through the entire number.
How hard is it to get an answer around here... I'm terrible at maths cmon guys.
It's not that hard. A googolplex is 10^(10^100). If you print out 10^11 zeros per second, then it will take
t = 10^(10^100) / 10^11 = 10^(10^100-11) = 10^(10^100) seconds
t = 10^(10^100) / (3*10^18) = 10^(10^100-18.5) = 10^(10^100) years
Where the last equality in each line is approximate, since I'm ignoring 11 (or 18.5) compared to a googolplex. However, this is a very, very good approximation.
So the answer is that it will take a googolplex seconds or a googolplex years, both of which are about the same, and both of which are an incomprehensibly long time.
That's how long it would take to count to a googolplex. The challenge at hand is how long it would take to print a googolplex.
That does not take 1010100 operations. It only takes 10100 operations. SteamKing has already referenced a page that provides a time estimate. The only difference is that his reference used an assumption of two zeroes per second rather than 100 billion.
My mistake. So let me re-do my estimate:
t = 10^(100) / 10^11 = 10^(100-11) = 10^89 seconds
t = 10^(100) / (3*10^18) = 10^(100-18.5) = 3*10^81 years
Still an extremely long time, but not so incomprehensible.
so that's 30 sexvigintillion years, (3,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000 years) or 1/10 novemvigintillion seconds, (100,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000 seconds) if the math is correct. according to http://bmanolov.free.fr/numbers_names.php
I guess. my brain shuts down after 6 zero
I assume that is how long it takes for the computer to do it. If so, my best guess as to how long it would take to count out is: Go get in your car right now. Start driving, any direction, at about 75 mph. Now drive to the very edge of the universe. Return home. You might have done it by now. If not, you may need to repeat.
1. How long would it take for a computer to write out a Googolplex?
Assuming the computer is able to write one character per nanosecond, it would take approximately 3.16 x 10^23 years to write out a Googolplex, which is significantly longer than the age of the universe.
2. Can a computer actually write out a Googolplex?
In theory, a computer could write out a Googolplex, as it is a finite number. However, the amount of time and resources required would make it virtually impossible for a computer to do so.
3. How many zeros are in a Googolplex?
A Googolplex is a one followed by a Googol zeros, which is 10^100 zeros. This number is so large that it is impossible to write it out in standard form.
4. How does a Googolplex compare to other large numbers?
A Googolplex is significantly larger than other commonly used large numbers, such as a trillion or a quadrillion. In fact, a Googolplex is so large that it is larger than the estimated number of atoms in the observable universe.
5. Why is a Googolplex used in discussions about computers and their capabilities?
A Googolplex is often used as an example to illustrate the vastness and complexity of numbers, and to demonstrate the limitations of computers and their capabilities. It also helps to put into perspective the incredible speed and efficiency of modern computers in performing complex tasks.
  • General Math
  • General Math
  • General Discussion
  • Science Fiction and Fantasy Media
  • Sticky
