Chesmistry 12|VSEPER Problems|Quick Problems
  • Thread starter Raza
In summary, The VSEPER diagram for C2H2 has 5 clouds on the central atom with bond angles of 1200 in the plane and 900 in vertical. This molecule also has a triple bond composed of 1 sigma and two pi bonds, with the H-C bond being a sigma bond. For further understanding of molecular shapes and bonds, there are resources available in your chemistry textbook and online.
Raza
203
Hi,
I am confused with this molecule's VSEPER diagram.
I was told to draw the VSEPER diagram for C2H2
This is what I drew:
http://www.albumtown.com/data/c44e503833b64e9f27197a484f4257c0/1142_p807888.jpeg
Then, it asked me to name the number and type of clouds on the central atom with the bond angles. This is where I am confused.
Does it have 5 clouds?
Is the bond angles 1200 in the plane and 900 in vertical?
There should be a discussion of sigma and pi bonds in your chemistry textbook.
In H - C = C - H, the triple bond is composed of 1 sigma and two pi bonds. The H-C is a sigma bond.
There is a nice brief discussion of molecular shapes and bonds here -
http://www.chem.hope.edu/~chemboard/f05/messages/15/Molecular_Shapes_Lab-1308.pdf
See also -
http://www.chem.unl.edu/cak/bk5.htm
http://www.utdallas.edu/~parr/chm1341/13410618.html
Hi there,
Thank you for sharing your VSEPER diagram for C2H2. From what I can see, your diagram is correct. C2H2 has a linear molecular geometry with a bond angle of 180 degrees. This means that the central atom (carbon) has two bonding pairs and zero lone pairs, resulting in a total of two clouds. The bond angles are indeed 180 degrees, which is consistent with a linear geometry. I hope this helps clarify your confusion. Keep up the good work!
1. What are VSEPR problems in Chemistry 12?
VSEPR stands for Valence Shell Electron Pair Repulsion. It is a theory used in chemistry to predict the shape of molecules based on the repulsion between valence electron pairs around the central atom.
2. What are some common types of VSEPR problems?
Some common types of VSEPR problems include determining the molecular geometry of a molecule, predicting the bond angles, and identifying the hybridization of the central atom.
3. How do you solve VSEPR problems?
To solve VSEPR problems, you first need to determine the Lewis structure of the molecule. Then, you can use the VSEPR theory to determine the molecular geometry and bond angles based on the number of electron pairs around the central atom.
4. What are some quick problem-solving tips for VSEPR problems?
Some quick tips for solving VSEPR problems include memorizing the common molecular geometries and bond angles, understanding the basic principles of VSEPR theory, and practicing with different types of molecules.
5. How important are VSEPR problems in Chemistry 12?
VSEPR problems are essential in Chemistry 12 as they help students understand the 3D structure of molecules, which is crucial in understanding their properties and behavior. These problems also help students develop critical thinking and problem-solving skills, which are essential in the field of chemistry.
9K
  • Classical Physics
