Which rational numbers between 0 and 1 have finite decimal expansions?
In summary, if x=0.a1a2...an then r=\frac{10n}{2^a5^b} where either a or b could be 0 and p is a prime.Splitting hairsI think either of a and b is more precise, and p does not have to be prime.I think either of a and b is more precise.The usage of "and" is incorrect; I don't require that both a and b be 0 whenever one of them is 0. Also, the "either ... or" construction does not require the use of "of". See American Heritage.The usage of "and" is incorrect; I don't require that both a and b be
Natasha1
493
The question I have been given is essencially this:
Give a brief description, with some explanation, of which rational numbers between 0 and 1 have finite decimal expansions? [An example is 3/40 = 0.075, however 2/3 = 0.66666666666...]
I am truly :confused: Please help.
I have looked on http://mathworld.wolfram.com/DecimalExpansion.html
but I need more? anyone?
I am truly stuck as there are a infinite number of rational numbers. I just need a general explanation, but obviously the more I put the better... please help! :-)
After some quick testing, it looks like the pattern seems to be
[tex]
finite decimal = \frac{x}{2^a \times 5^b}
[/tex]
I don't know how to "prove" that, but it makes sense as 10 = 2 X 5
(1)-(4) of your link explains the condition you're after. Do you understand what's there?
That page gives an easy to derive characterization, r = p/(2a5b) where either a or b could be 0 and p is a prime.
Splitting hairs
Stand corrected, sorry.
Actually, I changed my post before seeing yours having realized my mistake.:redface:
No problem, I just looked that up myself. :smile: You're right, p doesn't have to be prime.
Hey, upon further research (and splitting the "splits"), I found that "either of a and b" is a legitimate expression:
it does mean either a, or b, or both (like in OR operator in Boolean logic)!:approve:
In [tex]r = \frac {p}{2^a 5^b}[/tex] either of three scenarious (a=0, b=0, both a=0 and b=0) is possible.
Well, if both a and b equal 0, can we still call r a fraction?:cool:
BTW, seems we abandoned Natasha in our semantic fencing.
Her plea "I need more? anyone?" went unanswered.
On the other hand, what could be more the MathWorld?
Is this becoming an English grammar forum now?
Please don't multiple post. I've merged your two threads.
Sorry I am new to all this. Won't multiply post in the future! Promise
Can anyone see something else?
Can anyone see something else? :bugeye:
Suppose x= 0.a1a2...an.
What happens if you multiply both sides by 10n?
Do you see how to write x as a fraction?
What is the denominator?
What happens when you reduce to lowest terms?
1. What is a rational number?
A rational number is any number that can be expressed as a ratio of two integers (whole numbers), such as 1/2, 3/4, or -5/8.
2. Why is the range between 0 and 1 specified?
This range is specified because it includes all numbers that have finite decimal expansions, which is the focus of the question.
3. What is a finite decimal expansion?
A finite decimal expansion is a decimal representation of a number that has a finite number of digits after the decimal point, such as 0.25 or 0.75.
4. How do you determine which rational numbers between 0 and 1 have finite decimal expansions?
To determine which rational numbers between 0 and 1 have finite decimal expansions, you can use the decimal representation of the fraction and see if it has a finite number of digits after the decimal point. If it does, then it has a finite decimal expansion.
5. Are there rational numbers between 0 and 1 that do not have finite decimal expansions?
Yes, there are rational numbers between 0 and 1 that do not have finite decimal expansions. For example, 1/3 is a rational number between 0 and 1, but its decimal representation is 0.333... which has an infinite number of digits after the decimal point.
