Webbd050
- 35
- 4
Crash? Just the force from the deceleration not actually being crushed. Thanks
The size of the flywheel does not directly affect the force acting on it. However, a larger flywheel may require more force to accelerate or decelerate due to its greater rotational inertia.
The force acting on the flywheel is impacted by several factors, including the mass of the flywheel, the speed at which it is rotating, and any external forces acting on it, such as friction or air resistance.
The force acting on the flywheel can be calculated using the formula F = ma, where F is the force, m is the mass of the flywheel, and a is the acceleration. This formula can be modified to take into account the rotational speed and inertia of the flywheel.
The shape of the flywheel does not directly impact the force acting on it. However, the distribution of mass within the flywheel can affect its rotational inertia, which in turn can impact the force required to accelerate or decelerate it.
The force acting on the flywheel in a car can be measured using a dynamometer, which is a device that measures torque and rotational speed. This data can then be used to calculate the force acting on the flywheel using the aforementioned formula.
